* make/custom/pghplus.cfg: New (relocated from /make/custom).
* make/custom/tqm8xx.cfg: New (relocated from /make/custom).
* make/custom/tqm8xx_stk8xx.cfg: New (relocated from /make/custom).
* make/custom/ss555.cfg: New (relocated from /make/custom).
* make/custom/score603e.cfg: New (relocated from /make/custom).
* make/custom/qemuppc.cfg: New (relocated from /make/custom).
* make/custom/psim.cfg: New (relocated from /make/custom).
* make/custom/mvme5500.cfg: New (relocated from /make/custom).
* make/custom/mvme3100.cfg: New (relocated from /make/custom).
* make/custom/mpc8260ads.cfg: New (relocated from /make/custom).
* make/custom/mpc5566evb.cfg: New (relocated from /make/custom).
* make/custom/mpc55xx.cfg: New (relocated from /make/custom).
* make/custom/mcp750.cfg: New (relocated from /make/custom).
* make/custom/mtx603e.cfg: New (relocated from /make/custom).
* make/custom/mvme2100.cfg: New (relocated from /make/custom).
* make/custom/mvme2307.cfg: New (relocated from /make/custom).
* make/custom/mbx821_001.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002b.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_001b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_005b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_1b.cfg: New (relocated from /make/custom).
* make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* make/custom/haleakala.cfg: New (relocated from /make/custom).
* make/custom/gen83xx.cfg: New (relocated from /make/custom).
* make/custom/gen5200.cfg: New (relocated from /make/custom).
* make/custom/ep1a.cfg: New (relocated from /make/custom).
* make/custom/virtex.cfg: New (relocated from /make/custom).
* make/custom/nios2_iss.cfg: New (relocated from /make/custom).
* make/custom/leon3.cfg: New (relocated from /make/custom).
* make/custom/leon2.cfg: New (relocated from /make/custom).
* make/custom/erc32.cfg: New (relocated from /make/custom).
* make/custom/sis.cfg: New (relocated from /make/custom).
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* make/custom/ts_386ex.cfg: New (relocated from /make/custom).
* make/custom/pc386.cfg: New (relocated from /make/custom).
* make/custom/pc386dx.cfg: New (relocated from /make/custom).
* make/custom/pc486.cfg: New (relocated from /make/custom).
* make/custom/pc586.cfg: New (relocated from /make/custom).
* make/custom/pc686.cfg: New (relocated from /make/custom).
* make/custom/i386ex.cfg: New (relocated from /make/custom).
* make/custom/simsh1.cfg: New (relocated from /make/custom).
* make/custom/simsh2.cfg: New (relocated from /make/custom).
* make/custom/simsh2e.cfg: New (relocated from /make/custom).
* make/custom/simsh4.cfg: New (relocated from /make/custom).
* make/custom/gensh4.cfg: New (relocated from /make/custom).
* make/custom/gensh2.cfg: New (relocated from /make/custom).
* make/custom/gensh1.cfg: New (relocated from /make/custom).
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/canonical-target-name.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4, aclocal/enable-posix.m4,
aclocal/rtems-cpu-subdirs.m4: Remove posix/unix.
* Makefile.am: Remove reference to timer_SOURCES.
* configure.ac: Rework make/custom/* handling.
* aclocal/check-custom-bsp.m4: Change *.cfg handling.
* Makefile.am: Remove make/custom/default.cfg-rule.
PR 1451/bsps
* network/tsec.c: Fix mbuf leak when watchdog expires. The
re-initialization algorithm failed to release mbuf chains
held in the TX ring.
Also, during initialization the initial link status is determined
and IFF_OACTIVE set if no active link was detected.
* bootcard: Update for heap API changes.
* include/bsp.h: BSP has plenty of memory.
* startup/cmain.c: Comment out prints.
* shared/bspgetworkarea.c: Add debug prints of memory information.
* shared/vmeUniverse/vmeUniverse.c: print message and
let vmeUniverseIntLoopbackTst() fail if odd-numbered
vector is used (cannot program the chip to reply with
such a vector).
paranthesis around usage of x in some macros
* libchip/ide/ata.c, c/src/libchip/ide/ata_internal.h: Remove the
multiblock support from the ATA driver. Multiblock at the disk
level should not be a global policy as a disk may have more than
one partition with different block sizes. An IDE driver could
decide to use the feature with DMA but this a driver specific
design choice. Fixed bugs relating to variable block sizes and
large block transfer.
* c/src/libchip/ide/ide_controller.c,
c/src/libchip/ide/ide_ctrl_cfg.h, c/src/libchip/ide/ide_ctrl_io.h:
Changed the block size to 32bits so blocks of 64K or bigger can be
transfered in a single driver call.
* ide/ide.c: Fixed more IDE driver bugs. The driver can transfer
64K in a single write on my test PC and qemu with this driver. The
driver only checks the data ready bit at the start of each 512
block being transfered. This has speed the transfer loop up. Fixed
the timing so the BSP timer is used until RTEMS has started.
