1997-04-15 | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 4 | -8/+20 | |
of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | |||||
1997-04-15 | Added directories to place test output screens into as part of fixing | Joel Sherrill | 1 | -3/+4 | |
difftest. | |||||
1997-04-15 | Added line to install test screens so difftest does not have to have | Joel Sherrill | 65 | -7/+137 | |
a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | |||||
1997-04-15 | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 20 | -19/+51 | |
returned an error to using a single shared copy of this file. | |||||
1997-04-15 | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 10 | -9/+48 | |
implementation as all m68k BSPs. | |||||
1997-04-11 | replaced linking of source from mvme147 drivers with use of vpath to | Joel Sherrill | 4 | -29/+8 | |
simply search into that directory and get the necessary files. | |||||
1997-04-11 | removed commented out line performing a link | Joel Sherrill | 2 | -2/+0 | |
1997-04-09 | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 4 | -5/+9 | |
tasks table. | |||||
1997-04-09 | new test | Joel Sherrill | 14 | -0/+862 | |
1997-04-09 | added cpuuse and rtmonuse | Joel Sherrill | 1 | -1/+1 | |
1997-04-09 | printing task names now instead of id numbers | Joel Sherrill | 2 | -6/+32 | |
1997-04-09 | new files. | Joel Sherrill | 16 | -0/+1234 | |
1997-04-09 | added rtmonuse and cpuuse directories | Joel Sherrill | 2 | -0/+4 | |
1997-04-09 | added cpuuse and rtmonuse directories | Joel Sherrill | 1 | -1/+1 | |
1997-04-09 | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 2 | -0/+16 | |
down. | |||||
1997-04-09 | correct incorrect register addresses for port a. | Joel Sherrill | 1 | -2/+2 | |
1997-04-09 | removed unused is_character_ready routine. | Joel Sherrill | 1 | -27/+0 | |
1997-04-09 | added support for tracking thread cpu usage. | Joel Sherrill | 1 | -0/+2 | |
1997-04-09 | enhanced printf statements | Joel Sherrill | 1 | -4/+4 | |
1997-04-09 | corrected spacing. | Joel Sherrill | 2 | -16/+16 | |
1997-04-09 | added SYSTEM_STATE_SHUTDOWN | Joel Sherrill | 2 | -0/+2 | |
1997-04-09 | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1 | -1/+4 | |
be made to shut the system down when it is down. | |||||
1997-04-09 | added support for statistics on rate monotonic periods. | Joel Sherrill | 3 | -15/+142 | |
1997-04-09 | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 37 | -133/+1030 | |
was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | |||||
1997-04-08 | added cast to eliminate warning. | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 7 | -72/+79 | |
warnings. | |||||
1997-04-07 | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1 | -2/+6 | |
1997-04-07 | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1 | -3/+10 | |
warnings. | |||||
1997-04-07 | changed signed int to unsigned int to eliminate a warning. | Joel Sherrill | 2 | -2/+2 | |
1997-04-07 | removed noreturn attribute to eliminate warnings. | Joel Sherrill | 5 | -10/+35 | |
1997-04-07 | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 4 | -12/+28 | |
1997-04-07 | added prototype and return statement to eliminate warnings. | Joel Sherrill | 1 | -0/+4 | |
main.c: added return statement to eliminate a warning. | |||||
1997-04-07 | removed reference to no_bsp. | Joel Sherrill | 2 | -8/+20 | |
added prototypes. | |||||
1997-04-07 | commented out sccs_id to eliminate warnings | Joel Sherrill | 2 | -8/+20 | |
1997-04-07 | added or fixed includes of page_table.h to eliminate warnings. | Joel Sherrill | 3 | -2/+5 | |
1997-04-07 | added cast to eliminate warning | Joel Sherrill | 3 | -4/+5 | |
1997-04-07 | added prototype for delay. | Joel Sherrill | 1 | -0/+1 | |
1997-04-07 | added global statement for start entry point | Joel Sherrill | 2 | -0/+2 | |
1997-04-07 | removed noreturn from prototype to avoid warnings. | Joel Sherrill | 6 | -6/+55 | |
1997-04-07 | added cast to eliminate warning. | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | added return statement to avoid warning. | Joel Sherrill | 1 | -0/+2 | |
1997-04-07 | added initialization of variable to eliminate warning. | Joel Sherrill | 2 | -2/+2 | |
1997-04-07 | added include of unistd.h to eliminate warning for no prototype for write(). | Joel Sherrill | 1 | -0/+1 | |
1997-04-07 | added ifdef around variables to eliminate warnings when cross | Joel Sherrill | 1 | -0/+2 | |
1997-04-07 | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 2 | -0/+4 | |
1997-04-07 | added volatile to Switch_necessary structure member to avoid warning. | Joel Sherrill | 1 | -2/+2 | |
1997-04-07 | added test to avoid spurious error | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | added prototype for missing routine. | Joel Sherrill | 1 | -0/+4 | |
1997-04-07 | added "return" to eliminate warning. | Joel Sherrill | 1 | -0/+2 | |
