* irq/irq_asm.S: Add FIQ support.
* rtems-stub-glue.c: Removed should only be common copy.
* support/init.c: Included <unistd.h> for exit(2).
* support/test_support.adb: Eliminated warnings by commenting out
unused variables.
* serial/z85c30.c: Eliminated warning by clarifying statement.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* sp32/.cvsignore: New file.
* PR271 was not applicable against the current source but included
a nice test that Joel decided to add to the tree as sp32.
* sp32/Makefile.am, sp32/init.c, sp32/sp32.scn: New file.
* Makefile.am, configure.ac: Modified to reflect addition.
* include/bsp.h, startup/Makefile.am, startup/bspclean.c:
Cleanup so the BSP works.
* start/start16.S: Remove unwanted + at beginning of relative
numeric label.
numeric label.
* samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am:
Now appear to mostly compile.
* samples/hello/Makefile.am: Make sure init.c is compiled and
included. This test now runs.
* Part of addressing PR281.
* target.cfg.in: Removed remaining support for RTEMS_USE_GCC272
and RTEMS_LIBC_DIR.
* main.cfg: Added recognition of VARIANT=DEBUG on command line.
* compilers/gcc-target-default.cfg: Removed remaining support for
RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug
as one of the LDFLAGS when the debug variant is specified.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
* Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
* configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* clock/clock.c: Disabled use of fast idle since it seems broken
with gcc 3.2.
* samples/base_mp/config.h: New file previously missed.
* network/Makefile.am, network/README.cs8900, network/cs8900.c,
network/cs8900.h: Significant update which corrects the problem
where the cs8900.c file was actually the BSP glue. Joel did
some hacking so this file will compile. Previously it required
providing a target.h file to compile.
* network/cs8900.c.bsp: New file.
* pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve
warnings.
* Makefile.inc.in: Comment out RTEMS_USE_GCC272.
Comment out RTEMS_LIBC_DIR.
* base_mp now builds and can be considered a bit of an example for
the other mptests.
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am,
samples/base_mp/mptest.adb, samples/base_mp/mptest.ads,
Modified to make compile.
* mptests/mp01/node1/mptest-per_node_configuration.adb,
mptests/mp01/node2/mptest-per_node_configuration.adb,
mptests/mp02/node1/mptest-per_node_configuration.adb,
mptests/mp02/node2/mptest-per_node_configuration.adb,
mptests/mp03/node1/mptest-per_node_configuration.adb,
mptests/mp03/node2/mptest-per_node_configuration.adb,
mptests/mp04/node1/mptest-per_node_configuration.adb,
mptests/mp04/node2/mptest-per_node_configuration.adb,
mptests/mp05/node1/mptest-per_node_configuration.adb,
mptests/mp05/node2/mptest-per_node_configuration.adb,
mptests/mp06/node1/mptest-per_node_configuration.adb,
mptests/mp06/node2/mptest-per_node_configuration.adb,
mptests/mp07/node1/mptest-per_node_configuration.adb,
mptests/mp07/node2/mptest-per_node_configuration.adb,
mptests/mp08/node1/mptest-per_node_configuration.adb,
mptests/mp08/node2/mptest-per_node_configuration.adb,
mptests/mp09/node1/mptest-per_node_configuration.adb,
mptests/mp09/node2/mptest-per_node_configuration.adb,
mptests/mp10/node1/mptest-per_node_configuration.adb,
mptests/mp10/node2/mptest-per_node_configuration.adb,
mptests/mp11/node1/mptest-per_node_configuration.adb,
mptests/mp11/node2/mptest-per_node_configuration.adb,
mptests/mp12/node1/mptest-per_node_configuration.adb,
mptests/mp12/node2/mptest-per_node_configuration.adb,
mptests/mp13/node1/mptest-per_node_configuration.adb,
mptests/mp13/node2/mptest-per_node_configuration.adb,
mptests/mp14/node1/mptest-per_node_configuration.adb,
mptests/mp14/node2/mptest-per_node_configuration.adb,
samples/base_mp/node1/mptest-per_node_configuration.adb,
samples/base_mp/node2/mptest-per_node_configuration.adb: Removed
as this information should come from config.h.
