* startup/syscalls.c: Rename to avoid conflict with newlib.
* Makefile.am, preinstall.am: Fix typo.
* rtl8019/rtl8019.c: Fix typo.
* shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h,
shared/startup/idtmem.S, shared/startup/idttlb.S: New files.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S:
Removed.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
* startup/usc.S: New file.
* shared/irq/exception.S: rbtx4925, rbtx4938, and hurricane had very
similar versions of exception. Now all use shared/irq/exception.S
* configure.ac: rbtx4925, rbtx4938, and hurricane had very similar
* Makefile.am, configure.ac: rbtx4925, rbtx4938, and hurricane had very
* startup/exception.S: Removed.
* shared/irq/exception.S: New file.
* Makefile.am: rbtx4925 and rbtx4938 had copies of the same file with
only minor differences. Both now use shared/irq/exception.S
* startup/exception.S: Minor changes to make more similar to the shared
version.
* aclocal/bsp-alias.m4: Change quoting to work-round
http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* startup/linkcmds: Include basic linker command file and define only
board specific values. Define RAM and PROM limits only if not defined
by command line arguments.
* Makefile.am, preinstall.am: Reflect changes above.
* shared/startup/linkcmds.base: New file.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* include/bsp.h: Do not include <bsp/bsp_bsdnet_attach.h> if networkign
disabled.
* timer/timer.c: Now runs on 486 and below again. Reformatted.
* shared/start/start.S: Finish merging change.
* shared/start/start.S: Add support for qemu-system-lm32 shutdown
device.
PR 1506/bsps
* console/console.c: Removed.
* console/erc32_console.c: New file. Use shared console driver.
Make sure interrupt support works. PPPD confirmed on sis.
* startup/linkcmds: Wildcard on .data so C++ links.
* rtl8019/rtl8019.c: Fixed interrupt handler.
* at91rm9200/dbgu/dbgu.c, at91rm9200/usart/usart.c,
pxa255/ffuart/ffuart.c: Fixed warnings due to Termios API change.
* irq/irq_asm.S, irq/irq_init.c, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above. Added generic
interrupt support modules.
* irq/irq.h, irq/irq.c: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* start/start.S, startup/bspstart.c, clock/clockdrv.c,
console/console.c, timer/timer.c: Interrupt support changes.
* irq/bsp_irq_init.c: Removed file.
* Makefile.am, preinstall.am: Reflect change above. Added generic
* startup/bspstart.c, irq/bsp_irq_asm.S, clock/clockdrv.c,
network/network.c: Interrupt support changes.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* startup/bspstart.c, console/uart.c, network/network.c: Interrupt
support changes.
* startup/bspstart.c: Interrupt support changes.
* startup/bspstart.c, rtl8019/rtl8019.c: Interrupt support changes.
* console/uart.c: Fixed warnings.
* include/irq-config.h: Removed file.
* irq/irq.c: Removed superfluous parameter checks.
* make/custom/lpc24xx.inc: Use VFP floating point model.
* make/custom/nds.cfg, Makefile.am, dswifi/arm7/makefile: Use VFP
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
* shared/irq_init.c: Removed file.
* Makefile.am: Reflect change above.
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* Makefile.am, preinstall.am: Reflect change above. Added interrupt
support modules.
* include/mpc5200.h: Added GPIO PIN defines.
* libcpu/powerpc/mpc55xx/include/irq.h: Move defines from
'libbsp/powerpc/mpc55xxevb/include/irq-config.h'.
* libbsp/powerpc/mpc55xxevb/include/irq-config.h: Removed file.
* libbsp/powerpc/mpc55xxevb/Makefile.am,
libbsp/powerpc/mpc55xxevb/preinstall.am: Reflect changes above.
* Makefile.am, preinstall.am: Update for generic interrupt support
changes.
* shared/irq/irq-config.h: Removed file.
* shared/irq/irq.h: Moved defines from 'shared/irq/irq-config.h'.
