* | Remove special case lib/libbsp/bare (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -8/+2 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 11 | -739/+0 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -4/+4 |
| | | | | * startup/bspstart.c: Remove __RTEMS_APPLICATION__ | ||||
* | added support for COBRA5475 board | Thomas Doerfler | 2009-10-16 | 12 | -19/+348 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+6 |
| | | | | * startup/bspstart.c: Add missing prototypes. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 3 | -3/+8 |
| | | | | | * shared/motorola/motorola.c, shared/vme/vme_universe.c: Add missing prototypes. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+5 |
| | | | | * startup/linkcmds: Add .sbss.*. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -13/+17 |
| | | | | | * startup/linkcmds: Add sbss section handling. Misc. sync with binutils's ld-scripts. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+5 |
| | | | | * startup/linkcmds: Fix up .sbss .sbss.* section handling. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+7 |
| | | | | * startup/linkcmds: Add __sbss_start, __sbss_end etc. | ||||
* | Update for block device API change. | Thomas Doerfler | 2009-10-16 | 2 | -2/+6 |
| | | | | * make/custom/ss555.cfg: Remove -D$(RTEMS_BSP_FAMILY) (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+2 |
| | | | | * Makefile.am: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+1 |
| | | | | * configure.ac: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -3/+4 |
| | | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 |
| | | | | * make/custom/gen83xx.cfg: Remove -W -Wno-unused. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 |
* | Fix typo. | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 |
* | add PHY control support | Thomas Doerfler | 2009-10-15 | 2 | -191/+159 |
* | add network support, various corrections | Thomas Doerfler | 2009-10-15 | 7 | -37/+1898 |
* | add MC_DMA support to MCF548x | Thomas Doerfler | 2009-10-15 | 12 | -0/+4408 |
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+19 |
| | | | | * make/custom/no_bsp.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+29 |
| | | | | * make/custom/uC5282.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+55 |
| | | | | | * make/custom/sim68000.cfg: New (relocated from /make/custom). * make/custom/simcpu32.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+39 |
| | | | | * make/custom/ods68302.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+50 |
| | | | | * make/custom/mvme167.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+75 |
| | | | | | * make/custom/mvme162.cfg: New (relocated from /make/custom). * make/custom/mvme162lx.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+34 |
| | | | | * make/custom/mvme147s.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+32 |
| | | | | * make/custom/mvme147.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+35 |
| | | | | * make/custom/mvme136.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+59 |
| | | | | * make/custom/mrm332.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/mcf5329.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+40 |
| | | | | * make/custom/mcf5235.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+36 |
| | | | | * make/custom/mcf52235.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+26 |
| | | | | * make/custom/mcf5206elite.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+33 |
| | | | | * make/custom/idp.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+49 |
| | | | | | * make/custom/genmcf548x.cfg: New (relocated from /make/custom). * make/custom/m5484FireEngine.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 4 | -0/+69 |
| | | | | | | * make/custom/gen68360_040.cfg: New (relocated from /make/custom). * make/custom/gen68360.cfg: New (relocated from /make/custom). * make/custom/pgh360.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+25 |
| | | | | * make/custom/gen68340.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/gen68302.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/csb360.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/av5282.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+24 |
| | | | | * make/custom/smdk2410.cfg: New (relocated from /make/custom). | ||||
| | | | | | * make/custom/rtl22xx.cfg: New (relocated from /make/custom). * make/custom/rtl22xx_t.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+44 |
| | | | | * make/custom/nds.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 6 | -0/+68 |
| | | | | | | | | * make/custom/lpc24xx.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ea.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_ram.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_rom_ext.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_rom_int.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/gumstix.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+30 |
| | | | | * make/custom/gp32.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 6 | -0/+111 |
| | | | | | | | | * make/custom/arm1136jfs.cfg: New (relocated from /make/custom). * make/custom/arm1136js.cfg: New (relocated from /make/custom). * make/custom/arm7tdmi.cfg: New (relocated from /make/custom). * make/custom/arm920.cfg: New (relocated from /make/custom). * make/custom/armcortexa9.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/gba.cfg: New (relocated from /make/custom). |
