PR 782/rtems
* rtems.ads: Remove stray ';'.
* rtems.adb: Stub Task_Variable_Add, Task_Variable_Get,
Task_Variable_Delete.
* mptests/mp01/config.h, samples/base_mp/config.h,
samples/base_sp/config.h, samples/hello/config.h,
samples/ticker/config.h, sptests/sp01/config.h,
sptests/sp02/config.h, sptests/sp03/config.h, sptests/sp04/config.h,
sptests/sp05/config.h, sptests/sp06/config.h, sptests/sp07/config.h,
sptests/sp08/config.h, sptests/sp09/config.h, sptests/sp11/config.h,
sptests/sp12/config.h, sptests/sp13/config.h, sptests/sp14/config.h,
sptests/sp15/config.h, sptests/sp16/config.h, sptests/sp17/config.h,
sptests/sp19/config.h, sptests/sp20/config.h, sptests/sp21/config.h,
sptests/sp22/config.h, sptests/sp23/config.h, sptests/sp24/config.h,
sptests/sp25/config.h, tmtests/tm01/config.h, tmtests/tm02/config.h,
tmtests/tm03/config.h, tmtests/tm04/config.h, tmtests/tm05/config.h,
tmtests/tm06/config.h, tmtests/tm07/config.h, tmtests/tm08/config.h,
tmtests/tm09/config.h, tmtests/tm10/config.h, tmtests/tm11/config.h,
tmtests/tm12/config.h, tmtests/tm13/config.h, tmtests/tm14/config.h,
tmtests/tm15/config.h, tmtests/tm16/config.h, tmtests/tm17/config.h,
tmtests/tm18/config.h, tmtests/tm19/config.h, tmtests/tm20/config.h,
tmtests/tm21/config.h, tmtests/tm22/config.h, tmtests/tm23/config.h,
tmtests/tm24/config.h, tmtests/tm25/config.h, tmtests/tm28/config.h,
tmtests/tm29/config.h, tmtests/tmck/config.h,
tmtests/tmoverhd/config.h: Include <rtems/confdefs.h> instead of
<confdefs.h> (obsolete).
* configure.ac: fix evaluating --enable-ada.
* ada/Makefile.am: Use preinstall.am
* ada/preinstall.am: New.
* irq/irq.c, start/start.S: Removed warnings
* New BSP.
* console/config.c: New files.
* Add/remove files for the Update to new exception model.
* pci/no_host_bridge.c, vme/vmeconfig.c: New files.
* clock/clock.c: Removed.
* Add/move files for the Update to new exception model.
NOTE: These modifications have not been tested on hardware.
* irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c: New files.
* startup/FPGA.c: Removed.
* libchip/network/README.sonic: Rewritten to account for removal of
dmv177.
* configure.ac: Remove reference to dmv177.
* acinclude.m4: Remove dmv177 and ppcn_60x.
* dmv177/.cvsignore, dmv177/ChangeLog, dmv177/Makefile.am,
dmv177/QUIRKS, dmv177/README, dmv177/README.net, dmv177/STATUS,
dmv177/bsp_specs, dmv177/cable.doc, dmv177/configure.ac,
dmv177/times, dmv177/clock/clock.c, dmv177/console/conscfg.c,
dmv177/console/debugio.c, dmv177/include/.cvsignore,
dmv177/include/bsp.h, dmv177/include/dmv170.h, dmv177/include/tm27.h,
dmv177/scv64/scv64.c, dmv177/sonic/dmvsonic.c, dmv177/start/start.S,
dmv177/startup/bspclean.c, dmv177/startup/bspstart.c,
dmv177/startup/genpvec.c, dmv177/startup/linkcmds,
dmv177/startup/setvec.c, dmv177/startup/vmeintr.c,
dmv177/timer/timer.c, dmv177/tod/todcfg.c, ppcn_60x/.cvsignore,
ppcn_60x/ChangeLog, ppcn_60x/Makefile.am, ppcn_60x/README,
ppcn_60x/STATUS, ppcn_60x/bsp_specs, ppcn_60x/configure.ac,
ppcn_60x/clock/clock.c, ppcn_60x/console/config.c,
ppcn_60x/console/console.c, ppcn_60x/console/console.h,
ppcn_60x/console/debugio.c, ppcn_60x/console/i8042.c,
ppcn_60x/console/i8042_p.h, ppcn_60x/console/i8042vga.c,
ppcn_60x/console/i8042vga.h, ppcn_60x/console/ns16550cfg.c,
ppcn_60x/console/ns16550cfg.h, ppcn_60x/console/vga.c,
ppcn_60x/console/vga_p.h, ppcn_60x/console/z85c30cfg.c,
ppcn_60x/console/z85c30cfg.h, ppcn_60x/include/.cvsignore,
ppcn_60x/include/bsp.h, ppcn_60x/include/extisrdrv.h,
ppcn_60x/include/nvram.h, ppcn_60x/include/pci.h,
ppcn_60x/include/tm27.h, ppcn_60x/network/amd79c970.c,
ppcn_60x/network/amd79c970.h, ppcn_60x/nvram/ds1385.h,
ppcn_60x/nvram/mk48t18.h, ppcn_60x/nvram/nvram.c,
ppcn_60x/nvram/prepnvr.h, ppcn_60x/nvram/stk11c68.h,
ppcn_60x/pci/pci.c, ppcn_60x/start/start.S,
ppcn_60x/startup/bspclean.c, ppcn_60x/startup/bspstart.c,
ppcn_60x/startup/bsptrap.S, ppcn_60x/startup/genpvec.c,
ppcn_60x/startup/linkcmds, ppcn_60x/startup/rtems-ctor.cc,
ppcn_60x/startup/setvec.c, ppcn_60x/startup/spurious.c,
ppcn_60x/startup/swap.c, ppcn_60x/timer/timer.c, ppcn_60x/tod/cmos.h,
ppcn_60x/tod/tod.c, ppcn_60x/universe/universe.c,
ppcn_60x/vectors/README, ppcn_60x/vectors/align_h.S,
ppcn_60x/vectors/vectors.S: Removed.
