* | 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 3 | -4/+11 |
| | | | | | | * configure.ac: Pass CFLAGS to testsuites configure. * aclocal/prog-cxx.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS. Setup CXXFLAGS from CFLAGS. | ||||
* | 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 2 | -16/+10 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -47/+4 |
| | | | | * console/sci.c: Remove CVS Log. | ||||
* | Fix typo. | Ralf Corsepius | 2005-01-05 | 1 | -1/+3 |
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -0/+15 |
| | | | | * aclocal/rtems-flags.new: New (moved from ../aclocal). | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 7 | -75/+24 |
| | | | | | | | | | | | | | * configure.ac: Pass CFLAGS to cpukit configure. * aclocal/rtems-flags.m4: Remove (Unused). * aclocal/prog-ccas.m4: Remove $(GCCSPECS). * aclocal/env-rtemsbsp.m4: Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS. Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS. Cleanup comments. | ||||
* | Fix typo. | Ralf Corsepius | 2005-01-05 | 4 | -4/+9 |
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -2/+4 |
| | | | | * Makefile.am: Fix typo. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -2/+4 |
| | | | | * shared/Makefile.am: Fix typo. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 8 | -19/+28 |
| | | | | | | * at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c, mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h, shared/arm920/mmu.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -0/+6 |
| | | | | * ppc403/tty_drv/tty_drv.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 3 | -7/+15 |
| | | | | * ChangeLog, startup/bspstart.c, tod/todcfg.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 6 | -7/+17 |
| | | | | * startup/linkcmds: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -5/+14 |
| | | | | * console/config.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 3 | -5/+12 |
| | | | | * comm/gdb_glue.c, irq/idt.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 4 | -52/+31 |
| | | | | | * console/keyboard.c, console/ps2_mouse.c, console/vt.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -1/+8 |
| | | | | * console/sci.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -9/+14 |
| | | | | * console/leds.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -2/+6 |
| | | | | * console/console.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 3 | -2/+5 |
| | | | | * console/console-io.c, startup/init5272.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -4/+9 |
| | | | | * clock/clockdrv.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 3 | -1/+6 |
| | | | | * startup/bspstart.c, startup/exit.c: Remove warnings. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -0/+5 |
| | | | | * start/start.S: Remove warnings. | ||||
* | 2005-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-03 | 2 | -1/+5 |
* | 2005-01-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect psim-gdb having been added. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 28 | -709/+258 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 33 | -1056/+327 |
| | | | | * Makefile.am, wrapup/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 10 | -312/+108 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 48 | -1766/+576 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 4 | -136/+21 |
| | | | | | * sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -37/+10 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 8 | -357/+48 |
| | | | | | | * mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am, shared/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 5 | -95/+20 |
| | | | | | * mongoosev/Makefile.am, r46xx/Makefile.am, shared/Makefile.am, tx39/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 5 | -113/+24 |
| | | | | | * m68040/Makefile.am, mcf5206/Makefile.am, mcf5272/Makefile.am, shared/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -159/+129 |
| | | | | | * ChangeLog: Merge-in mcf5272/ChangeLog. * mcf5272/ChangeLog: Remove. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -33/+8 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 4 | -104/+20 |
| | | | | | * at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am: Remove build-variant support. | ||||
* | Remove (Unused). | Ralf Corsepius | 2005-01-02 | 7 | -98/+0 |
* | 2005-01-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 4 | -30/+34 |
| | | | | | | | * ChangeLog: Merge-in at91rm9200/ChangeLog, mc9328mxl/ChangeLog, shared/ChangeLog. * at91rm9200/ChangeLog, mc9328mxl/ChangeLog, shared/ChangeLog: Remove. | ||||
* | 2005-01-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -3/+5 |
| | | | | * console/leds.c: Fix prototype of led_putnum(). | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -20/+4 |
| | | | | * automake/compile.am: Remove build-variant support. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 4 | -41/+21 |
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 6 | -296/+98 |
| | | | | | | * libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am support/Makefile.am, wrapup/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2005-01-01 | 2 | -2/+5 |
| | | | | * configure.ac: Use AS_HELP_STRING instead of AC_HELP_STRING. | ||||
* | 2004-12-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-12-30 | 4 | -21/+49 |
| | | | | | * Makefile.am, psim: Split psim into two files. * psim-gdb: New file. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-12-30 | 2 | -12/+13 |
* | 2004-12-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-12-30 | 2 | -3/+5 |
| | | | | * acinclude.m4: Reflect eth_comm having been removed. | ||||
* | 2004-12-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-12-10 | 2 | -179/+5 |
| | | | | | PR 704/bsps. * ide_ctrl.c: Removed (obsolete). | ||||
* | Changelog, PR728 & PR729 | Greg Menke | 2004-12-06 | 1 | -241/+34 |
| | | | | Greg Menke 12/06/2004 | ||||
* | PR 729/bsps | Greg Menke | 2004-12-06 | 1 | -4/+9 |
| | | | | | | | * bootloader/pci.c: Removed the r->size=0 and r->base=0 assignement which makes too-large regions conflict with onboard hardware, replacing it with sfree which deletes the memory region from the setup code, leaving it disabled. |
