Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
This file was used by this BSP only. Avoid RTEMS_RELLDFLAGS.
Update #3285.
Avoid extra CPPFLAGS.
Update #3285.
Update #3285.
Update #3254.
upgrade to that version.
Close #3387.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
These are now built to executables and are too large for this BSP.
Update #3382
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
The umon support is only used by the csb337 BSP.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3375.
Update #3285.
Update #3285.
Started to eliminate warnings and then realized that only one one-line
macro in the file was used by a few files. The rest of the file was
was not needed. Eliminate the file.
Closes #3354.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3339.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
