* mpc505/timer/timer.c, mpc5xx/timer/timer.c,
mpc6xx/clock/c_clock.c, mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/cpm/cp.c, mpc8xx/cpm/dpram.c, mpc8xx/include/cpm.h,
mpc8xx/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c, rtems/powerpc/cache.h, shared/src/cache.c:
Convert to using c99 fixed size types.
* clock/ckinit.c, clock/clock.h, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/vectorexceptions.c, timer/timer.c,
tx39/include/tx3904.h: Convert to using c99 fixed size types.
* sh7032/clock/ckinit.c, sh7032/delay/delay.c,
sh7032/include/ispsh7032.h, sh7032/sci/sci.c,
sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/clock/ckinit.c,
sh7045/include/ispsh7045.h, sh7045/sci/sci.c,
sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c,
sh7045/timer/timer.c, sh7750/clock/ckinit.c,
sh7750/include/rtems/score/ispsh7750.h, sh7750/include/sh/sh4uart.h,
sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c,
sh7750/score/ispsh7750.c, sh7750/timer/timer.c: Convert to using c99
fixed size types.
* m68040/fpsp/rtems_fpsp.c, mcf5206/clock/ckinit.c,
mcf5206/console/mcfuart.c, mcf5206/include/mcf5206e.h,
mcf5206/include/mcfmbus.h, mcf5206/include/mcfuart.h,
mcf5206/mbus/mcfmbus.c, mcf5206/timer/timer.c: Convert to using c99
fixed size types.
* i960ca/cpu_install_intr_stack.c, i960ca/cpu_install_raw_isr.c,
i960ka/cpu_install_intr_stack.c, i960ka/cpu_install_raw_isr.c,
i960rp/cpu_install_intr_stack.c, i960rp/cpu_install_raw_isr.c:
* page.c: Convert to using c99 fixed size types.
* librdbg/Makefile.am: Fix rpcgen rules.
* librdbg/src/i386/any/remdeb_xdr.c,
librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c:
Reflect changes to librdbg/Makefile.am.
* configure.ac: Reflect changes testsuites/configure.ac and
cpukit/configure.ac.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c: Use asm constraint "i" instead of "I" to
pass sizeof(Context_Control) to context switch.
* aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP.
Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir.
* configure.ac: Reflect changes to testsuites's configuration.
* configure.ac: Add 2nd arg to RTEMS_TOP.
Unconditionally configure MP-directories.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Add DIST_SUBDIRS comprising MP-subdirs.
* samples/Makefile.am: Add DIST_SUBDIRS comprising MP-subdirs.
PR/589 rtems
* libchip/network/pci.h: Remove (Moved to cpukit).
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
support.
Minor formating clean up.
Add documentation to the header file.
* README: Add "mpc5xx (mpc565)", because Wilfried B. mentioned the
mpc5xx being used on mpc565.
* configure.ac: SIZE, NM, OBJCOPY.
* libchip/network/dec21140.c: Use __PPC__ instead of __PPC.
Cosmetics.
* aclocal/canonicalize-tools.m4: Revert Joel's 2004-03-04's patch.
There are no application level Makefiles in here.
PR 587/bsps
* shared/include/cpuIdent.h, shared/include/cpuIdent.c: Add defines
for MPC_5XX.
* Makefile.am, configure.ac: Reflect having added mpc5xx.
* mpc5xx/.cvsignore, mpc5xx/Makefile.am: New.
* mpc5xx/exceptions/asm_utils.S, mpc5xx/exceptions/raw_exception.c,
mpc5xx/exceptions/raw_exception.h, mpc5xx/ictrl/ictrl.c,
mpc5xx/ictrl/ictrl.h, mpc5xx/timer/timer.c: New (Submission from
Wilfried Busalski <w.busalski@lancier-monitoring.de>).
* aclocal/canonicalize-tools.m4: Add SIZE, NM, and OBJCOPY so
they can be used in application level makefiles.
* libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* libchipnetwork/open_eth.c: Remove warnings by conditionally
compiling this file only only those CPU families with supported
exception models.
* mpc6xx/mmu/pte121.c: Add missing ifdef DEBUG to remove warning for
unused static routine.
* bootloader/pci.c: Remove warnings by adding include <string.h>.
* irq/irq.c: Clean up includes to remove warnings.
* pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const
on struct _int_map.
* network/network.c: Remove warnings for unused routines left from
original code.
PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
* vectors/vectors.h, vectors/vectors_init.c: Undo previous change.
* irq/irq.h: Correct typo.
* Makefile.am: Correct typo.
* startup/linkcmds: Add more memory so tests can link. This is a
* Makefile.am: Cosmetics.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* bootloader/Makefile.am: Fix preinstall dir handling.
* bootloader/Makefile.am: Preinstall dirs.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Don't install *.rels. Reflect changes to bsp.am.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
