* | Moved PowerPC cache management code to libcpu. Also compiled | Joel Sherrill | 2000-06-14 | 11 | -359/+55 |
| | | | | | | mpc8xx libcpu support for the first time and remove includes of bsp.h, references to BSP_Configuration, and Cpu_table. All of these can be obtained directly from RTEMS now. | ||||
* | Must now pull in cache management code from libcpu. | Joel Sherrill | 2000-06-14 | 4 | -2/+6 |
* | Removed alloc860.c and mmu.c from C_FILES since they are now in libcpu. | Joel Sherrill | 2000-06-14 | 1 | -2/+2 |
* | Do not build if networking disabled. | Joel Sherrill | 2000-06-14 | 1 | -0/+2 |
* | Removed building of libcpu.a. It is now the individual BSPs | Joel Sherrill | 2000-06-14 | 4 | -8/+14 |
| | | | | | responsibility to explicitly pick up the components they require. This makes it easier to override default implmentations. | ||||
* | Thread iterate not ready for submission -- removed. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Moved to include subdirectory. | Joel Sherrill | 2000-06-14 | 1 | -99/+0 |
* | New files containing cache manager functionality stripped from | Joel Sherrill | 2000-06-14 | 3 | -0/+220 |
| | | | | score/cpu/powerpc. | ||||
* | New file. | Joel Sherrill | 2000-06-14 | 2 | -0/+4 |
* | Functionality moved from directory above to accomodate building | Joel Sherrill | 2000-06-14 | 9 | -0/+1255 |
| | | | | shared source code. | ||||
* | Moved from score/cpu/PowerPC. | Joel Sherrill | 2000-06-14 | 8 | -1150/+4 |
* | Thread iterator and libgjc support submitted too early. | Joel Sherrill | 2000-06-14 | 25 | -2025/+10 |
* | Fix typo. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Added crude i960ka support. | Joel Sherrill | 2000-06-13 | 3 | -6/+38 |
* | Pickup console-polled.c from the libbsp/shared directory. | Joel Sherrill | 2000-06-13 | 1 | -0/+2 |
* | Removing clock and timer since this BSP does not currently | Joel Sherrill | 2000-06-13 | 1 | -2/+0 |
| | | | | have them. | ||||
* | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2000-06-13 | 2 | -7/+3 |
* | New file. | Joel Sherrill | 2000-06-13 | 1 | -0/+137 |
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 25 | -579/+605 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 6 | -0/+12 |
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 11 | -0/+33 |
* | Added .cvsignore files. | Joel Sherrill | 2000-06-13 | 2 | -0/+15 |
* | Accounted for 1 task used. | Joel Sherrill | 2000-06-13 | 1 | -0/+1 |
* | Removed unused directories from Makefile.am and warnings | Joel Sherrill | 2000-06-13 | 3 | -1/+17 |
| | | | | from cvs by adding .cvsignore files. | ||||
* | Temporary hack to compile. Need to probably address definition | Joel Sherrill | 2000-06-13 | 3 | -0/+3 |
| | | | | of all FIO constants and conflict with libnetworking code. | ||||
* | Temporary hack to compile. | Joel Sherrill | 2000-06-13 | 2 | -2/+0 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 43 | -7762/+0 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860. | ||||
* | Fixed so hppa1.1 compiles with only problems in simhppa BSP. | Joel Sherrill | 2000-06-12 | 3 | -6/+16 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 15 | -0/+1790 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | ||||
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 102 | -470/+12509 |
* | Ensure that when -msoft-float is specified for multilib builds, that | Joel Sherrill | 2000-06-12 | 1 | -1/+2 |
| | | | | | something indicates this. Eventually this needs to be merged into gcc. | ||||
* | Works on Solaris and Linux. | Joel Sherrill | 2000-06-12 | 1 | -8/+6 |
* | Removed references to printk as part of moving it to a more shareable | Joel Sherrill | 2000-06-12 | 6 | -171/+6 |
| | | | | location in libc. | ||||
* | Added printk as a generic, shared routine. | Joel Sherrill | 2000-06-12 | 7 | -3/+367 |
* | New file. This is a simple termios console driver which is sufficient | Joel Sherrill | 2000-06-12 | 1 | -0/+148 |
| | | | | to do polled IO on a single port with VERY little support code. | ||||
* | Added i960sim BSP which (ignoring the 3 instructions not supported | Joel Sherrill | 2000-06-12 | 18 | -0/+641 |
| | | | | by gdb 5.0's i960 simulator) is enough to run hello world. | ||||
* | Merge lossage. Apparently the DOS/UNIX CRLF issue got lost. | Joel Sherrill | 2000-06-12 | 1 | -1438/+1438 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1431 | -10240/+81752 |
* | New file. | Joel Sherrill | 2000-05-24 | 1 | -0/+0 |
* | New file added on 4.5 branch | Joel Sherrill | 2000-05-08 | 2 | -0/+0 |
* | New file added on 4.5 branch | Joel Sherrill | 2000-05-08 | 1 | -0/+0 |
* | Added on 4.5 branch. | Joel Sherrill | 2000-05-03 | 4 | -0/+0 |
* | Added on 4.5-branch | Joel Sherrill | 2000-05-01 | 8 | -0/+0 |
* | New files. | Joel Sherrill | 2000-04-29 | 4 | -0/+8 |
* | New files added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 28 | -0/+0 |
* | New files added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 156 | -0/+0 |
* | New directory added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 46 | -0/+0 |
* | New files added on 4.5 branch. | Joel Sherrill | 2000-04-28 | 4 | -0/+0 |
* | New file. | Joel Sherrill | 2000-04-13 | 1 | -0/+367 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 346 | -0/+1244 |
| | | | | adds .cvsignore. |
