* | 2006-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-01 | 3 | -1/+17 |
| | | | | | | * configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option. This makes it easy to build the pc386 BSP in a configuration that corresponds to qemu with COM1 redirected to stdio. | ||||
* | Fix Formatting. | Joel Sherrill | 2006-02-01 | 1 | -4/+5 |
* | 2006-02-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2006-02-01 | 1 | -0/+5 |
| | | | | | * gnatinstallhandler.c: Rename since old name is now used by GNAT source. | ||||
* | Formatting. | Joel Sherrill | 2006-02-01 | 2 | -12/+13 |
* | 2006-02-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2006-02-01 | 1 | -1/+3 |
* | Add code to maintain CPU load average. | Eric Norum | 2006-01-29 | 4 | -6/+51 |
* | 2006-01-26 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2006-01-27 | 5 | -3/+29 |
| | | | | | | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h: Added 2F address modifier for VME64 CSR access. | ||||
* | 2006-01-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-23 | 2 | -0/+7 |
| | | | | * runtest: Add pvr setting. | ||||
* | 2006-01-20 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2006-01-21 | 2 | -9/+37 |
| | | | | | | | * mpc6xx/mmu/pte121.c: consistency check now warns instead of reporting an error when coming across a non 1:1 VSID; fix: triv121IsRangeMapped() needs to convert segment offset into a page index if the vsid argument is non-special. | ||||
* | 2006-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-20 | 2 | -2/+94 |
| | | | | | | * psim: Enhance to add limit on how long a single test is allowed to execute. This can be used to significantly enhance the reliability of long batch test runs. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 65 | -65/+65 |
* | Replace illegal lvalue casts with explicit increments. | Eric Norum | 2006-01-12 | 2 | -5/+12 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 66 | -0/+234 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 64 | -128/+0 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
| | | | | * wrapup/Makefile.am: Add preinstall.am. | ||||
* | Add preinstall.am | Ralf Corsepius | 2006-01-12 | 1 | -15/+1 |
* | New. | Ralf Corsepius | 2006-01-12 | 1 | -0/+26 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 4 | -37/+31 |
| | | | | | | * libchip/Makefile.am: Build libchip/network/smc91111. * libchip/network/smc91111.c, libchip/network/smc91111config.h: Eliminate cyg_int* crap. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 58 | -116/+99 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 3 | -9/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 56 | -109/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 2 | -2/+2 |
* | Remove unnecessary CLEANFILES. | Ralf Corsepius | 2006-01-12 | 5 | -12/+3 |
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h, | Till Straumann | 2006-01-12 | 5 | -20/+81 |
| | | | | | | | | | vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h: No longer enable posted-writes on master windows (creates race-condition on memory-mapped devices). A new flag allows for signalling that a window maps 'ordinary memory'. Disable VME IRQ level if no handler is registered with interrupting vector. | ||||
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h: | Till Straumann | 2006-01-12 | 3 | -8/+17 |
| | | | | Eliminate obsolete types. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -69/+3 |
| | | | | * librdbg/Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 4 | -0/+216 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 18 | -538/+73 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 5 | -0/+310 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -283/+30 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 27 | -683/+82 |
* | New. | Ralf Corsepius | 2006-01-11 | 22 | -0/+1306 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 20 | -545/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 6 | -0/+364 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 34 | -68/+85 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-11 | 3 | -4/+1 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -4/+16 |
| | | | | | * aclocal/bsp-configure.m4: Add ampolish3. New header guards. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2006-01-11 | 2 | -7/+4 |
| | | | | * bspstart.am: Remove. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 33 | -900/+139 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -246/+33 |
* | New. | Ralf Corsepius | 2006-01-10 | 14 | -0/+1240 |
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -151/+33 |
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+5 |
| | | | | * shared/start.S: Add include of bspopts.h so SIS quirks will trigger. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -9/+14 |
| | | | | | * startup/linkcmds: Merge from 4.6 branch. Now the copy_data loop works. |