PR 781/rtems_misc
* libchip/serial/ns16550_p.h: Fix baud rate calculation
* score603e/Makefile.am, score603e/configure.ac,
score603e/console/console.c, score603e/include/bsp.h,
score603e/include/gen2.h, score603e/include/tm27.h,
score603e/startup/bspstart.c: Update score603e to new exception model
* acinclude.m4: Initial release of ep1a bsp
* ep1a/Makefile.am, ep1a/bsp_specs, ep1a/configure.ac,
ep1a/console/alloc360.c, ep1a/console/console.c,
ep1a/console/console.h, ep1a/console/init68360.c,
ep1a/console/m68360.h, ep1a/console/mc68360_scc.c,
ep1a/console/ns16550cfg.c, ep1a/console/ns16550cfg.h,
ep1a/console/rsPMCQ1.c, ep1a/console/rsPMCQ1.h, ep1a/include/bsp.h,
ep1a/irq/irq.c, ep1a/irq/irq_init.c, ep1a/pci/no_host_bridge.c,
ep1a/start/start.S, ep1a/startup/bspstart.c, ep1a/startup/linkcmds,
ep1a/vme/vmeconfig.c: New files.
* mcf5206/include/mcfuart.h: Reformatted.
* s3c2400/clock/clockdrv.c: Eliminate warning.
* console/uart.h: Eliminate tabs.
* startup/bspstart.c: Eliminate warnings.
* clock/clock.c: Eliminate warning for duplicate definition of
PPC_Set_decrementer.
* startup/idtmem.S: Eliminate warnings and be more consistent with
other MIPS assembly.
* clock/clockdrv.c: Add include of rtems/bspIo.h.
* include/tm27.h: Delete TX3904 code and leave stub.
* network/network.c: Eliminate warnings.
* startup/bspclean.c: Add include of rtems/bspIo.h. Reformat.
* network/network.c: Change int to rtems_id to eliminate warning.
* startup/alloc360.c: Eliminate warnings.
* pci/pcibios.c: Reformatted.
* 3c509/3c509.c, wd8003/wd8003.c: Eliminate warnings.
* startup/bspstart.c: Add include rtems/bspIo.h to eliminate warning.
* network/network.c: Add include rtems/bspIo.h to eliminate warning.
PR 779/bsp
* clock/p_clock.c: Add parameter to powerpc exception handler routines
PR 779/bsp
* mpc5xx/console-generic/console-generic.c, mpc5xx/irq/irq.c,
mpc5xx/irq/irq.h, mpc5xx/irq/irq_init.c: Add parameter to powerpc
interrupt handler routines
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
powerpc: add parameter to new exception interrupt handlers
* libchip/serial/ns16550.c:
Fixed warnings generated in various powerpc configurations
* libchip/serial/ns16550.c: Modified
ISR to work with PPC new exception processing
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Added parameter
to irq handler
* clock/ckinit.c, console/console.c, console/ps2_mouse.c,
console/serial_mouse.c, timer/timer.c: Added parameter to irq handler
* network/network.c: Fix warnings.
* GT64260/GT64260TWSI.c, GT64260/GT64260TWSI.h, irq/GT64260Int.c,
network/GT64260eth.c, pci/pci.c, startup/bspclean.c,
startup/reboot.c: Fix warnings.
* clock/clock.c: Fix multiple defined warning
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc8260/console-generic/console-generic.c: add parameter to new
exception interrupt handlers in powerpc bsps
PR 779/bsp
* vmeUniverse/vmeUniverse.c: add parameter to new exception interrupt
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c: add parameter to new exception
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c, network/GT64260eth.c: add
parameter to new exception interrupt handlers in powerpc bsps
