* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 4 | -2/+6 |
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Corrected reference to LIBC_LIBM to work on all targets. | Joel Sherrill | 1997-08-27 | 1 | -1/+1 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 2 | -14/+18 |
| | | | | error number mapping. | ||||
* | Modified to support the BSP family concept. | Joel Sherrill | 1997-08-27 | 11 | -21/+21 |
* | Modified to have correct address for vector table on multiple models. | Joel Sherrill | 1997-08-27 | 2 | -0/+10 |
* | Added rule so TARGET_VARIANTS are dependent on the environment stuff. | Joel Sherrill | 1997-08-27 | 1 | -1/+4 |
* | Patches from Chris Johns to clean up test. | Joel Sherrill | 1997-08-26 | 5 | -19/+52 |
* | removed -lm | Joel Sherrill | 1997-08-26 | 1 | -1/+1 |
* | Corrected to compile with egcs. | Joel Sherrill | 1997-08-26 | 2 | -5/+5 |
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 1 | -2/+2 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1997-08-22 | 2 | -0/+10 |
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 5 | -9/+96 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 2 | -2/+12 |
* | Removed redundant stanza. | Joel Sherrill | 1997-08-22 | 1 | -2/+0 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 2 | -0/+2 |
* | start no longer a global symbol per Eric Norum's request. | Joel Sherrill | 1997-08-22 | 2 | -2/+12 |
| | | | | | | | | | | Also, I ran across a nasty problem the first time I tried downloading and running an application compiled with the new snapshot. To make a very long story short, the `start' in ...../m68k/gen6860/start360/start360.s must not be global. The change is simple -- just remove the .globl start from start360.s. | ||||
* | Switched to new version of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -29/+29 |
* | moved mc68230.h from main include directory to motorola | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 2 | -144/+582 |
* | Fixed type | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Corrected typo | Joel Sherrill | 1997-08-04 | 9 | -9/+9 |
* | Corrected descent to a hardcoded directory and made it dependent on the cpu ↵ | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
| | | | | model | ||||
* | Fixed typo and removed duplicated code | Joel Sherrill | 1997-08-04 | 1 | -4/+1 |
* | First attempt at values for PPC | Joel Sherrill | 1997-08-04 | 3 | -0/+9 |
* | Trying to support all models | Joel Sherrill | 1997-08-04 | 1 | -20/+4 |
* | Trying to support all models. | Joel Sherrill | 1997-08-04 | 1 | -0/+6 |
* | consolex built for all models. | Joel Sherrill | 1997-08-04 | 1 | -8/+4 |
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 8 | -9/+8 |
* | Correcting difference between mvme162lx and mvme162. All versions have | Joel Sherrill | 1997-08-04 | 1 | -0/+5 |
| | | | | four serial ports. | ||||
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 4 | -5/+7 |
* | Modified to reflect changes in mc68681.h header file. | Joel Sherrill | 1997-08-04 | 1 | -104/+200 |
* | Header files moved into zilog subdirectory. | Joel Sherrill | 1997-08-04 | 1 | -2/+2 |
* | Moved files into the zilog and motorola subdirectories. | Joel Sherrill | 1997-08-04 | 1 | -3/+12 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 2 | -8/+38 |
* | Added include/motorola and include/zilog directories to the | Joel Sherrill | 1997-08-04 | 1 | -8/+10 |
| | | | | install tree and cleaned up spacing. | ||||
* | moved from main include directory | Joel Sherrill | 1997-08-04 | 10 | -0/+956 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 3 | -1/+102 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Added conditional for KA9Q. | Joel Sherrill | 1997-08-01 | 1 | -0/+4 |
* | Added include of termios.h which was accidentally left out. | Joel Sherrill | 1997-08-01 | 1 | -0/+2 |
* | Added consolex to wrapup | Joel Sherrill | 1997-08-01 | 1 | -0/+1 |
* | Corrected typo. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Made to work. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Removed warnings. | Joel Sherrill | 1997-08-01 | 1 | -2/+2 |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 17 | -11/+1609 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 83 | -0/+12481 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 7 | -6/+84 |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 |
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 6 | -30/+139 |
