* | botched file -- removed from repository and readded | Joel Sherrill | 1998-04-30 | 1 | -0/+14 |
* | Removed tripling of workspace API when POSIX API is enabled. confdefs.h | Joel Sherrill | 1998-04-30 | 2 | -1/+5 |
| | | | | | | is now correct enough where this is not necessary. This was in to cover up the deficiencies in figuring out how much memory a GNAT/RTEMS application required. There is a good stab at this now. | ||||
* | Added wildcard to switch for monitor and termios. | Joel Sherrill | 1998-04-30 | 1 | -1/+1 |
* | Removed redundant "* 1024" which exploded the size of the workspace. | Joel Sherrill | 1998-04-30 | 2 | -4/+4 |
* | Added sections and redirected some to RAM to avoid warnings. | Joel Sherrill | 1998-04-30 | 1 | -40/+47 |
* | Added sections to remove warnings | Joel Sherrill | 1998-04-30 | 1 | -0/+8 |
* | moved tools to bsp directory | Joel Sherrill | 1998-04-30 | 2 | -2/+2 |
* | Added support for debug variants on tests. | Joel Sherrill | 1998-04-29 | 1 | -4/+5 |
* | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>. | Joel Sherrill | 1998-04-27 | 11 | -820/+274 |
* | Added I386_HAS_BSWAP cpu model feature flag so swap u32 could take | Joel Sherrill | 1998-04-27 | 1 | -10/+28 |
| | | | | | | | | advantage of this instruction. Also up conditionals mapping cpu models to feature flags by having a section which defaults all the i386 family feature flags to the most common value. | ||||
* | Added swap of unsigned16 | Joel Sherrill | 1998-04-27 | 11 | -3/+69 |
* | Fixed spelling errors. | Joel Sherrill | 1998-04-27 | 1 | -3/+3 |
* | Fixed trace bit manipulation per requests from Eric Norum and Chris Johns. | Joel Sherrill | 1998-04-27 | 1 | -11/+3 |
| | | | | Actual patch was from Eric Norum. | ||||
* | Cosmetic fix from Eric Norum: | Joel Sherrill | 1998-04-27 | 2 | -2/+2 |
| | | | | | | This makes the headings line up above the columns a little better. Now that it's so easy to include/exclude the stack check code I find myself adding it to all my `debug' targets. | ||||
* | Removed redundant implementation of tcgetattr and tcsetattr. | Joel Sherrill | 1998-04-27 | 1 | -20/+0 |
* | Fixed bad CVS Id string. | Joel Sherrill | 1998-04-27 | 1 | -2/+1 |
| | | | | Removed unnecessary definition of "ED". | ||||
* | Clean up patch from Ralf Corsepius. | Joel Sherrill | 1998-04-27 | 1 | -22/+23 |
* | Fix from Ralf Corsepius: | Joel Sherrill | 1998-04-27 | 1 | -6/+1 |
| | | | | | | use a wildcard rule instead of explicit listing all include files (I have more libcpu header files than the public version has. This patch removes the need to patch this Makefile for my private bsps) | ||||
* | Added shared directory. | Joel Sherrill | 1998-04-27 | 1 | -1/+1 |
* | Removed extra (bad) CVS Id string. | Joel Sherrill | 1998-04-27 | 1 | -2/+0 |
* | Fixed CVS Id string and removed bogus comment. | Joel Sherrill | 1998-04-27 | 1 | -4/+1 |
* | Fix from Ralf Corsepius: | Joel Sherrill | 1998-04-27 | 1 | -0/+1 |
| | | | | + adding #include <rtems/libio.h> to fix implicit declaration warning | ||||
* | Fixed CVS Id | Joel Sherrill | 1998-04-27 | 1 | -1/+1 |
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 24 | -3/+49 |
| | | | | more accurate. | ||||
* | Fixed screen to match actual output. | Joel Sherrill | 1998-04-27 | 1 | -3/+2 |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 2 | -2/+134 |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | ||||
* | Moved POSIX_signals_Siginfo_node structure definition to headers/psignal.h | Joel Sherrill | 1998-04-27 | 1 | -5/+1 |
| | | | | so confdefs.h could see it. | ||||
* | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1998-04-27 | 2 | -4/+14 |
| | | | | | | | the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | ||||
* | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1998-04-27 | 1 | -1/+5 |
| | | | | generated. | ||||
* | psim now runs in both debug and non-debug mode. | Joel Sherrill | 1998-04-18 | 4 | -9/+17 |
* | rtems_libio_number_iops is now defined in confdefs.h so the maximum | Joel Sherrill | 1998-04-18 | 2 | -2/+2 |
| | | | | file descriptors is user configurable. | ||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 2 | -2/+10 |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | ||||
* | Changed version number so script will work. | Joel Sherrill | 1998-04-18 | 2 | -2/+2 |
* | Fixed so this would compile without warning. | Joel Sherrill | 1998-04-15 | 2 | -0/+4 |
* | Added bh, ch, dh, bl, cl, and dl register macros. | Joel Sherrill | 1998-04-15 | 1 | -0/+7 |
* | Updated. | Joel Sherrill | 1998-04-15 | 1 | -0/+2 |
* | update from Eric Norum | Joel Sherrill | 1998-04-15 | 2 | -16/+15 |
* | New file created by extracting common initialization from every BSP's | Joel Sherrill | 1998-04-15 | 1 | -0/+38 |
| | | | | bspstart.c file. | ||||
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 56 | -873/+90 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 63 | -1435/+604 |
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 |
| | | | | for them. | ||||
* | Stack check now initialized as part of initial extension set. | Joel Sherrill | 1998-04-15 | 6 | -0/+130 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 27 | -351/+13 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 9 | -28/+83 |
* | changed version to ralf-980414 | Joel Sherrill | 1998-04-14 | 2 | -2/+2 |
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 2 | -2/+24 |
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 3 | -3/+2 |
| | | | | gcc-target-default.cfg | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 27 | -201/+3 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 2 | -4/+28 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 28 | -408/+32 |
| | | | | by newlib. |
