<erik.ivanenko@utoronto.ca> and Eric Valette <valette@crf.canon.fr>.
Here is a cosmetic patch which corrects a few spelling problems in parts
written by me.
Apparently, I must have written these under the influence of ether (:-)
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
The RTEMS i386 stub in
c/src/lib/libbsp/i386/shared/comm/i386-stub.c
doesn't take advantage of some of the newer gdb remote features which
permits shorter and fewer packets.
Here is a patch which uses the 'T' response to report the registers
which gdb generally needs, and implements the 'P' request to set only
a single register. The general effect is to avoid sending all the
register contents back and forth between gdb and the stub every time
the stub stops. This also implements the 'D' request which handles
the gdb detach command, so you can cleanly quit out of the debugger
and leave the target board running.
I just happened across the sync_io support in
c/src/exec/score/cpu/unix/cpu.c
(is this documented anywhere?). That looked more useful than the
signal driven I/O I was using before, so I tried it. I ran across a
few bugs in the way it uses select.
Select changes its fd_set arguments, so you can't use global variables
for them. You have to copy them into local variables first.
If select returns -1 with errno set to EINTR, then it has not changed
any of the fd_sets. You can't start looking at them.
When clearing a descriptor, the code has the usual select off by one
error when setting sync_io_nfds.
I don't see how this code could ever have worked correctly.
I have appended a patch for the problems I found.
with libchip.
<jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me
know what was wrong and I supplied the code. :)
I noticed that in the 4.0.0-beta4a tar file, the file
c/src/lib/libbsp/i386/pc386/startup/linkcmds
was changed so that it no longer handles the .gnu.linkonce.r*
sections. The appended patch was applied to the file. I'm not sure
why. I think this patch should probably be backed out, although it's
not critical for the release.
recommendation.
ppc403 interrupt control libcpu component.
scripts (make/rtems.cfg)
Testing:
cosmetic things.
POSIX API.
in include file order.
<raguet@crf.canon.fr>.
now installed from the shared directory.
Thanks to Rod Barman for this one.
information to this file to be more like the gen68360.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
