path: root/c (follow)
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1612-164/+101
| | | | | | | | | | | | | | * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/posix/Makefile.am: Remove. * include/Makefile.am: Handle subdirs. * inline/rtems/Makefile.am: Remove. * inline/rtems/posix/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs. * macros/rtems/Makefile.am: Remove. * macros/rtems/posix/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs. * configure.ac: Reflect changes above.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1612-156/+96
| | | | | | | | | | | | | | * include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above.
* 2001-10-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-152-0/+6
| | | | * console/.cvsignore: New file.
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-151-0/+179
| | | | | | | | | | | | | | | | * include/sh4uart.h: move to include/sh/sh4uart.h. * include/ispsh7750.h: move to include/rtems/score/ispsh7750.h. * include/iosh7750.h: move include/rtems/score/iosh7750.h. * include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h. * include/rtems/score/ipl.h: move to include/rtems/score/ipl.h. * include/rtems/score/sh4_regs.h: Reintroduce from Alexandra Kossovsky's original sources. * include/Makefile.am: reflect changes above, remove EXTRA_DIST, require automake 1.5. * sci/Makefile.am: Disable compilation of console.c. * sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S, remove SH4_CPU_HZ_Frequency; * score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-157-7/+32
| | | | | | | | | | * configure.ac: Added support for START_HW_INIT. * console/Makefile.am: Removed VPATH. * include/Makefile.am: Added missing ramdisk.h to include_HEADERS. * startup/linkcmds: Do not force output format to coff-sh. * startup/linkcmds-le: Comment out force of output format and add comment questioning need to have special linkcmds for little endian. * wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-152-0/+5
| | | | * configure.ac: Add sh7750.
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-152-0/+8
| | | | * acinclude.m4: Add gensh4 and simsh4.
* 2001-10-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1511-9/+554
| | | | | | | | | | | | | | | * configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add START_HW_INIT-support macros, add console/Makefile. * Makefile.am: Add console SUBDIR. * hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ. * include/Makefile.am: Add bspopts.h. * include/bsp.h: Comment out SH4_CPU_HZ_Frequency. * startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency. * startup/linkcmds: Comment out OUTPUT_FORMAT for coff compatibility. * wrapup/Makefile.am: Add console to BSP_PIECES. * console/Makefile.am: New. * console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1511-205/+99
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-152-1/+6
| | | | * cpu.c: Fix #ifdefs, add missing #endif.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-122-1/+4
| | | | * start/start.S: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-123-2/+4
| | | | * clock/p_clock.c, startup/bspstart.c: Fixed typo.
| | | | * include/chain.h: Fixed typo.
| | | | * console/inch.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-1/+0
| | | | | | * startup/linkcmds: Fixed typo. * comm/gdb_glue.c:
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-0/+5
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-125-4/+5
| | | | | * debug_ada/init.c, network_ada/listener/init.c, network_ada/tcprelay/init.c, ts_1325_ada/init.c: Fixed typo.
| | | | * console/console-io.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-129-8/+6
| | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-125-5/+0
| | | | | * clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c, startup/vmeintr.c: Fixed typo.
| | | | * clock/p_clock.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-128-7/+6
| | | | | | * clock/p_clock.c, include/bsp.h, include/coverhd.h, startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c, startup/start.S: Fixed typo.
| | | | * shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1214-13/+8
| | | | | | | | * clock/clock.c, console/console.c, console/debugio.c, console/ns16550cfg.c, console/ns16550cfg.h, console/z85c30cfg.c, console/z85c30cfg.h, include/bsp.h, startup/bspstart.c, startup/genpvec.c, startup/rtems-ctor.cc, startup/setvec.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1219-18/+9
| | | | | | | | | * PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c, console/consolebsp.h, console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h, include/gen2.h, startup/82378zb.c, startup/FPGA.c, startup/bspstart.c, startup/genpvec.c, startup/setvec.c, startup/vmeintr.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+5
| | | | | * include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/linkcmds: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1210-9/+6
| | | | | | * include/bsp.h, start/start.S, start/start.ram, start/start.rom, startup/bspclean.c, startup/bspstart.c, startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
| | | | * console.c, setvec.c: Fixed typo.
| | | | * console-polled.c, console.c: Fixed typo.
| | | | | * clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h, startup/setvec.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1223-22/+9
| | | | | | | | | * mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c, mpc8xx/timer/timer.c, new_exception_processing/cpu.c, new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S, old_exception_processing/cpu.c, old_exception_processing/cpu.h, old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+4
| | | | * rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+6
| | | | | | * unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: Fixed typo.
| | | | * serial/z85c30.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1212-11/+6
| | | | | | | * clock/ckinit.c, delay/delay.c, include/iosh7032.h, include/ispsh7032.h, include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1211-10/+6
| | | | | | * clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h, include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-129-9/+0
| | | | | | * clock/ckinit.c, include/iosh7750.h, include/ipl.h, include/ispsh7750.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c, score/ispsh7750.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-124-2/+8
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-122-1/+3
| | | | * console/console.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-124-3/+4
| | | | * shared/ppctypes.h: Fixed typo.
| | | | * include/rtems/directives.h: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-12120-9/+4809
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-122-0/+69
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-123-54/+6
| | | | | | * include/sh4_regs.h: Deleted and contents merged in score/cpu to avoid dependencies. * include/Makefile.am: Reflects above.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-129-25/+59
| | | | | | * asm.h, cpu.c, rtems.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h, rtems/score/shtypes.h: Consistency changes and made sure there were no includes from the libcpu tree.
* 2001-10-12 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-124-16/+146
| | | | | | * cpu.c, rtems/score/cpu.h, rtems/score/sh.h: Modified to support SH4. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de> who did the original SH port.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-122-2/+8
| | | | | | * cpu_asm.S: _CPU_Context_save_fp in was incorrectly in conditional compilation block with (CPU_HARDWARE_FP == FALSE). Reported by Wayne Bullaughey <wayne@wmi.com>.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-12115-4561/+0
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-1/+22
| | | | | | | * configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ. * startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ. * include/.cvsignore: Add stamp-h* bspopts.h* * include/bsp.h: Add bspopts.h.
