path: root/c (follow)
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-2/+6
| | | | * Makefile.am: Correct path to clockdrv_shell.c.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-4/+5
| | | | | * configure.ac: Remove AM_CONDITIONAL(HAS_MP). Remove RTEMS_CHECK_MULTIPROCESSING.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-2/+4
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-035-5/+20
| | | | | | | * libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-4/+5
| | | | * Makefile.am: Cosmetics.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-034-8/+10
| | | | | * configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING. Remove AM_CONDITIONAL(HAS_MP).
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0211-13/+21
| | | | | | | | | | | | * aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP). Add AM_CONDITIONAL(HAS_MP). * wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel. * configure.ac: Remove AM_CONDITIONAL(HAS_MP). * aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING (Deprecated by autoconf 2.59).
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0216-239/+127
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. * bsp_specs: Sync with other BSPs, fixup missing brace.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-022-1/+5
| | | | * Makefile.am: Correct path to libcpu.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-022-2/+6
| | | | * Makefile.am: Fix minor bugs in previous patch.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0215-228/+112
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0217-264/+132
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0215-212/+117
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-0213-201/+99
| | | | | | | | | * Makefile.am: Merge-in console/Makefile.am, liblnk/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, liblnk/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3117-230/+123
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-311-0/+6
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3113-194/+112
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-313-115/+138
| | | | | * start/start.S: Replace #-ASM-style comments with C-/**/ comments. * start/reg.S: Remove //-comments
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3116-241/+145
| | | | | | | | | | * Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore, irq/.cvsignore, network/.cvsignore, startup/.cvsignore, vectors/.cvsignore. Use automake compilation rules. * clock/.cvsignore, console/.cvsignore, irq/.cvsignore, network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile: Reflect changes above.
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3124-367/+191
| | | | | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, universe/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, universe/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3118-269/+138
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3018-260/+142
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, ide/Makefile.am, irq/Makefile.am, network/Makefile.am, startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, ide/Makefile.am, irq/Makefile.am, network/Makefile.am, startup/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-307-120/+75
| | | | | | | | * Makefile.am: Merge-in dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am. Use automake compilation rules. * dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3019-217/+126
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove. * configure.ac, wrapup/Makefile.am: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-308-93/+61
| | | | | | | | * Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use automake compilation rules. * dlentry/Makefile.am, startup/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3016-225/+122
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3018-277/+141
| | | | | | | | | | * Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am, console/Makefile.am, irq/Makefile.am, network/Makefile.am, startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * canbus/Makefile.am, clock/Makefile.am, console/Makefile.am, irq/Makefile.am, network/Makefile.am, startup/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-306-85/+75
| | | | | | | * wrapup/Makefile.am: Remove. * configure.ac: Remove wrapup. * shared/Makefile.am: Use automake compilation rules. Build *.rels.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3026-486/+270
| | | | | | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am, start/Makefile.am, startup/Makefile.am, vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules. Rename clock.rel to pclock.rel (Conflict with libcpu). * clock/Makefile.am, console/Makefile.am, irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am, start/Makefile.am, startup/Makefile.am, vectors/Makefile.am, vme/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3029-212/+131
| | | | | | * Makefile.am: Merge-in start/Makefile.am. * start/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3018-12/+59
| | | | | * wrapup/Makefile.am: Reflect changes to ../support/*exception_processing/*.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-304-15/+26
| | | | | * configure.ac: Add RTEMS_PROG_CCAS. * Makefile.am: Use automake compilation rules.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-304-18/+29
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-308-4/+17
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-302-3/+7
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3015-224/+105
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3015-245/+144
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-302-0/+6
| | | | * configure.ac: Add RTEMS_ENV_RTEMSBSP.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3019-96/+55
| | | | | | | | | | | | | * Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am, network_ada/adasockets/Makefile.am, network_ada/Makefile.am, network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake compilation rules. * debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am, network_ada/adasockets/Makefile.am, network_ada/Makefile.am, network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3030-476/+260
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignore.Ralf Corsepius2004-01-295-10/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-298-187/+111
* Remove unnecessary .cvsignoreRalf Corsepius2004-01-297-14/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2910-237/+139
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules. * clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am, trap34/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-296-149/+95
| | | | | | | | * Makefile.am: Merge-in console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignore.Ralf Corsepius2004-01-294-8/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-297-147/+102
| | | | | | | | | * Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, scitab/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignoreRalf Corsepius2004-01-296-12/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-299-210/+115
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2958-35/+203
| | | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS.
