* | bsps: Move wd80x3.h to libchip/wd80x3.h | Sebastian Huber | 2018-01-22 | 9 | -19/+7 |
| | | | | | | This header is used also by the motorola_powerpc BSP. Update #3254. | ||||
* | bsp/gen5200: Fix i2c.h and i2cdrv.h installation | Sebastian Huber | 2018-01-19 | 8 | -17/+8 |
| | | | | | | Install these files only as <bsp/i2c.h> and <bsp/i2cdrv.h>. Update #3254. | ||||
* | bsp/leon3: Fix interrupt timestamp timecounter | Sebastian Huber | 2018-01-18 | 1 | -1/+8 |
* | leon3: Simplify bsp_specs | Joel Sherrill | 2018-01-18 | 1 | -4/+0 |
| | | | | Updates #3520. | ||||
* | leon2: Simplify bsp_specs | Joel Sherrill | 2018-01-18 | 1 | -4/+0 |
* | sparc/erc32: Simplify bsp_specs | Joel Sherrill | 2018-01-18 | 1 | -4/+0 |
* | qemuppc: Simplify bsp_specs | Joel Sherrill | 2018-01-18 | 1 | -4/+0 |
* | bsps/powerpc: Move BSP specific file to BSP | Sebastian Huber | 2018-01-16 | 4 | -4/+3 |
* | bsps/arm: Add header guard, fix defines | Chris Johns | 2018-01-15 | 1 | -2/+5 |
* | bsps/m68k: Fix CACR register defines | Sebastian Huber | 2018-01-15 | 1 | -4/+1 |
* | bsps: Fix redefine warning | Chris Johns | 2018-01-15 | 1 | -0/+1 |
* | bsp/mvme167: Fix warnings | Sebastian Huber | 2018-01-15 | 1 | -17/+17 |
* | bsps: Add AM_CPPFLAGS to special case CPPFLAGS | Sebastian Huber | 2018-01-15 | 1 | -2/+2 |
| | | | | | | | This is necessary to pick up mandatory flags provided by the build system. Update #3254. | ||||
* | libchip: Use public include path | Sebastian Huber | 2018-01-15 | 1 | -1/+1 |
* | bsps/lm32: Do not include network headers in bsp.h | Sebastian Huber | 2018-01-15 | 2 | -5/+2 |
* | bsp/gen5200: Fix linker command file | Sebastian Huber | 2018-01-05 | 1 | -0/+1 |
* | bsps/m68k: Install shared <mvme16x_hw.h> | Sebastian Huber | 2018-01-04 | 6 | -13/+10 |
* | bsps/mips: Fix AC_CONFIG_SRCDIR() | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsps/i386: Fix AC_CONFIG_SRCDIR() | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsp/edb7312: Use public include path | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsps: Use public include path | Chris Johns | 2018-01-04 | 2 | -4/+4 |
* | bsps/powerpc: Use public include path | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsp/mvme3100: Use public include path | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsp/beatnik: Use public include path | Chris Johns | 2018-01-04 | 1 | -1/+1 |
* | bsps/bfin: Use public include path | Chris Johns | 2018-01-04 | 7 | -7/+7 |
* | bsps/powerpc: Use public include path | Chris Johns | 2018-01-04 | 22 | -75/+13 |
* | bsp/mcf548x: Use public include path | Chris Johns | 2018-01-04 | 3 | -6/+6 |
* | libchip: Use public include path | Chris Johns | 2018-01-04 | 8 | -11/+10 |
* | bsp/gen5200: Use public include path | Chris Johns | 2018-01-04 | 31 | -68/+54 |
* | bsps/lm32: Use public include path | Chris Johns | 2018-01-04 | 13 | -13/+13 |
* | bsp/pc386: Use public include path | Chris Johns | 2018-01-04 | 6 | -6/+6 |
* | bsp/altera-cyclone-v: Use public include path | Chris Johns | 2018-01-04 | 14 | -61/+61 |
* | bsps: Add AM_CPPFLAGS to special case CPPFLAGS | Chris Johns | 2018-01-04 | 18 | -18/+18 |
* | bsp/pc386: Do not install console_private.h | Sebastian Huber | 2018-01-04 | 3 | -6/+1 |
| | | | | | | The name suggests that this is a private implementation header file. Update #3254. | ||||
* | bsps/powerpc: Remove unused RTEMS_CPU_MODEL | Sebastian Huber | 2018-01-03 | 1 | -17/+3 |
* | bsps/powerpc: Rename BSP specific linkcmds.base | Sebastian Huber | 2018-01-03 | 13 | -15/+15 |
| | | | | | | Avoid name conflicts with shared linkcmds.base. Update #3254. | ||||
* | bsps/powerpc: Move shared irq.h | Sebastian Huber | 2018-01-03 | 4 | -5/+4 |
| | | | | | | | This header file is only used by motorola_powerpc, so not shared. Update #3254. Update #3268. | ||||
* | sparc: Remove BSP specifics from <pci/irq.h> | Sebastian Huber | 2018-01-02 | 3 | -21/+0 |
| | | | | | | Update #3254. Update #3260. Update #3269. | ||||
* | sparc: Move <libcpu/byteorder.h> | Sebastian Huber | 2018-01-02 | 3 | -71/+0 |
| | | | | | Update #3254. Update #3260. | ||||
* | bsp/mpc55xxevb: Move <bsp/irq.h> | Sebastian Huber | 2018-01-02 | 5 | -11/+5 |
* | bsps: Use CPPASCOMPILE for startfile | Sebastian Huber | 2018-01-02 | 78 | -293/+362 |
* | bsps: Add EXTRA_DIST to all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 83 | -45/+123 |
| | | | | | | | | | | This makes it possible to easily use EXTRA_DIST += foobar in fragments. Update #3254. | ||||
* | bsps: Include bsp.am in all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 73 | -0/+73 |
* | beatnik, motorola_powerpc, mvme3100, mvme5500: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 17 | -31/+53 |
| | | | | | | | | | This collection of BSPs shared the linker script shared/startup/linkcmds. I renamed that ot shared/startup/linkcmds.share and made a BSP family specific startup/linkcmds. This was needed because each BSP family had a different combination of start file name, undefined symbols, etc. Updates #3520. | ||||
* | qemuppc: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -2/+4 |
* | haleakala: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 |
* | mpc8260ads: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 |
* | ss555: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+2 |
* | virtex4: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -7/+3 |
* | virtex5: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -7/+3 |
| | | | | Updates #3520. |
