AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* configure.ac: Unconditionally check for CXX.
Require autoconf-2.57, automake-1.7.2.
* rtems++: Eliminate CC_O_FILES.
PR 338/filesystem
* rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
PR 338/filesystem
* sapi/no-io.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change). Unused function removed.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
* Makefile.am, configure.ac: Added new test loopback which shows how to
use the loopback interface. Thank you Eric Norum for a portable
target independent test which exercises the TCP/IP. This should
prevent massive failures in the TCP/IP stack from reaching the
street.
* loopback/.cvsignore, loopback/Makefile.am, loopback/README,
loopback/init.c, loopback/loopback.scn: New files.
street.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* tx39/vectorisrs/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* r46xx/vectorisrs/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* shared/interrupts/Makefile.am: Ditto.
* shared/cache/Makefile.am: Ditto. Eliminate *_O_FILES.
* timer/Makefile.am: Ditto.
* clock/Makefile.am: Eliminate *_O_FILES.
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/misc/Makefile.am: Ditto.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate @RTEMS_BSP@.cfg, $(OBJS).
* sci/Makefile.am: Likewise.
* hw_init/Makefile.am: Don't include @RTEMS_BSP@.cfg.
