path: root/c (unfollow)
2018-04-23bsps: Move PCI drivers to bspsSebastian Huber21-4349/+19
This patch is a part of the BSP source reorganization. Update #3285.
2018-04-23bsps/sh: Move console.c to bspsSebastian Huber3-125/+2
2018-04-23bsps/sh: Move setvec.c to bspsSebastian Huber1-55/+0
2018-04-23bsps/sh: Move bsphwinit.c to bspsSebastian Huber5-22/+4
2018-04-23bsps: Move GDB stubs to bspsSebastian Huber11-5381/+0
2018-04-23bsps/v850: Move crt1.c to bspsSebastian Huber2-26/+1
2018-04-23bsps/sparc64: Move helenos to bspsSebastian Huber13-2316/+16
2018-04-23bsps: Move RTC drivers to bspsSebastian Huber29-2341/+15
2018-04-23bsps: Move legacy network drivers to bspsSebastian Huber116-83020/+51
2018-04-23bsps: Move interrupt controller support to bspsSebastian Huber116-13267/+95
2018-04-23bsps: Move SPI drivers to bspsSebastian Huber14-4224/+7
2018-04-23bsps: Move I2C drivers to bspsSebastian Huber38-6469/+22
2018-04-23bsps/arm: Remove unused stm32f* filesSebastian Huber311-416553/+0
2018-04-23bsp/tms570: Move more start to bspsSebastian Huber16-3510/+15
2018-04-23bsp/gen5200: Move bestcomm to bspsSebastian Huber23-3600/+22
2018-04-23bsp/atsam: Move libraries to bspsSebastian Huber79-21900/+52
2018-04-23bsp/altera-cyclone-v: Move hwlib to bspsSebastian Huber12-19191/+10
2018-04-23bsps: Move make/custom/* files to bspsSebastian Huber269-3652/+12
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-23bsps: Remove AC_CONFIG_SRCDIR()Sebastian Huber103-103/+0
This AC_CONFIG_SRCDIR() is just a sanity check in this insane build system. Since all content of c/src/lib/libbsp/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@ is bound to be moved it makes no sense to keep it. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps/mvme147s: Fix Makefile.amSebastian Huber1-3/+3
2018-04-20bsps/leon3: Move AMBA support to bspsSebastian Huber2-167/+1
2018-04-20bsps/leon2: Move PCI driver to bspsSebastian Huber2-657/+1
2018-04-20bsps/sparc: Move gnatsupp to bspsSebastian Huber6-87/+3
2018-04-20bsps: Move MPCI support to bspsSebastian Huber27-1588/+20
2018-04-20bsps/sparc: Move network drivers to bspsSebastian Huber9-484/+6
2018-04-20bsps/sparc: Move shared files to bspsSebastian Huber74-50188/+131
2018-04-20sparc: Move irq_asm.SSebastian Huber4-910/+0
This file is BSP-independent. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20sparc: Move _CPU_Trap_slot_templateSebastian Huber4-39/+0
The definition of _CPU_Trap_slot_template is BSP-independent. A potential para-virtualization support may use <rtems/score/paravirt.h>. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move benchmark timer to bspsSebastian Huber86-5754/+49
2018-04-20bsps: Move startup files to bspsSebastian Huber651-51862/+556
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move start files to bspsSebastian Huber152-17423/+112
2018-04-20bsps: Move console drivers to bspsSebastian Huber236-48044/+194
2018-04-20bsps/powerpc: Move shared btimer supportSebastian Huber16-16/+16
2018-04-20bsps: Move clock drivers to bspsSebastian Huber139-8097/+95
2018-04-20bsps: Move bspsmpgetcurrentprocessor.c to bspsSebastian Huber3-17/+2
2018-04-20bsps: Move bspsmp.c to bspsSebastian Huber4-38/+3
2018-04-20bsps: Move setvec.c to bspsSebastian Huber21-64/+21
2018-04-20bsps: Move sbrk.c to bspsSebastian Huber78-106/+78
2018-04-20bsps: Move shared CPU counter support to bspsSebastian Huber21-80/+30
2018-04-20bsps: Move getentropy-cpucounter.c to bspsSebastian Huber83-151/+82
2018-04-20bsps: Move gpio.c to bspsSebastian Huber3-1982/+2
2018-04-20bsps: Move shared btimer support to bspsSebastian Huber19-82/+17
2018-04-20bsps: Remove unused irq.h template fileSebastian Huber1-77/+0
2018-04-20bsps: Remove unused rtems-stub-glue.cSebastian Huber1-1341/+0
2018-04-20bsps: Move pci_find_device.c to bspsSebastian Huber4-277/+3
2018-04-20bsps: Move pci_bus_count.c to bspsSebastian Huber2-69/+1
2018-04-20bsps: Move doxygen.h files to bspsSebastian Huber13-195/+0
2018-04-20bsps: Convert all bsp_predriver_hook()Sebastian Huber96-423/+203
Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
2018-04-20bsp/motorola_powerpc: Move bspstart.c to bspsSebastian Huber2-377/+1
This shared powerpc file was only used by this BSP. This patch is a part of the BSP source reorganization. Update #3285.
2018-04-20bsps: Move bspgetworkarea.c to bspsSebastian Huber70-131/+69
