path: root/c (follow)
* tools: Remove shgenSebastian Huber2018-06-114-27/+4
| | | | | | | | | | | | All tools should be removed from the RTEMS source repository at some point in time. Tools with a BSD-style license will be moved to the RTEMS tools repository. Unfortunately, the shgen tool is GPL licensed. Remove all uses of this tool from the code base. Replace generated files with stub functions. If users of this BSP still exist, they can reimplement the functionality using a BSD-style license. Close #3443.
* build: Force warningsSebastian Huber2018-06-111-1/+1
| | | | Always append some standard warning flags.
* virtex5: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* virtex4: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* virtex: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* tqm8xx: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+1
| | | | Updates #3425.
* t32mppc: Move -Dxxx to configure.acJoel Sherrill2018-05-181-1/+1
| | | | Updates #3425.
* ss555: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* qoriq: Move -Dxxx to configure.acJoel Sherrill2018-05-181-1/+1
| | | | Updates #3425.
* qemuppc: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+1
| | | | Updates #3425.
* psim: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* mvme5500: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* mvme3100: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* mpc8260ads: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+1
| | | | Updates #3425.
* mpc55xxevb: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* motorola_powerpc: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+14
| | | | Updates #3425.
* haleakala: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* beatnik: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* sparc64 BSPs: Hard define configuration required settingsJoel Sherrill2018-05-152-13/+3
| | | | Updates #3425.
* no_cpu/no_bsp: Fix MakefileAmaan Cheval2018-05-141-1/+1
* sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.hJoel Sherrill2018-05-092-1/+13
| | | | Updates #3425.
* smdk2410: Move define of CPU_S3C2410 to bspopts.hJoel Sherrill2018-05-091-2/+5
| | | | Updates #3425.
* bsp/pc386: Remove bin2boot supportSebastian Huber2018-04-276-833/+0
| | | | | Update #3408. Close #3410.
* bsp/mcf5206elite: Do not install runtest scriptSebastian Huber2018-04-265-399/+0
| | | | | | | Provide the runtest script only as a part of the sources. This simplifies the build system. Test support should be included in the RTEMS Tester.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-26127-12218/+0
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Remove unmaintained times filesSebastian Huber2018-04-264-765/+0
* bsp/sparc64: Move asm.S to bsps and renameSebastian Huber2018-04-263-19/+2
* bsps/mips: Move liblnk to bspsSebastian Huber2018-04-265-248/+6
* bsps/powerpc: Move bsp-start-zero.S to bspsSebastian Huber2018-04-265-119/+4
* bsp/psim: Move align_h.S to bspsSebastian Huber2018-04-262-440/+1
* bsp/haleakala: Move assembler files to bspsSebastian Huber2018-04-263-322/+2
* bsp/qemuppc: Install linkcmds.baseSebastian Huber2018-04-251-0/+1
| | | | | Update #3339. Close #3411.
* bsps/arm: Remove unused filesSebastian Huber2018-04-2513-17990/+0
* bsps: Remove unused u-boot-generic-board-info.hSebastian Huber2018-04-251-132/+0
* bsp/beagle: Move source files to bspsSebastian Huber2018-04-255-1621/+4
* bsp/gumstix: Move fb.c to bspsSebastian Huber2018-04-252-240/+1
* bsp/lm3s69xx: Move ssi.c to bspsSebastian Huber2018-04-252-171/+1
* bsp/lpc176x: Move source files to bspsSebastian Huber2018-04-2513-2426/+13
* bsp/lpc24xx: Move source files to bspsSebastian Huber2018-04-2510-1963/+9
* bsp/lpc32xx: Move source files to bspsSebastian Huber2018-04-2512-1239/+11
* bsp/raspberrypi: Move source files to bspsSebastian Huber2018-04-257-1591/+4
* bsp/smdk2410: Move smc.c to bspsSebastian Huber2018-04-252-411/+1
* bsp/tms570: Move cpucounterread.c to bspsSebastian Huber2018-04-252-63/+1
* bsp/mcf5206elite: Move nvram.c to bspsSebastian Huber2018-04-252-174/+1
* bsp/mrm332: Move interr.c to bspsSebastian Huber2018-04-251-50/+0
* bsp/mrm332: Move spinit.c to bspsSebastian Huber2018-04-252-97/+1
* bsp/gen5200: Move source files to bspsSebastian Huber2018-04-257-3129/+4
* bsp/haleakala: Move mmu_405.c to bspsSebastian Huber2018-04-252-294/+1
* bsp/beatnik: Move source files to bspsSebastian Huber2018-04-258-2721/+4
* bsp/mvme3100: Move flashcfg.c to bspsSebastian Huber2018-04-252-117/+1
