* | Jennifer found some uninitialized variables: | Joel Sherrill | 1998-01-16 | 2 | -2/+14 |
| | | | | | | + major and minor number elements in rtems_termios_open. + arg->ioctl_return in rtems_termios_ioctl routine. | ||||
* | Error reported by Duncan Smith <dds@flavors.com>: | Joel Sherrill | 1998-01-15 | 2 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | >> >>There is a 30 day error in _TOD_Days_since_last_leap_year[2..3] >> > >> >Thanks. >> >What's the condition to hit this error? >> >Every year 4n+2 and 4n+3 ? >> >(i.e. 1998, 1999, 2002, 2003, ...) >> > >> OK: 96 97 00 01 04 05 ... >> Bad: 98 99 02 03 06 07 ... There is also a problem in newlib 1.7.x reported at the same time: >> I found another, that would strike only on 2/29/2000, or other leapyears. >> Only a problem on 1 day. >> >> Joel: FYI, there is a bug in Newlib localtime.c, localtime or (_tm_time). >> Ours is modified for dst and timezones, but the bug was in original source. >> I have not looked at the latest public source (nor do I know where to find >> it). | ||||
* | Updates from Eric Norum. Changed CPU CFLAG and went to a common name | Joel Sherrill | 1998-01-06 | 1 | -150/+112 |
| | | | | for the network driver attach entry point. | ||||
* | Changed initial settings of first time. | Joel Sherrill | 1998-01-06 | 2 | -6/+10 |
* | Fixed spacing. | Joel Sherrill | 1998-01-06 | 1 | -2/+2 |
* | Updated for the first time in a long while. | Joel Sherrill | 1997-12-23 | 1 | -30/+45 |
* | Added CONFIGURE_GNAT_KEYS to correct the number of keys configured | Joel Sherrill | 1997-12-23 | 2 | -24/+22 |
| | | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call. | ||||
* | Fixes from Eric Norum. C++ support added in previous version was broken: | Joel Sherrill | 1997-12-22 | 3 | -291/+272 |
| | | | | | | | | | | | | | | | | | | 1) In my haste to add C++ constructor/destructors to the 68360 linkcmds scripts I managed to break all existing 68360 programs. Linker scripts which actually produce a working executable are contained below. The problem was that the constructor/destructors weren't included before the etext symbol. On top of that Eric and I appear to have problems with attachments: 2) In deciphering the above problem I think I stumbled across the reason you've had with patches mailed from me. I noticed that the linkcmds (and linkcmds.bootp) scripts in the latest distribution have a control-M (carriage return) at the end of each line. Could you check the files below before installing them in the distribution and see that there aren't returns in the files? Maybe if I send everything as a tar attatchment things will work better. | ||||
* | Corrected prototypes for all termios console write driver entries to | Joel Sherrill | 1997-12-22 | 8 | -11/+14 |
| | | | | properly reflect the const on the buffer pointer being passed in. | ||||
* | Now generating this file with autoconf to avoid having to embed so | Joel Sherrill | 1997-12-22 | 1 | -0/+221 |
| | | | | much target specific information in the script. | ||||
* | Changed invocation of size_rtems to match new autoconf'ed version. | Joel Sherrill | 1997-12-22 | 1 | -1/+1 |
* | Changed from .align to .p2align to avoid differences in meaning of | Joel Sherrill | 1997-12-22 | 1 | -6/+6 |
| | | | | | .align between i386-rtems (real number on .align) and i386-go32-rtems (power of 2). | ||||
* | Added lines to build sizeinfo.txt which is automatically generated now | Joel Sherrill | 1997-12-22 | 1 | -0/+3 |
| | | | | by size_rtems. | ||||
* | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1997-12-20 | 19 | -38/+38 |
| | | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | ||||
* | Update from Eric Norum to include C++ support. | Joel Sherrill | 1997-12-20 | 3 | -239/+281 |
* | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1997-12-19 | 19 | -19/+19 |
| | | | | switch which lets the user specify a different linker script. | ||||
* | Pass in PROJECT_HOME so rtems-glom can run if the make is invoked | Joel Sherrill | 1997-12-16 | 2 | -4/+8 |
| | | | | just in this directory. | ||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 461 | -480/+1868 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Added missing dependency for libmisc.a based on a bug report by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -0/+2 |
* | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -2/+2 |
* | Changed the uuencode line to work better with VPATH setups. | Joel Sherrill | 1997-12-06 | 1 | -2/+2 |
* | Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined. | Joel Sherrill | 1997-12-06 | 2 | -4/+4 |
| | | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find. | ||||
* | Reworked mkdir line to invoke smaller lines. | Joel Sherrill | 1997-12-04 | 1 | -1/+4 |
* | Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano | Joel Sherrill | 1997-12-01 | 32 | -0/+4896 |
| | | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/). | ||||
* | Since test suite Makefiles are not always generated, use wildcard | Joel Sherrill | 1997-11-30 | 1 | -4/+3 |
| | | | | to determine which directories to descend into. | ||||
* | Corrected call to rtems_termios_open. | Joel Sherrill | 1997-11-30 | 1 | -1/+2 |
* | Corrected comment. | Joel Sherrill | 1997-11-30 | 2 | -6/+1 |
* | Do not generate make/os at install point. | Joel Sherrill | 1997-11-30 | 1 | -2/+1 |
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 4 | -2/+12 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Patch from Chris Johns to filter out the trace bit on CPU models | Joel Sherrill | 1997-11-29 | 1 | -2/+5 |
| | | | | which have hardware support for a separate interrupt stack. | ||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1997-11-18 | 1 | -0/+45 |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 2 | -0/+10 |
* | Removed warnings. | Joel Sherrill | 1997-11-18 | 2 | -1/+6 |
* | Added argument as required by new version of termios_open. | Joel Sherrill | 1997-11-18 | 1 | -2/+4 |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 2 | -2/+12 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 6 | -178/+427 |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 3 | -3/+3 |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 2 | -0/+2 |
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 2 | -2/+16 |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 5 | -29/+15 |
* | Switched to new style for read support routine. | Joel Sherrill | 1997-10-23 | 1 | -10/+6 |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 3 | -1/+205 |
