* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* shared/start/start.S: Export crt0 symbol because the debug.S uses
that.
* at91rm9200/clock/clock.c: Add support for nanoseconds since last
tick. The resolution is not that high but better than nothing.
* clock/rtc.c, clock/tod.h: Update for new RTC driver interface.
* tod.h, tod.c: Update for new RTC driver interface.
PR 1415/bsps
* startup/bspstart.c, startup/linkcmds: Enable caches and therefore
enable the mmu.
* start/start.S: Correct call to boot_card to meet bfin abi by
clearing l0 - l3 and allocating some stack space.
PR 1418/bsps
* mmu/mmu.c: enable mmu after initializing it.
* mmu/mmu.h: add missing mmu flags entries.
* include/mmuRegs.h: correct a couple field name typos.
* Makefile.am: Remove junk bsp_reset().
* startup/bspreset.c: Removed.
* console/console-io.c: Fix typo.
* startup/linkcmds: Correct name of ENTRY.
* bsppost.c: Fix typo.
* include/irq-generic.h, src/irq-generic.c: Documentation.
initialization tasks need them.
* libchip/network/i82586.c: Fix warning in manner suggested by
Arnout Vandecappelle <arnout@mind.be> in
http://www.rtems.org/pipermail/rtems-users/2009-May/005460.html.
* include/bsp.h: Defined as a small memory target. It cannot build
one of the sample programs any more.
* irq/BSP_irq.c: New file.
* irq/irq.c, network/if_1GHz/POSSIBLEBUG: Removed.
* include/bsp.h, start/start.S, startup/bspstart.c:
added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h.
removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined
by the linker script (shared/startup/linkcmds) for the initial
stack.
replaced __rtems_end+4096 with __stack in start.S
Removed legacy code in bspstart.c (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in
bspstart.c
* bootcard.c, bspgetworkarea.c, include/bootcard.h: Switch from ssize_t
to uintptr_t for bsp_get_work_area() since the work area is larger
than a single allocatable object.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* shared/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* shared/startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* startup/linkcmds: Correct to have 65K total RAM (mostly external) and
correct base address.
* bspinit.c: Fix warning by adding include file.
* libchip/network/if_dc.c: Fixed warnings.
* page.c: Fixed warnings.
* shared/comm/i386-stub-glue.c, shared/comm/uart.c, shared/irq/irq.c,
shared/pci/pcibios.c: Fixed warnings.
* console/console.c, console/inch.c, ide/ide.c: Fixed warnings.
PR 1409/bsps
* gdbstub/rtems-stub-glue.c: Print object names correctly.
* shared/start/start.S: Confirmed OK by mwalle.
* bootcard.c, gdbstub/rtems-stub-glue.c: Add info to not enough memory
message.
* shared/pci/pci.c: Removed warnings.
* mpc6xx/mmu/bat.c, new-exceptions/e500_raw_exc_init.c,
new-exceptions/raw_exception.h, new-exceptions/bspsupport/irq_supp.h,
shared/include/cpuIdent.c: Removed warnings. Split
bsp_irq_dispatch_list to allow non-standard/non-existant pics to call
with interrupts off.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* console/uart.c: Remove warning.
* shared/gdbstub/README, shared/gdbstub/gdb_if.h,
shared/gdbstub/lm32-debug.S, shared/gdbstub/lm32-stub.c: New files.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Checked call to boot_card.
* tod.c: Remove warnings and clean up.
* ndstool/include/banner.h, ndstool/include/header.h,
ndstool/include/ndstree.h, ndstool/source/banner.cpp,
ndstool/source/header.cpp, ndstool/source/ndscreate.cpp,
ndstool/source/ndstool.cpp, ndstool/source/passme.cpp: Remove
warnings for deprecated character conversions.
* libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c: Fix warnings. Reformat
as needed.
* shared/start.S: Checked and OK.
* libchip/ide/ata.c: Remove a detection test that fails in qemu.
* libchip/ide/ide_controller.c: Change the status detection and
add a message if the transfer fails. There is currently no error
handle at the IDE drvier level.
* Makefile.am: Add bspinit.c, a common Init task that manages
command line arguments from a BSP.
* startup/main.c: Update for boot_card command line change.
* shared/start/start.S: Update for boot_card command line change.
* bootcard.c, include/bootcard.h: Remove argc/argv/envp and
replace with a single BSP boot command line a BSP can optionally
support.
* start/start.S: Update for boot_card command line change.
* startup/start.S: Update for boot_card command line change.
