Close #2373.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
The update fixes breakage of TMS570 support after Alexander Krutwig
switch of RTEMS time read to timecounter mechanism
bsps: Convert clock drivers to use a timecounter
Mechanism to specify odd (non 1 Mhz) time base update frequencies
implemented after objections of Martin Galvan.
Code is adjusted to convert RTEMS configuration parameter
microseconds_per_tick to such odd base if
TMS570_PREFERRED_TC_FREQUENCY is specified appropriately.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
The header files are generated by script make_header.py.
Current script's version can be found at:
https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python
Registers offsets and fields have been extracted from reference manual.
These files were left after running the script in the previous patch.
do
echo $b
# echo $g
-i $b
done
The e500v1 has no support for the ATB.
Update #2369.
Update #2369.
counter
timer interrupt was hard coded to 10 ms per tick.
Fix uses the setting of CONFIGURE_MICROSECONDS_PER_TICK to compute the correct start value for the counter
See for more information: http://permalink.gmane.org/gmane.os.rtems.user/22691
This was the only configure.ac file with bspopts.h present in
AC_CONFIG_FILES(). This somehow prevented the generation of this file
leading to build errors for this BSP.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
closes #2364.
The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically the deferred floating point switch is
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context. The floating point unit is disabled for interrupt handlers.
Thus in case an interrupt handler uses the floating point unit then this
will result in a trap.
On SMP configurations the deferred floating point switch is not
supported in principle. So use here a safe floating point support. Safe
means that the volatile floating point context is saved and restored
around a thread dispatch issued during interrupt processing. Thus
post-switch actions and context switch extensions may safely use the
floating point unit.
Update #2270.
Store the floating-point unit property in the thread control block
regardless of the CPU_HARDWARE_FP and CPU_SOFTWARE_FP settings. Make
sure the floating-point unit is only enabled for the corresponding
multilibs. This helps targets which have a volatile only floating point
context like SPARC for example.
Update #2270.
Update #2356.
basic VGA driver can be enabled during configure phase by exporting variable
USE_VGA=1 so that it is available in configure environment
cirrus driver is enabled the same way by exporting variable
USE_CIRRUS_GD5446=1
driver is not initialized by default
initialization is possible through multiboot command line option or
through the string variable (see fb_default_mode.h) set in user's module
allowing the driver to evaluate this variable after the two
modules are linked together
This BSP in intended to run on the simulator that should be built
from RSB. When building RTEMS for Epiphany --disable-networking must
be provided part of the configure command.
Fix typo.
closes 2345.
Update #2271.
These global variables are obsolete since
65f71f8472fa904ca48b816301ed0810def47001.
