* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 63 | -246/+686 |
| | | | | partially recovered working tree, etc | ||||
* | initial history lost in disk crash | Joel Sherrill | 1995-12-19 | 2 | -0/+386 |
* | changes remerged after disk crash -- history lost | Joel Sherrill | 1995-12-19 | 17 | -345/+18 |
* | file lost in crash and re-added | Joel Sherrill | 1995-12-19 | 9 | -0/+1479 |
* | file lost in crash and readded | Joel Sherrill | 1995-12-19 | 1 | -0/+195 |
* | changed version | Joel Sherrill | 1995-12-08 | 2 | -2/+2 |
* | file added | Joel Sherrill | 1995-12-08 | 1 | -0/+56 |
* | updated for snapshot 3.5.02 | Joel Sherrill | 1995-12-08 | 1 | -163/+163 |
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 6 | -5/+6 |
* | updated for 3.5.02 snapshot | Joel Sherrill | 1995-12-08 | 1 | -0/+4 |
* | updated to include HW information | Joel Sherrill | 1995-12-07 | 1 | -1/+2 |
* | the bss start and end symbols were changed | Joel Sherrill | 1995-12-07 | 1 | -3/+3 |
* | updated to reflect HW information | Joel Sherrill | 1995-12-07 | 2 | -2/+4 |
* | updated to reflect HW information and have correct timing information for | Joel Sherrill | 1995-12-07 | 2 | -329/+334 |
| | | | | a pre-release snapshot for 3.5.1 | ||||
* | created | Joel Sherrill | 1995-12-06 | 7 | -0/+972 |
* | Added comments for addition of is_fp flag to _CPU_Context_Initialize. | Joel Sherrill | 1995-12-05 | 1 | -0/+5 |
* | update from Andy Bray <andy@i-cubed.co.uk> | Joel Sherrill | 1995-12-05 | 7 | -194/+139 |
* | bug fix in statistics from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1995-12-05 | 2 | -2/+6 |
* | minor changes so it would compile in a cross environment | Joel Sherrill | 1995-12-05 | 1 | -0/+2 |
* | minor changes so it would compile | Joel Sherrill | 1995-12-05 | 4 | -14/+12 |
* | new states added and _Rate_monotonic_Set_State removed. | Joel Sherrill | 1995-12-05 | 3 | -111/+67 |
* | Insert mode argument to _Watchdog_Insert removed. Now are watchdog timers | Joel Sherrill | 1995-12-01 | 16 | -110/+45 |
| | | | | are automatically activated upon insertion. | ||||
* | Added new synchronization algorithm. | Joel Sherrill | 1995-12-01 | 1 | -58/+92 |
* | Added support for new synchronization algorithm. Specifically, the routine | Joel Sherrill | 1995-12-01 | 2 | -0/+28 |
| | | | | _Thread_queue_Enter_critical_section was added. | ||||
* | Added support for new synchronization algorithm. | Joel Sherrill | 1995-12-01 | 2 | -0/+50 |
* | Changed code for exit from synchronization state to a switch on the | Joel Sherrill | 1995-12-01 | 1 | -11/+19 |
| | | | | | possible synchronization actions. This should have made it harder to avoid a case. | ||||
* | spurious blank line removed | Joel Sherrill | 1995-12-01 | 2 | -2/+0 |
* | Replaced critical section algorithm to correct race conditions. | Joel Sherrill | 1995-12-01 | 1 | -10/+19 |
* | Made _Event_Sync volatile | Joel Sherrill | 1995-12-01 | 2 | -4/+30 |
| | | | | | | Replaced critical section algorithm to correct race conditions. This resulted in the new variable _Event_Sync_state and the type _Event_Sync_states. | ||||
* | Corrected use of the state WATCHDOG_REINSERT and renamed it | Joel Sherrill | 1995-12-01 | 3 | -14/+27 |
| | | | | WATCHDOG_BEING_INSERTED. | ||||
* | typos fixed | Joel Sherrill | 1995-10-31 | 18 | -43/+428 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 83 | -1175/+3448 |
* | reordered test cases from simple to complex | Joel Sherrill | 1995-10-11 | 1 | -13/+25 |
* | fixed null pointer dereference | Joel Sherrill | 1995-10-06 | 1 | -2/+2 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 93 | -18/+147 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 15 | -3/+1888 |
* | moved to new development machine and went to gcc 2.7.0 | Joel Sherrill | 1995-10-06 | 11 | -5/+22 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 52 | -234/+446 |
* | new programs added | Joel Sherrill | 1995-09-27 | 3 | -1/+276 |
* | updated | Joel Sherrill | 1995-09-27 | 1 | -13/+8 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 26 | -305/+535 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | Fixed typo | Joel Sherrill | 1995-09-27 | 2 | -4/+4 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 321 | -782/+13417 |
* | fixed Id strings | Joel Sherrill | 1995-09-26 | 6 | -3/+12 |
* | new file | Joel Sherrill | 1995-09-26 | 1 | -0/+436 |
* | Removed unnecessary include files. | Joel Sherrill | 1995-09-22 | 1 | -1/+1 |
* | Removed unneeded referenced to rtems/fatal.h | Joel Sherrill | 1995-09-22 | 6 | -6/+0 |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 6 | -10/+13 |
* | More file movement required api extension to be added to score | Joel Sherrill | 1995-09-21 | 5 | -5/+264 |
* | More file movement | Joel Sherrill | 1995-09-21 | 4 | -4/+4 |
