Made Alteras hwlib compile clean within the RTEMS build system
Add files from Alteras hwlib
Implemented so far:
- nocache heap for uncached RAM
- basic timer
- level 1 cache handling for arm cache controller
in arm-cache-l1.h
- level 2 L2C-310 cache controller
- MMU
- DWMAC 1000 ethernet controller
- basic errata handling
- smp startup for second core
arm-l2c-310/cache_.h contains the handling for the L2C-310
level 2 cache controller from arm. It references the arm
level 1 cache handling in the new file arm-cache-l1.h.
Use _PPC_INTERRUPT_DISABLE_MASK introduced with
801b5d80325dbd3e92218271d54e75f389da7136.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133.
In order to support profiling of SMP locks and provide a future
compatible SMP locks API it is necessary to add an SMP lock destroy
function. Since the commit above adds an SMP lock to each chain control
we would have to add a rtems_chain_destroy() function as well. This
complicates the chain usage dramatically. Thus revert the patch above.
A global SMP lock for all chains is used to implement the protected
chain operations.
Advantages:
* The SAPI chain API is now identical on SMP and non-SMP
configurations.
* The size of the chain control is reduced and is then equal to the
Score chains.
* The protected chain operations work correctly on SMP.
Disadvantage:
* Applications using many different chains and the protected operations
may notice lock contention.
The chain control size drop is a huge benefit (SAPI chain controls are
66% larger than the Score chain controls). The only disadvantage is not
really a problem since these applications can use specific interrupt
locks and unprotected chain operations to avoid this issue.
Use the interrupt controller timestamping counter for the CPU counter if
available since it runs with a high frequency.
A new option RTEMS_INTERRUPT_REPLACE is introduced that permits updating
the first interrupt handler for the registered interrupt vector and
matching argument. If no match is found, the install function fails
with RTEMS_UNSATISFIED.
The Interrupt Manager Extension offers interrupt handlers with an
argument pointer. It is impossible to update two words (handler and
argument) atomically on most architectures. In order to avoid an SMP
lock in bsp_interrupt_handler_dispatch() which would degrade the
interrupt response time an alternative must be provided that makes it
possible to tear-down interrupt sources without an SMP lock.
Add RTEMS_INTERRUPT_REPLACE option to Interrupt Manager Extension. This
enables a clean tear-down of interrupt sources on SMP configurations.
Instead of an interrupt handler removal a replacement handler can be
installed to silence an interrupt source. This can be used in contexts
that allow no sophisticated synchronization (e.g. in atexit() or fatal
handlers).
The previous implementation used an instruction cache line size of 0,
this is a bogus value. Use a instruction cache line size of 64 since
the L2 cache may have a line size of 32 or 64. A greater value should
cause no harm.
Use a FLUSH operation for _CPU_cache_invalidate_instruction_range().
This is a preperation step to support the L2 cache.
Add rtems_cache_get_data_cache_size() and
rtems_cache_get_instruction_cache_size().
A cache line cannot have a negative size.
The vector number of spurious interrupts was wrong after the interrupt
handler removal on SMP configurations.
The SPARC processors supported by RTEMS have no built-in CPU counter
support. We have to use some hardware counter module for this purpose.
The BSP must provide a 32-bit register which contains the current CPU
counter value and a function for the difference calculation. It can use
for example the GPTIMER instance used for the clock driver.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
The 32-bit ABIs for thread-local storage (TLS) and EABI read-only
small-data area have a conflicting register (r2) usage. Use the System
V small-data instead (here r2 is system reserved).
Disabling of interrupts is not enough to ensure mutual exclusion on SMP
configurations.
