* network/README.3com: New file missed in previous commit.
PR 405/bsps
PR 393/networking
* network/dec21140.c: Fix leak also known as PR393.
* network/elnk.c, network/if_media.h, network/mii.h: New files.
* network/Makefile.am: Reflect new files.
PR 405/bsps
PR 393/networking
PR 405/bsps
* bootloader/pci.c: Added support for configuring devices for pci
busses > 0
* pci/pci.c, pci/pci.h: Added FixupPCI() to store vectors in the
INTERRUPT_LINE register of pci devices any # of hops away
from the host processor.
* motorola/motorola.c, motorola/motorola.h: Added interrupt
routing tables in support of FixupPCI. This is board-specific,
each board will have to supply information for FixupPCI() to do
anything for it.
* startup/bspstart.c: Extended bat2 to cover entire PCI address space.
* irq/irq.c, irq/irq.h: Added support for shared interrupts.
Existing single hander vectors are undisturbed, a new function
added to allow adding/removing handlers from a vector.
PR 415/bsps
* include/bsp.h, pci/detect_raven_bridge.c, startup/bspstart.c:
Support enabling MCP exceptions on the host bridge. This can
be used for memory probing on the VME bus.
* pppd/chat.c: Removed warnings.
* console/console.c, startup/linkcmds: Removed warnings.
* startup/linkcmds: Removed warnings.
* psxchroot01/test.c, psxreaddir/test.c: Removed warnings.
* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
* configure.ac: Remove support for profile-variant.
* pppd/system.h: Hack from Ralf to compile on all targets.
* psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c,
psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c,
psxtimer/psxtimer.c: Removed warnings.
* sp27/init.c, sp29/init.c, spsize/size.c: Removed warnings.
* pppd/fsm.c: Make peer_mru global again.
* configure.ac: Remove CC_CFLAGS_DEBUG_V.
CC_CFLAGS_DEFAULT (obsolete).
* configure.ac: Remove CC_CFLAGS_PROFILE_V.
Remove CC_LDFLAGS_PROFILE_V.
* pppd/magic.c: Remove *rand48.
* pppd/chap.c: Remove prototypes of *rand48.
Added how to boot over the network with a PXE Netboot BIOS.
* configure.ac: Add pppd.
* Makefile.am: Add pppd.
Adding pppd:
* pppd/Makefile-user: New, copied over from libnetworking/pppd/example.
* pppd/README: New, copied over from libnetworking/pppd/example.
* pppd/init.c: New, copied over from libnetworking/pppd/example.
* pppd/netconfig.h: New, copied over from libnetworking/pppd/example.
* pppd/ppp.conf: New, copied over from libnetworking/pppd/example.
* pppd/pppdapp.c: New, copied over from libnetworking/pppd/example.
* pppd/system.h: New, copied over from libnetworking/pppd/example.
* pppd/pppd.options: New, copied over from libnetworking/pppd/example.
* pppd/Makefile.am: New, converted to automake from Makefile-user.
* pppd/.cvsignore: New.
PR 387/rtems_misc
* ide/ata.c: Removed warning and moved to use of simpler libc routines.
* ide/ata_internal.h: Added missing newline and end of file.
PR 386/bsps
* vme/vmeconfig.c: Removed declaration of _BSP_vme_bridge_irq.
* ide/.cvsignore: New.
* rtems_webserver/cgi.c, rtems_webserver/sockGen.c,
rtems_webserver/umui.c, rtems_webserver/websSSL.c,
rtems_webserver/websSSL.h, rtems_webserver/websda.c,
rtems_webserver/websda.h: New files. Not included in previous commit.
