* console/leds.c: Fix prototype of led_putnum().
* automake/compile.am: Remove build-variant support.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am
support/Makefile.am, wrapup/Makefile.am:
* configure.ac: Use AS_HELP_STRING instead of AC_HELP_STRING.
* Makefile.am, psim: Split psim into two files.
* psim-gdb: New file.
* acinclude.m4: Reflect eth_comm having been removed.
PR 704/bsps.
* ide_ctrl.c: Removed (obsolete).
Greg Menke 12/06/2004
* bootloader/pci.c: Removed the r->size=0 and r->base=0
assignement which makes too-large regions conflict with onboard
hardware, replacing it with sfree which deletes the memory region
from the setup code, leaving it disabled.
* timer/timerisr.S: Include rtems/asm.h not asm.h
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
Also extended RAM section since this is for a simulator
* startup/linkcmds, startup/linkcmds_ROM: Add new bss sections .bss.*
* startup/linkcmds, startup/linkcmds.flash: Add new bss sections .bss.*
* startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add
* eth_comm/.cvsignore, eth_comm/ChangeLog, eth_comm/Makefile.am,
eth_comm/README, eth_comm/bsp_specs, eth_comm/configure.ac,
eth_comm/times, eth_comm/canbus/canbus.c, eth_comm/clock/p_clock.c,
eth_comm/console/console.c, eth_comm/include/.cvsignore,
eth_comm/include/8xx_immap.h, eth_comm/include/bsp.h,
eth_comm/include/canbus.h, eth_comm/include/commproc.h,
eth_comm/include/coverhd.h, eth_comm/include/info.h,
eth_comm/include/tm27.h, eth_comm/irq/irq.c, eth_comm/irq/irq.h,
eth_comm/irq/irq_asm.S, eth_comm/irq/irq_init.c,
eth_comm/network/README, eth_comm/network/network.c,
eth_comm/start/start.S, eth_comm/startup/bspstart.c,
eth_comm/startup/cpuinit.c, eth_comm/startup/linkcmds,
eth_comm/startup/mmutlbtab.c, eth_comm/vectors/vectors.S,
eth_comm/vectors/vectors.h, eth_comm/vectors/vectors_init.c,
eth_comm/wrapup/.cvsignore, eth_comm/wrapup/Makefile.am: Removed.
PR 693/misc
* libchip/rtc/mc146818a_ioreg.c: Disable unless on a target with
in/outport routines.
PR 581/bsps
* mpc6xx/exceptions/raw_exception.c, shared/include/cpuIdent.h:
Converting PSIM to new exception model required adding PSIM as
PowerPC CPU model.
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
* aclocal/enable-itron.m4: Remove (unused).
* aclocal/enable-itron.m4: New (moved from ../aclocal).
* configure.ac: Misc. quoting cleanups.
Enable ada-tests iff --enable-ada and --enable-tests.
* powerpc/shared/include/cpuIdent.c,
powerpc/shared/include/cpuIdent.h: Add 603le.
(Submitted by Thomas.Doerfler <Thomas.Doerfler@imd-systems.de>
as part of the patch attached to PR 703).
PR 703/filesystem
* ide/pcmcia_ide.c: Extend the "modes_available" and "mode_active" parameters
to uint16_t for UDMA support.
PR 703/filesystem
* ide/ide.c: Extend the "modes_available" and "mode_active" parameters
PR 703/filesystem
* shared/ide_ctrl.c: Extend the "modes_available" and "mode_active"
parameters to uint16_t for UDMA support.
PR 703/filesystem
* libchip/ide/ata_internal.h, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/ide/ata.c,
libchip/ide/ide_controller.c:
Move definitions for ATA modes into ide_ctrl_cfg.h, to make them
available for BSPS/device drivers.
Extend the "modes_available" and "mode_active" parameters to
* startup/m68k-stub.c: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
* shared/cache/cache.c, shared/cache/cache_.h:
* startup/linkcmds: Add sections required by gcc 3.3.x so it will link.
* vmeUniverse/vmeUniverse.c: Use PCI_MEM_BASE_ADJUSTMENT because some
boards -- notably the MVME2100 -- return the physical address, not an
offset in PCI memory space.
* README.MVME2100: Update to include DBAT0.
* startup/linkcmds: Add sections from new gcc versions.
PR 717/bsps
* bootloader/Makefile.am: Set up BOOTLOADER_CPU_CFLAGS.
* libchip/network/dec21140.c: Cleanup a bit and remove message about
not supported on PowerPC since it works on the MVME2100 BSP.
* configure.ac, mpc6xx/exceptions/raw_exception.c,
mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.c,
mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S, shared/include/cpuIdent.c,
shared/include/cpuIdent.h: Add MPC8240 and MPC8245 support. There was
also a significant amount of spelling and whitespace cleanup.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
* tod/todcfg.c: New file.
* Makefile.am, configure.ac, bootloader/Makefile.am, include/bsp.h,
wrapup/Makefile.am: Add MVME2100 BSP and MPC8240 support. There was
* README.MVME2100: New file.
* startup/linkcmds: Add .gnu.linkonce.b section.
* startup/linkcmds: Add .gnu.linkonce.b and .gnu.linkonce.bs sections.
* startup/linkcmds: Add .gnu.linkonce.b section and account for memory
area being named sdram NOT RAM.
