* | Fix formatting. | Joel Sherrill | 2005-10-20 | 3 | -5/+4 |
* | Numerous changes and cleanups to support MVME2100. | Eric Norum | 2005-10-20 | 10 | -20/+68 |
* | Add pci.rel to librtemsbsp.a | Ralf Corsepius | 2005-10-17 | 2 | -2/+2 |
* | Cosmetics. | Ralf Corsepius | 2005-10-17 | 1 | -1/+1 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 4 | -0/+30 |
| | | | | * Makefile.am: Add pci.rel. | ||||
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 1 | -0/+5 |
| | | | | | * console/fb_vga.h, console/kd.h, console/ps2_drv.h, console/serial_mouse.c, console/serial_mouse.h: Remove CVS Log. | ||||
* | Remove CVS Log | Ralf Corsepius | 2005-10-17 | 8 | -294/+0 |
| | | | | | * shared/comm/i386_io.h, shared/comm/tty_drv.c, shared/comm/tty_drv.h: Remove CVS Log. | ||||
* | Remove | Ralf Corsepius | 2005-10-17 | 3 | -529/+0 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -128/+505 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * configure.ac: Remove shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. | ||||
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -94/+0 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -28/+94 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Regenerate. | Ralf Corsepius | 2005-10-17 | 1 | -4/+4 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 2 | -5/+14 |
| | | | | * Makefile.am: Install/preinstall headers from ../../arm/shared. | ||||
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 6 | -17/+105 |
| | | | | * Makefile.am: Install/preinstall headers from ../../i386/shared. | ||||
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -24/+256 |
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -306/+0 |
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 4 | -45/+105 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -58/+0 |
* | Remove shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -2/+1 |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -1/+6 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -45/+0 |
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 1 | -36/+91 |
* | Merge-in shared/ChangeLog. | Ralf Corsepius | 2005-10-16 | 1 | -0/+6 |
* | Remove shared/Makefile.am | Ralf Corsepius | 2005-10-16 | 1 | -2/+1 |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -1/+12 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -115/+0 |
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 1 | -17/+43 |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -1/+5 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -46/+0 |
* | 2005-10-06 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2005-10-06 | 6 | -12/+98 |
| | | | | | | | | | PR 833/bsps * irq/irq_asm.S: Currently, all (new exception) BSPs explicitely enable the FPU across the user ISR but DONT save/restore the FPU context. Any use of the FPU fron the user handler (e.g., due to GCC optimizations) result in corruption. The fix results in an exception in such cases (user ISR must explicitely save/enable/restore FPU). | ||||
* | Remove comments not really for 4.6 branch. | Joel Sherrill | 2005-10-05 | 1 | -253/+9 |
* | Added PR number. | Joel Sherrill | 2005-09-29 | 1 | -1/+1 |
* | 2005-09-29 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Thomas Doerfler | 2005-09-29 | 3 | -1/+41 |
| | | | | | | PR 649/bsps * ide/idecfg.c, configure.ac: added configuration items for primary/secondary IDE interface | ||||
* | Silently return to bootstrap PROM. | Eric Norum | 2005-09-19 | 1 | -1/+0 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+5 |
| | | | | | * network/if_hdlcsubr.c, network/network.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 2 | -2/+2 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 2 | -1/+5 |
| | | | | * network/network.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Correct my email address. | Ralf Corsepius | 2005-09-19 | 2 | -16/+16 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+4 |
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 3 | -3/+3 |
| | | | | * network/ne2000.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Regenerate. | Ralf Corsepius | 2005-09-19 | 1 | -1/+4 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 2 | -18/+3 |
| | | | | * libnetworking/pppd/Makefile.am: Use preinstall.am. | ||||
* | New. | Ralf Corsepius | 2005-09-19 | 1 | -0/+27 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+3 |
| | | | | | | * librdbg/src/servbkpt.c, librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c librdbg/src/servtsp.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Include <errno.h> instead of <sys/errno.h> | Ralf Corsepius | 2005-09-19 | 5 | -5/+5 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 2 | -40/+8 |
| | | | | | * 3c509/3c509.c: Remove [$]Log. Include <errno.h> instead of <sys/errno.h>. | ||||
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 3 | -3/+8 |
| | | | | | | * network/network.c: Remove #define KERNEL. Include <errno.h>. * Makefile.am: Add -D_KERNEL to network_CPPFLAGS. |
