* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Now links.
* irq/irq.c, startup/bspstart.c: Now compiles with gcc 4.x.
* configure.ac: Remove CFLAGS_DEBUG_V.
Don't AC_SUBST(CFLAGS_OPTIMIZE_V), AC_SUBST(CPU_CFLAGS).
* tod.c: Change type of RTC_Count to size_t.
* Makefile.am: Merge rtems-ctor.o into libbsp.a.
Fix building rtems-ctor.o and no-ctor.o.
* wrapup/Makefile.am: Remove rtems-ctor.o.
* tod/todcfg.c: size_t RTC_Count.
* clock/todcfg.c: size_t RTC_Count.
* libchip/rtc/rtc.h: size_t RTC_Count.
* include/commproc.h: The variable cpmp was not used anywhere but
console.c and was static in console.c, so should not have been in
this file as extern.
* bsp_specs: Conditionalize inclusion of crtend/crtn.
PR 736/pppd
* libnetworking/pppd/chat.c, libnetworking/pppd/demand.c,
libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c,
libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd
should not be static and should have a name more specific to pppd.
* Makefile.am: Fix typo.
* pc386/console/vgainit.c, pc386/wd8003/wd8003.c, shared/comm/uart.c:
Fix errors caught by gcc 4.x.
* console/vgainit.c: static graphic_on|off.
* Makefile.am: Use ../../shared/tod.h instead of include/tod.h.
* include/tod.h: Remove.
* console/config.c: Remove typos from 2005-01-04 changes.
* startup/linkcmds: Add rom section to remove warning.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am:
* mongoosev/Makefile.am, r46xx/Makefile.am, shared/Makefile.am,
tx39/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* m68040/Makefile.am, mcf5206/Makefile.am, mcf5272/Makefile.am,
shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am:
* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
* configure.ac: Pass CFLAGS to testsuites configure.
* aclocal/prog-cxx.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CXXFLAGS. Setup CXXFLAGS from CFLAGS.
* Makefile.am: Remove build-variant support.
* console/sci.c: Remove CVS Log.
* aclocal/rtems-flags.new: New (moved from ../aclocal).
* configure.ac: Pass CFLAGS to cpukit configure.
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* aclocal/env-rtemsbsp.m4:
Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS.
Cleanup comments.
* shared/Makefile.am: Fix typo.
* at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c,
mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
shared/arm920/mmu.c: Remove warnings.
* ppc403/tty_drv/tty_drv.c: Remove warnings.
* ChangeLog, startup/bspstart.c, tod/todcfg.c: Remove warnings.
* startup/linkcmds: Remove warnings.
* console/config.c: Remove warnings.
