Haven't had a chance to do an extensive shake-out of 980710, but it
builds just fine on FreeBSD 2.2.5 (after termios is fixed using the
attached patch), and the tests run fine. FYI: FreeBSD doesn't support
System V IPC out of the box, but one only needs to add three options
to the kernel build configuration file, recompile the kernel, and
you're ready.
size of the minimum mc68681 driver. The clock speed field can not
now be configured as NULL but must instead specify the address of
the default table.
register access routines.
Added prototype for mc68681_build_imr(), mc68681_process(), and
mc68681_enable_interrupts().
the need for the ringbuffer manipulation in this driver. It should
also allow the removal of mc68681_flush. This greatly simplified the
interrupt processing.
Reworked Interrupt Mask Register handling. Added imr field to the device
context. This handling makes sure that the IMR accurately reflects the
state of the port in use and its mate. This required the reworking of
the mc68681_enable_interrupts() routine to allow for the specification
of which interrupt sources were being enabled/disabled.
Reworked initialization to reset using port address rather than chip
base address. Basically we were always resetting port 0.
Added deviceType field which allows for multiple chips of the same
class to have the same vector number.
Added proper headers to routines.
interrupt vector can be shared by multiple chips of varying types.
The scheme used in the mc68681 is the one to follow.
compilation section which used CONSOLE_USE_INTERRUPTS to switch all
ports between interrupt and polled mode.
driven.
Redid "mate determination" code to check that the chip base address was
the same but the port address was different.
Moved mc68681_process and mc68681_build_imr to the bottom of the file
so they would not be inlined.
Removed the code which forced mc68681_build_imr to always return 0 which
resulted in interrupts never being enabled from the chip.
Corrected spacing in prototype of mc68681_write_support_int.
<corsepiu@faw.uni-ulm.de> and his comments are below:
Joel, obviously you did apply my previous patch to
gcc-target-default.cfg -- This should have been gcc.cfg
(gcc-target-default.cfg should NOT contain any EXEEXT).
c/src/lib/libbsp/i386/pc386/console/console.c
__assert() modified so it prints on selected console instead of
PC console
c/src/lib/libbsp/i386/pc386/console/inch.c
inch_sleep() modified, so it does not depend upon tmacros.h
c/src/lib/libbsp/i386/pc386/pc386dev/GDB.HOWTO
description updated
c/src/lib/libbsp/i386/pc386/startup/exit.c
last output before call to exit() will be printed properly on
serial console
c/src/lib/libbsp/i386/pc386/startup/irq.c
re-submitted bug fix for problem in irqs over 7.
> It seems that rules for %{EXEEXT} don't exist in gcc-target-default.cfg
No, gcc-target-default.cfg is used to compile executables for the target
only, not for the host.
EXEEXT may only be used for programs to be run on the host.
> What should I add please?
This was a bug in my initial configuration patch to rtems-980616. A
correction to this patch I had sent to Joel at 26.06.98 doesn't seem to
have made it into the snapshot.
Please find attached the patch I had sent to Joel, hopefully this patch
fixes this problem.
Switched to shared default probe.
Renamed sersupp.c so we could have one routine per file to decrease
the baggage pulled into an application by default.
with this ROM monitor.
Still need to address default terminal settings.
Temporarily "if 0" of code which enables interrupts.
Moved setting of command registers at open but the current implementation
is questionable.
Added reset of RX errors while polling TX.
Read polled character as unsigned.
Baud rate mask must be in upper and lower nibble.
to polled.
globally visiable to ease debugging.
Added support for mc68681 "2 column" style baud rate table as
well as the Exar 88681 "4 column" style baud rate table.
Added support for user override of the default baud rate table.