* rtems_webserver/md5.h: Add missing newline.
* mpc8260/exceptions/raw_exception.c: #include <string.h>.
#include <bspIo.h>.
* pci/pcibios.c: #include <string.h>.
* mptests/mp01/node1/.cvsignore: New.
* mptests/mp01/node2/.cvsignore: New.
* mptests/mp02/node1/.cvsignore: New.
* mptests/mp02/node2/.cvsignore: New.
* mptests/mp03/node1/.cvsignore: New.
* mptests/mp03/node2/.cvsignore: New.
* mptests/mp04/node1/.cvsignore: New.
* mptests/mp04/node2/.cvsignore: New.
* mptests/mp05/node1/.cvsignore: New.
* mptests/mp05/node2/.cvsignore: New.
* mptests/mp06/node1/.cvsignore: New.
* mptests/mp06/node2/.cvsignore: New.
* mptests/mp07/node1/.cvsignore: New.
* mptests/mp07/node2/.cvsignore: New.
* mptests/mp08/node1/.cvsignore: New.
* mptests/mp08/node2/.cvsignore: New.
* mptests/mp09/node1/.cvsignore: New.
* mptests/mp09/node2/.cvsignore: New.
* mptests/mp10/node1/.cvsignore: New.
* mptests/mp10/node2/.cvsignore: New.
* mptests/mp11/node1/.cvsignore: New.
* mptests/mp11/node2/.cvsignore: New.
* mptests/mp12/node1/.cvsignore: New.
* mptests/mp12/node2/.cvsignore: New.
* mptests/mp13/node1/.cvsignore: New.
* mptests/mp13/node2/.cvsignore: New.
* mptests/mp14/node1/.cvsignore: New.
* mptests/mp14/node2/.cvsignore: New.
* samples/base_mp/node1/.cvsignore: New.
* samples/base_mp/node2/.cvsignore: New.
* mptests/Makefile.am: New.
* mptests/mp01/Makefile.am: New.
* mptests/mp01/node1/Makefile.am: New.
* mptests/mp01/node2/Makefile.am: New.
* samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT).
* samples/base_mp/node1/Makefile.am: New.
* samples/base_mp/node2/Makefile.am: New.
* configure.ac: Add mptests/mp01. Add samples/base_mp.
* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* shell/shell.c: #include <time.h>
* wrapup/Makefile.am: Eliminate LIBNAME.
* tmtests/tm20/Makefile.am: Remove EXPADA.
* samples/base_mp/mptest.ads: Removed lingering reference to BSP_MPCI.
* rtems.adb (IO_Initialize): Make this match the C prototype.
* console/Makefile.am: Add $(PROJECT_INCLUDE)/rtems to
PREINSTALL_FILES.
* console/mouse_parser.c: Include <string.h> (for strcmp).
* console/vt.c: Include <string.h> (for memcpy).
* wd8003/wd8003.c: Include <string.h> (for memcpy, memset).
* samples/base_mp/.cvsignore: New file.
* configure.ac: Add ada-tests.
* sptests/sp09/Makefile.am: Remove EXPADA.
* sptests/sp09/sptest.adb: Remove RESULT from SCREEN_13.
* sptests/sp19/Makefile.am: Remove EXPADA.
* sptests/sp21/Makefile.am: Remove EXPADA.
* sptests/sp21/sptest.adb: Remove RESULT from TASK_1.
* tmtests/tmoverhd/dummy_rtems.adb: Reflect changes to IO_Managers.
* tmtests/tmoverhd/dummy_rtems.ads: Reflect changes to IO_Managers.
* tmtests/tm20/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Fixed
call to RTEMS IO Manager services.
* sptests/sp19/sptest.adp: Fix include paths.
* sptests/sp19/sptest.adb: Remove.
* sptests/sp19/Makefile.am: Let m4 generate sptests.adb from
sptests.adp.
* rtems.ads: Corrected binding for Io_Initialize.
* sptests/sp21/sptest.adb: Fixed IO_Initialize invocations to
match corrected prototype.
* sptests/sp19/sptest.adp: Added from old Ada implementation.
* tmtests/tm27/.cvsignore: Removed. Missed in previous attempts.
