* | HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. | Joel Sherrill | 1998-03-26 | 1 | -1/+1 |
* | Moved memcpy to newlib/libc/machine/m68k | Joel Sherrill | 1998-03-25 | 1 | -1/+1 |
* | m68k software interrupt stack support from Chris Johns and Eric Norum. | Joel Sherrill | 1998-03-25 | 5 | -36/+40 |
* | Corrected argument passing. | Joel Sherrill | 1998-03-25 | 1 | -3/+2 |
* | Corrected definition of main and boot_card to be more ANSI compliant. | Joel Sherrill | 1998-03-25 | 1 | -3/+5 |
* | Corrected invocation of boot_card(). | Joel Sherrill | 1998-03-25 | 1 | -4/+6 |
* | Added _XOPEN_SOURCE definition to allow use of UNIX IPC. | Joel Sherrill | 1998-03-24 | 1 | -0/+1 |
* | changed version to 4.0.0-beta1 | Joel Sherrill | 1998-03-24 | 2 | -2/+2 |
* | Real definition for the beginning of the data section per Eric Norum's | Joel Sherrill | 1998-03-24 | 1 | -2/+2 |
| | | | | suggestion. | ||||
* | Corrected register constraints per suggestion from Thomas Doerfler, IMD | Joel Sherrill | 1998-03-24 | 2 | -6/+6 |
| | | | | <td@imd.m.isar.de>. | ||||
* | More cpu model flags converted to using cpp predefines. | Joel Sherrill | 1998-03-24 | 1 | -2/+2 |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 12 | -50/+48 |
| | | | | the CPU family name constants. | ||||
* | new file | Joel Sherrill | 1998-03-24 | 1 | -0/+54 |
* | Renamed hppa1_1 to hppa1.1 | Joel Sherrill | 1998-03-23 | 1 | -4/+1 |
* | renamed ppc to powerpc | Joel Sherrill | 1998-03-23 | 1 | -1/+0 |
* | Converted to conditionally uses strerr code to better work with glibc2. | Joel Sherrill | 1998-03-23 | 2 | -8/+21 |
* | Patches from Eric Norum: | Joel Sherrill | 1998-03-23 | 9 | -174/+85 |
| | | | | | | | Here are some patches to the gen68360 BSP. The improvements include: Boot prom run-time selection of DRAM size (1/4/16 Mbytes) Full 32-bit ethernet address obtained from boot prom. Updated README. | ||||
* | Added BSP specific start since it had become VERY complex to attempt | Joel Sherrill | 1998-03-21 | 3 | -1/+325 |
| | | | | to share the start code across i386 BSPs. | ||||
* | Corrected typo in copyright notice. | Joel Sherrill | 1998-03-21 | 1 | -1/+1 |
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 70 | -463/+190 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | Fixed spacing to be consistent with other CPUs. | Joel Sherrill | 1998-03-21 | 1 | -1/+1 |
* | POSIX not properly conditionalized | Joel Sherrill | 1998-03-21 | 2 | -2/+2 |
* | Fixed typo. | Joel Sherrill | 1998-03-20 | 2 | -2/+2 |
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-03-20 | 1 | -81/+75 |
| | | | | | | Here is my attempt at bringing m68k.h into line with the predefined symbols provided by egcs-1.0.2-prerelease (with R. Kirkham's patch so that -mcpu32, etc. implies -msoft-float). | ||||
* | Added Hitachi SH port info. | Joel Sherrill | 1998-03-20 | 1 | -1/+2 |
* | New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 24 | -0/+1811 |
* | SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 29 | -0/+4991 |
* | Removed blank line. | Joel Sherrill | 1998-03-20 | 1 | -1/+1 |
* | Fix from Chris Johns for inconsistent invocation of make. | Joel Sherrill | 1998-03-16 | 1 | -1/+1 |
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 1 | -2/+2 |
* | Changed to remove warning. | Joel Sherrill | 1998-03-03 | 1 | -5/+3 |
* | Switched from "extern int errno" to "#include <errno.h>". | Joel Sherrill | 1998-03-03 | 6 | -6/+6 |
* | Removed use of dc. David Fiddes reported that this is part of the | Joel Sherrill | 1998-02-27 | 1 | -1/+17 |
| | | | | | GNU tool bc which is not always installed under Linux and seldom present under non-UNIX environments like Win32. | ||||
* | Patch from Eric Norum: | Joel Sherrill | 1998-02-23 | 1 | -1/+1 |
| | | | | | | | | | Here's another small patch. The changes to socket.h are to provide some definitions that UNIX BSD socket programmers expect. The memcpy.c contains a memcpy routine optimized for the CPU32+. When I run the ttcp benchmark with this routine I get host->68360 transfers around 165 kbytes/sec (about a 25% improvement) and 68360->host transfers of around 290 kbytes/sec (about a 50% improvement). | ||||
* | Modified to make it possible for an ISR to return a mutex which did | Joel Sherrill | 1998-02-20 | 1 | -2/+20 |
| | | | | not use priority ceiling or priority inheritance protocols. | ||||
* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 |
* | Added misisng line continuation. | Joel Sherrill | 1998-02-20 | 2 | -2/+2 |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 |
* | changed version to 980219 | Joel Sherrill | 1998-02-19 | 2 | -2/+2 |
* | Patch from Eric Norum: | Joel Sherrill | 1998-02-19 | 1 | -36/+42 |
| | | | | | | | | | | While trying to work through this problem I decided that the build-time selection of the console I/O operation (polling or interrupt) was too clumsy. Here's a patch that allows run-time (actually init-time) selection of the console I/O mode. It also shows the need for another `flags' or `options' field in the rtems_driver_address_table structure... | ||||
* | Increased stack space of tasks. | Joel Sherrill | 1998-02-19 | 1 | -1/+1 |
* | Accounted for fixed system overhead. | Joel Sherrill | 1998-02-19 | 2 | -4/+20 |
* | Increased stack size of initialization task. | Joel Sherrill | 1998-02-19 | 1 | -0/+1 |
* | Restructured so all times are placed in variables and printed in batch | Joel Sherrill | 1998-02-19 | 1 | -163/+193 |
| | | | | | mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test. | ||||
* | changed version to 980218 | Joel Sherrill | 1998-02-18 | 2 | -2/+2 |
* | Ralf Corsepius noted that there was a dead path in _Thread_Initialize. | Joel Sherrill | 1998-02-18 | 1 | -6/+2 |
* | Patch from Chris Johns to add the interrupt class destructure. | Joel Sherrill | 1998-02-18 | 2 | -0/+10 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1377 | -1381/+1381 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
