* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 56 | -56/+56 |
* | rtems: Use atomic operation with correct type | Daniel Cederman | 2015-03-20 | 1 | -1/+1 |
* | bsp/rtl22xx: Add prefix due to name conflicts | Sebastian Huber | 2015-03-20 | 1 | -5/+5 |
| | | | | Close #2303. | ||||
* | Add CAN, PWM, ADC and UART1/2/3 support to the LPC176x BSP. | Martin Galvan | 2015-03-20 | 20 | -10/+1881 |
| | | | | | | | | | | This patch adds support for the following devices to the LPC176x BSP: * CAN * PWM * ADC It also adds the probe routines for UART1/2/3 to the console_device_table in console-config.c, and enables UART1 in configure.ac. | ||||
* | m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | powerpc/shared/flash/intelFlash.c: Eliminate use of deprecated method | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | powerpc/mvme5500/vectors/exceptionhandler.c: Turn off deprecated warning | Joel Sherrill | 2015-03-17 | 1 | -0/+6 |
| | | | | updated #2306. | ||||
* | libchip/network/if_fxp.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -7/+4 |
* | libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | score603e/tod/tod.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | beatnik/network/porting/if_xxx_rtems.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | mvme167/network/network.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -19/+21 |
* | mvme162/tod/tod.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | bsp/mpc55xx: Fix flash settings | Sebastian Huber | 2015-03-17 | 1 | -13/+16 |
* | bsp/qoriq: Add register blocks for T variants | Sebastian Huber | 2015-03-17 | 1 | -78/+84 |
* | bsp/qoriq: Fix warning | Sebastian Huber | 2015-03-17 | 1 | -0/+3 |
* | bsp/mbx8xx: Fix warnings | Sebastian Huber | 2015-03-16 | 1 | -4/+6 |
* | preliminary Raspberry Pi Model 2 support | Alan Cudmore | 2015-03-16 | 6 | -22/+55 |
| | | | | | | | | | | | | | | | | | This patch adds a BSP variant for the Raspberry Pi 2. You can build both variants by configuring with the option --enable-rtemsbsp="raspberrypi2 raspberrypi" For the current BSP, the only change was the peripheral register base address and the compiler options. The raspberrypi/make/custom rules were re-factored: raspberrypi.inc -- Common rules raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+) and Pi 2. | ||||
* | bsps/sparc: Fix linker section | Sebastian Huber | 2015-03-15 | 1 | -3/+3 |
* | Revert "autoconf changes" | Ben Gras | 2015-03-14 | 2 | -4/+4 |
| | | | | | | This reverts commit dbe85952f9adac28a2dc84473eac24ae2c85e260. Accidentally merged. | ||||
* | beagle bsp: delete TIMER_FREQ, TIMER_COUNT | Ben Gras | 2015-03-14 | 1 | -4/+0 |
| | | | | | | unused and poorly named (no prefix) and colliding with sp68. Closes #2302. | ||||
* | autoconf changes | Ben Gras | 2015-03-14 | 2 | -4/+4 |
* | m32cbsp: Add bsp_reset() so the BSP exits | Joel Sherrill | 2015-03-12 | 2 | -1/+3 |
* | mvme147s: Install z8530.h | Joel Sherrill | 2015-03-11 | 2 | -0/+13 |
| | | | | This was missed when the file was moved. | ||||
* | cpukit: deprecate notepads | Gedare Bloom | 2015-03-10 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265 | ||||
* | Move contents of libcsupport/include/zilog into libbsp/shared | Joel Sherrill | 2015-03-09 | 8 | -0/+242 |
| | | | | Only a few BSPs use this and it should not have been in libcsupport. | ||||
* | Move libcsupport/include/motorola/*.h to m68k/idp BSP | Joel Sherrill | 2015-03-09 | 4 | -0/+397 |
| | | | | | | | These header files were only used by one BSP and they are hardware dependent. The hardware dependency always made them bad candidates for where they were in the tree. But this fixes that. | ||||
* | libcpu/powerpc/mpc8260/console-generic/console-generic.c: Include bsp.h to ↵ | Joel Sherrill | 2015-03-09 | 1 | -3/+1 |
| | | | | fix warning | ||||
* | rtl22xx.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | lpc1768_mbed.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | mvme136.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | gensh1/include/bsp.h: Add needed prototype | Joel Sherrill | 2015-03-09 | 1 | -0/+7 |
* | gensh4/include/bsp.h: Remove unused prototype and include | Joel Sherrill | 2015-03-09 | 1 | -6/+0 |
* | powerpc/shared/bootloader/pci.c: Remove warnings | Joel Sherrill | 2015-03-09 | 1 | -2/+2 |
* | shared/include/grcan.h: Add prototypes to fix warnings | Joel Sherrill | 2015-03-09 | 1 | -1/+2 |
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 21 | -0/+25 |
* | Temporarily ignore dl* tests on some PowerPC BSPs | Joel Sherrill | 2015-03-06 | 9 | -0/+45 |
| | | | | | | | | Some BSPs have issues linking the dl* tests. These issues have not been investigated. This is a temporary workaround until we have an explanation and permanent solution. updates 2258. | ||||
* | Always disable networking for h8300 | Joel Sherrill | 2015-03-06 | 9 | -1/+10 |
* | Temporarily disable libdl tests on some MIPS BSPSs | Joel Sherrill | 2015-03-06 | 3 | -0/+15 |
| | | | | | | | These BSPs are little endian while most are big endian. The dl tool does not support the -EL option yet. updates 2279. | ||||
* | raspberrypi: Do not include default IRQ handler and BSP specific one | Joel Sherrill | 2015-03-06 | 1 | -1/+0 |
| | | | | | | This was tripping a linker error in the dl0[12] tests. closes 2247. | ||||
* | lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01 | Joel Sherrill | 2015-03-06 | 1 | -0/+1 |
* | lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file | Joel Sherrill | 2015-03-06 | 1 | -7/+0 |
| | | | | | This file does not have "-testsuite" in the name and is ignored by the build system. |
