* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
* mpc6xx/wrapup/.cvsignore: Remove.
* mongoosev/duart/Makefile.am: Remove.
* mongoosev/vectorisrs/Makefile.am: Remove.
* mongoosev/Makefile.am: Merge-in vectorisrs/Makefile.am,
duart/Makefile.am.
* r46xx/vectorisrs/Makefile.am: Remove.
* r46xx/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/cache/Makefile.am: Remove.
* shared/interrupts/Makefile.am: Remove.
* shared/Makefile.am: Merge-in cache/Makefile.am,
interrupts/Makefile.am.
* tx39/vectorisrs/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/misc/Makefile.am: Remove.
* shared/Makefile.am: Merge-in the Makefile.ams above.
Eliminate VPATH.
* cache/Makefile.am: Eliminate VPATH.
* Makefile.am: Eliminate VPATH.
* ppc403/clock/Makefile.am: Remove.
* ppc403/console/Makefile.am: Remove.
* ppc403/ictrl/Makefile.am: Remove.
* ppc403/timer/Makefile.am: Remove.
* ppc403/tty_drv/Makefile.am: Remove.
* ppc403/vectors/Makefile.am: Remove.
* ppc403/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to ppc403/Makefile.ams.
* mpc505/ictrl/Makefile.am: Remove.
* mpc505/timer/Makefile.am: Remove.
* mpc505/vectors/Makefile.am: Remove.
* mpc505/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to mpc8xx/Makefile.ams.
* mpc8xx/clock/Makefile.am: Remove.
* mpc8xx/console-generic/Makefile.am: Remove.
* mpc8xx/cpm/Makefile.am: Remove.
* mpc8xx/exceptions/Makefile.am: Remove.
* mpc8xx/mmu/Makefile.am: Remove.
* mpc8xx/timer/Makefile.am: Remove.
* mpc8xx/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Remove mpc6xx/*/Makefile, mpc8260/*/Makefile.
* mpc6xx/clock/Makefile.am: Remove.
* mpc6xx/exceptions/Makefile.am: Remove.
* mpc6xx/mmu/Makefile.am: Remove.
* mpc6xx/timer/Makefile.am: Remove.
* mpc6xx/wrapup/Makefile.am: Remove.
* mpc6xx/Makefile.am: Merge-in Makefile.ams above.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
* shared/include/Makefile.am: Remove.
* shared/src/Makefile.am: Remove.
* shared/Makefile.am: Merge-in Makefile.ams above.
* startup/linkcmds.dl: Remove SEARCH_DIR.
* automake/compile.am: Remove LINK_LIBS (Unused).
* configure.ac: Reflect changes to RTEMS_CONFIG_SUBDIR.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* acinclude.m4: Rework RTEMS_CONFIG_SUBDIR.
* Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* start/Makefile.am: Build $(ARCH)/start16$(LIB_VARIANT).bin.
* Makefile.am: Remove RTEMS_BSP-subdir rule.
* configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit
rules for RTEMS_BSP-subdirs.
* support/Makefile.am: Pass @RTEMS_BSP@ to AM_CPPFLAGS.
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* start/Makefile.am: Use project_lib_DATA.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/i386/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/m68k/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/powerpc/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* bootloader/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from
* include/rdbg/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/duart/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* tx39/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/clock/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/mmu/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/tty_drv/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/include/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/src/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
* Makefile.am: Use mkdir_p instead of mkinstalldirs.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bootloader/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vme/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
