* | virtex5: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -7/+3 |
| | | | | Updates #3520. | ||||
* | gen5200, gen83xx, gen83x, mpc55xxevb, psim, qoriq, t32mppc, tqm8xx, virtex: ↵ | Joel Sherrill | 2017-12-20 | 20 | -41/+31 |
| | | | | | | | | | | Simplify bsp_specs These BSPs all use shared/startup/linkcmds.base and thus needed to be modified at the same time. Variations in the arguments were reflected into the BSP specific portions of the linkcmds. Updates #3520. | ||||
* | uC5282: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 |
* | mcf5235: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 4 | -5/+8 |
* | mcf5225x: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 |
* | mcf5206elite: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 3 | -5/+7 |
* | mcf52235: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 |
* | gen68340: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+5 |
* | gen68360: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 |
* | csb360: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 |
* | av5282: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 4 | -5/+7 |
* | genmcf548x, mvme147, mvme147s, mvme162, mvme167: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 6 | -25/+9 |
| | | | | | | | These BSPs used shared/startup/linkcmds.base and had to be modified as a set. Updates #3520. | ||||
* | mrm332: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 |
* | mcf5329: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 3 | -5/+3 |
* | Add support for arguments in ISRs | Kilian Holzinger | 2017-12-20 | 1 | -0/+3 |
* | gensh4: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 4 | -5/+7 |
| | | | | Updates #3250. | ||||
* | gensh2: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 4 | -7/+4 |
* | gensh1: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | shsim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 5 | -242/+2 |
| | | | | | | | | | | This bsp_specs included non-standard logic to pass endian arguments to the linker. These should not be necessary. If they are, it is a bug in the sh gcc target. The code was "%{ml:-EL}%{mb:-EB}" Also the file linkcmds.sim was not referenced and was deleted. Updates #3250. | ||||
* | rbtx4938: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 |
* | rbtx4925: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 |
* | malta: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 |
* | jmr3904: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 |
* | hurricane: Simplifies bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 |
* | csb350: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+3 |
* | sparc64 BSPs: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 3 | -11/+4 |
* | ARM BSPs: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 21 | -100/+21 |
* | riscv_generic: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | TLL6527M: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | eZKit533: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | bf537Stamp: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | nios2_iss: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 |
* | generic_or1k: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | m32cbsp: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | moxiesim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | milkymist: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 |
* | lm32_evr: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 |
* | pc386: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 3 | -7/+4 |
| | | | | | | | | If this has any issues, check that the change in linking the 16-bit startup code in Makefile.am generates the same code. This was odd code and didn't need the RTEMS linkcmds anyway. Updates #3520. | ||||
* | epiphany: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 |
* | gdbv850sim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -9/+2 |
* | mvme167: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -7/+0 |
| | | | | | | | | | This bsp-specs added many libraries which it should not have. It also added the non-standard -qjava option which if actually used will have to be addressed by adding linker options on the GCC command line. Updates #3520. | ||||
* | mcf5206elite: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -9/+1 |
| | | | | | | | Removes the non-standard -qflash option added by the bsp_specs. If actually used, this will have to be addressed in another way. Updates #3520. | ||||
* | csb360: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -9/+1 |
| | | | | | | | | This patch removes the non-standard -qclock option which defines _SYS_CLOCK_FREQUENCY. If actually used, this can be achieved by providing ld options via the linking invocation of GCC. Updates #3520. | ||||
* | sparc/*/bsp_specs, shared/linkcmds: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 4 | -3/+5 |
* | bsp/altera-cyclone-v: Remove reserved memory | Sebastian Huber | 2017-12-19 | 1 | -0/+83 |
| | | | | Removed reserved memory from work area, e.g. used by FPGA devices. | ||||
* | bsp/altera-cyclone-v: Adjust work area | Sebastian Huber | 2017-12-19 | 3 | -2/+94 |
| | | | | | Use FDT to adjust the work area. Reduce work area of linker command file. | ||||
* | bsps/arm: Fix move <libcpu/arm-cp15.h> to cpukit | Sebastian Huber | 2017-12-15 | 16 | -91/+0 |
| | | | | Update #3254. | ||||
* | bsp/altera-cyclone-v: Update clock frequencies | Sebastian Huber | 2017-12-14 | 1 | -2/+73 |
* | bsp/altera-cyclone-v: Enable FDT support | Sebastian Huber | 2017-12-14 | 2 | -0/+13 |
* | bsps/arm: Disable all interrupts in GIC init | Sebastian Huber | 2017-12-14 | 1 | -0/+4 |