* rtems_webserver/NOTES, rtems_webserver/asp.c,
rtems_webserver/balloc.c, rtems_webserver/default.c,
rtems_webserver/ej.h, rtems_webserver/ejIntrn.h,
rtems_webserver/ejlex.c, rtems_webserver/ejparse.c,
rtems_webserver/emfdb.c, rtems_webserver/emfdb.h,
rtems_webserver/form.c, rtems_webserver/h.c,
rtems_webserver/handler.c, rtems_webserver/license.txt,
rtems_webserver/md5.h, rtems_webserver/md5c.c,
rtems_webserver/mime.c, rtems_webserver/misc.c,
rtems_webserver/ringq.c, rtems_webserver/rom.c,
rtems_webserver/security.c, rtems_webserver/sock.c,
rtems_webserver/sym.c, rtems_webserver/uemf.c,
rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h,
rtems_webserver/url.c, rtems_webserver/value.c,
rtems_webserver/wbase64.c, rtems_webserver/webcomp.c,
rtems_webserver/webpage.c, rtems_webserver/webrom.c,
rtems_webserver/webs.c, rtems_webserver/webs.h,
rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h:
Update to GoAhead Webserver 2.1.4. The following URL is
the release notes from GoAhead.
http://data.goahead.com/Software/Webserver/2.1.4/release.htm
I have only done a minimal amount of testing (i.e. the network
demo program works fine). Please try this out and let me know
if it works. The patch needs to be applied on the
c/src/libnetworking/rtems_webserver directory.
PR 380/bsps
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h:
make printk format strings compliant with libcpu/printk.
minor fixes and lazy init bugfix.
PR 379/bsps
* console/polled_io.c: libcpu provides 'printk' already.
Therefore, the implementation in this file was removed (still
used for the bootloader, though). It now provides BSP_output_char()
for libcpu's printk().
* console/uart.c, console/uart.h: BSP_output_char_via_serial()
prototype changed to match the BSP_output_char_function_type. Note
that the motorola BSPs use polled-io for the output_char routine, not
the uart.c version. The latter can be used be other BSPs however
(e.g. SVGM).
* console/console.c, console/consoleIo.h, console/polled_io.c,
irq/irq_init.c, openpic/openpic.c, pci/detect_raven_bridge.c:
Unfortunately, the supported 'printk' format string subset of the
polled-io and libcpu implementations are different - hence, a few
format strings in the ppc/shared BSP were changed.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
PR 383/bsps
* irq/irq.c: Fix bug introduced by conflicts in previous patches.
* ide/.cvsignore: Add.
* bootloader/Makefile.am: Eliminate EABI CFLAGS from those used to
compile the bootloader.
* ide/Makefile.am: ATA code depends upon libchip/ide which is not
allowed in the cpukit source code since it must be buildable
independent of any BSP. These files were moved to libchip/ide.
* ide/ata.c, ide/ata.h, ide/ata_internal.h: New files.
PR 368/filesystems
* mpc8xx/include/mpc8xx.h: Add PCMCIA registers.
PR 368/filesystems
* ide/Makefile.am, ide/ide_ctrl_cfg.h: General improvements which
now work on pc386 and mbx8xx.
* ide/ide_controller.c: New file.
PR 368/filesystems
* startup/ldsegs.S: Increase alignment.
* Makefile.am, configure.ac, include/bsp.h, wrapup/Makefile.am:
Added IDE supporting infrastructure.
* ide/Makefile.am, ide/ide.c, ide/idecfg.c: New files. Added
BSP support for libchip standard ide driver.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
PR 360/bsps
* irq/irq.c, irq/irq_init.c, openpic/openpic.c, openpic/openpic.h:
BSP code had set the task priority register multiple times of
the OpenPIC instead of setting the individual source priorities.
This patch adds openpic_get_source_priority() and
openpic_set_source_priority() calls and lets IRQ management code
use them.
PR 349/bsps
* irq/irq.c, vme/VME.h, vme/vmeconfig.c: Fixes library dependency
on the vmeUniverse driver. It is now possible to use the ppc/shared/irq
code on non-VME BSPs without triggering linkage of the vmeUniverse
driver.
PR 349/bsps
* shared/include/cpuIdent.c: Readd PPC604r CPU.
