A new option RTEMS_INTERRUPT_REPLACE is introduced that permits updating
the first interrupt handler for the registered interrupt vector and
matching argument. If no match is found, the install function fails
with RTEMS_UNSATISFIED.
The Interrupt Manager Extension offers interrupt handlers with an
argument pointer. It is impossible to update two words (handler and
argument) atomically on most architectures. In order to avoid an SMP
lock in bsp_interrupt_handler_dispatch() which would degrade the
interrupt response time an alternative must be provided that makes it
possible to tear-down interrupt sources without an SMP lock.
Add RTEMS_INTERRUPT_REPLACE option to Interrupt Manager Extension. This
enables a clean tear-down of interrupt sources on SMP configurations.
Instead of an interrupt handler removal a replacement handler can be
installed to silence an interrupt source. This can be used in contexts
that allow no sophisticated synchronization (e.g. in atexit() or fatal
handlers).
The previous implementation used an instruction cache line size of 0,
this is a bogus value. Use a instruction cache line size of 64 since
the L2 cache may have a line size of 32 or 64. A greater value should
cause no harm.
Use a FLUSH operation for _CPU_cache_invalidate_instruction_range().
This is a preperation step to support the L2 cache.
Add rtems_cache_get_data_cache_size() and
rtems_cache_get_instruction_cache_size().
A cache line cannot have a negative size.
The vector number of spurious interrupts was wrong after the interrupt
handler removal on SMP configurations.
The SPARC processors supported by RTEMS have no built-in CPU counter
support. We have to use some hardware counter module for this purpose.
The BSP must provide a 32-bit register which contains the current CPU
counter value and a function for the difference calculation. It can use
for example the GPTIMER instance used for the clock driver.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
The 32-bit ABIs for thread-local storage (TLS) and EABI read-only
small-data area have a conflicting register (r2) usage. Use the System
V small-data instead (here r2 is system reserved).
Disabling of interrupts is not enough to ensure mutual exclusion on SMP
configurations.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
Since the per-CPU SMP lock must be acquired and released to send the
message a single interrupt broadcast operations offers no benefits. If
synchronization is required, then a SMP barrier must be used anyway.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
Move vital code out of debug section. Harmonize variable names with
other implementations.
Add _LEON3_Get_current_processor().
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
The _CPU_Context_switch() is a normal function call. The following
registers are volatile (the caller must assume that the register
contents are destroyed by the callee) according to "SYSTEM V APPLICATION
BINARY INTERFACE - SPARC Processor Supplement", Third Edition: g1, o0,
o1, o2, o3, o4, o5. Drop these registers from the context.
Ensure that offset defines match the structure offsets.
The expression "*pi++" post-increments the pointer (not the value).
Use the Global Timer for the Cortex-A9 MPCore clock driver instead of
the Private Timer. This enables a consistent nanoseconds since last
context switch value across all processors.
This reverts commit 7579e255127ee0cf04901bbab6c1538559053508.
Improve QEMU to support AMBA plug and play instead.
Do not return a status.
Delete _CPU_Context_switch_to_first_task_smp() and use
_CPU_Context_restore() instead.
Avoid usage of the same stack area by multiple secondary processors at
the same time.
Avoid magic delay loops.
Install inter-processor interrupt (IPI) handler before secondary CPUs
are started. This ensures that secondary CPUs fetch the newly installed
handler.
Remove superfluous return statement.
