* include/Makefile.am: Cleanup.
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* network/sonic.c: Added ipalign() routine to align the
received packet so that the ip header is on a 32-bit boundary.
Necessary for cpu's that do not allow unaligned loads and stores
and when the 32-bit DMA mode is used.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* clock_driver_stub.c: This is a stub of a clock driver that
is sufficient for linking the ticker application. Some
simulators do not have a soruce for a clock tick. Also
this can be used while constructing a BSP so everything links.
* Makefile.am, console/Makefile.am, include/Makefile.am,
start/Makefile.am: VPATH was not setup correctly
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf).
Autoconf allows one to pass -enable-*, but this file expected --enable*.
* libc/libio.c: Special treatment of O_NDELAY for Cygwin.
* Makefile.am, clock/Makefile.am, clock/.cvsignore, wrapup/Makefile.am:
Added include of stub clock driver so ticker would link.
* configure.in, Makefile.am, clock/Makefile.am, clock/.cvsignore,
wrapup/Makefile.am: Added include of stub clock driver so ticker
would link.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* network/README.cs8900, network/cs8900.c, network/cs8900.h: New files.
* network/Makefile.am: Modified to reflect above.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* bsp_specs: Remove -Tlinkcmds from *link rule.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h,
libio_.h, libio.h, and libcsupport.h moved from libc to
lib/include/rtems and now must be referenced as <rtems/XXX.h>.
Header file order was cleaned up while doing this.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
* startup/82378zb.c, startup/FPGA.c: assoc.h, error.h, libio_.h,
* shared/bsppretaskinghook.c: assoc.h, error.h, libio_.h, libio.h,
* ChangeLog: Removed incorrectly placed entry.
* configure.in: Added include/rtems subdirectory.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and now must
* src/imfs/Makefile.am, src/imfs/deviceio.c, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_free.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_gtkn.c,
src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_readlink.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/memfile.c, src/imfs/miniimfs_init.c:
<rtems/XXX.h>. Now we do not have to reach up and over to
libc to pick them up.
* Makefile.am: Switch to GNU canonicalized autoconf macros.
* bsp_specs: Add qnolinkcmds.
* Makefile.am: Switch to macros/, reflect new configure.in,
* configure.in: Switch to GNU-canonicalization.
* acinclude.m4: Remove.
* configure.in: Cleanup comments.
* target.cfg.in: Comment out RTEMS_HOST, RTEMS_CROSS_TARGET.
* Makefile.am: Switch to GNU canonicalization.
* ChangeLog: New file.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* configure.in: New file.
* .cvsignore: Add aclocal.m4, configure.
effects in RTEMS source code.
* paranoia/paranoia.c: Commented out incorrect and conflicting
prototype of read().
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
* machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync
with newlib's <machine/types.h>.
* rtems/rtems_bsdnet_internal.h: newlib now includes definition
of struct itimerval in <sys/time.h>.
* sbrk.c: Corrected prototype to match newlib.
