* acinclude.m4: Remove arm_bare_bsp.
PR bsps/771
* configure.ac: Remove reference to arm_bare_bsp in
AC_CONFIG_SRCDIR. Use ../arm instead.
PR bsps/771
* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
* au1x00/include/au1x00.h: Converted types to C99 types.
PR 751/bsps
* startup/linkcmds: Cleanup.
* network/network.c: Added hardware initialization
code.
* at91rm9200/include/at91rm9200_emac.h: Cleanup.
* Makefile.am, configure.ac: New CPU.
* shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S: Added CPU32 support.
* au1x00/Makefile.am, au1x00/include/au1x00.h,
au1x00/vectorisrs/maxvectors.c, au1x00/vectorisrs/vectorisrs.c: New CPU.
* acinclude.m4: Added csb350 to list of BSPs.
* csb350/Makefile.am, csb350/README, csb350/bsp_specs,
csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c,
csb350/console/console-io.c, csb350/include/bsp.h,
csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S,
csb350/start/start.S, csb350/startup/bspclean.c,
csb350/startup/bspstart.c, csb350/startup/linkcmds,
csb350/timer/timer.c: New BSP.
* console/keyboard.h: Add include file and cleanup file header.
* startup/bspstart.c: Eliminate rtems_unsigned32.
* startup/bspstart.c: include <rtems/powerpc/powerpc.h>.
Use PPC_MINIMUM_STACK_FRAME_SIZE instead of
CPU_MINIMUM_STACK_FRAME_SIZE.
* start/start.S: include <rtems/powerpc/powerpc.h>.
* new-exceptions/cpu.c, rtems/powerpc/powerpc.h:
Remove CPU_MINIMUM_STACK_FRAME_SIZE.
Use PPC_MINIMUM_STACK_FRAME_SIZE instead.
* rtems/powerpc/powerpc.h: Add PPC_MINIMUM_STACK_FRAME_SIZE.
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS.
* aclocal/ppc.m4; Dynamically switch between {old|new} exceptions
depending upon presence of _OLD_EXCEPTIONS in CFLAGS.
* new-exceptions/cpu.c: Add CPU_MINIMUM_STACK_FRAME_SIZE.
* new-exceptions/cpu.c (_CPU_ISR_install_vector): New.
* old-exceptions/rtems/score/ppc_offs.h,
old-exceptions/ChangeLog, old-exceptions/README,
old-exceptions/TODO, old-exceptions/cpu.c,
old-exceptions/cpu_asm.S, old-exceptions/irq_stub.S,
old-exceptions/ppccache.c: New (Copied from
../../libbsp/powerpc/support/old_exception_processing)
* new-exceptions/ChangeLog, new-exceptions/cpu.c,
new-exceptions/cpu_asm.S: New (Copied from
../../libbsp/powerpc/support/new_exception_processing).
* cpu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value (Unify old/new
exception processing API).
* cpu.c (ppc_exception_vector_addr): Merge ppc603 and ppc603e cases.
* ppc403/console/console405.c: Rename round to spiBaudRound
(Conflict with C99). Make spiBaudRound static.
* mpc8260/mmu/mmu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value.
(Unify old/new-exception processing API).
* flashentry/flashentry.S: #include <rtems/powerpc/powerpc.h>
* startup/spurious.c: Merge ppc603 and ppc603e.
Remove digits (Unused).
* rtems/powerpc/powerpc.h: Remove mpc603e specific
PPC_TLB_*/PPC_IRQ_* defines. Use mpc603 specific defines on mpc603e.
* rtems/powerpc/powerpc.h: Remove PPC_ALIGNMENT.
* cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>.
* mpc8xx/mmu/mmu.c, rtems/powerpc/cache.h, rtems/powerpc/powerpc.h:
* cpu.c: Add _PPC_MSR_DISABLE_MASK.
* rtems/powerpc/powerpc.h: New header guard.
* rtems/powerpc/powerpc.h: New (Copy of
cpukit/score/cpu/powerpc/rtems/score/powerpc.h).
* mpc5xx/include/mpc5xx.h, mpc5xx/include/console.h,
mpc5xx/exceptions/raw_exception.h, mpc5xx/irq/irq.h,
mpc5xx/vectors/vectors.h, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.h,
mpc6xx/clock/c_clock.h, mpc8260/include/mpc8260.h,
mpc8260/include/console.h, mpc8260/include/cpm.h,
mpc8260/exceptions/raw_exception.h, mpc8260/include/mmu.h,
mpc8xx/include/mpc8xx.h, mpc8xx/include/console.h,
mpc8xx/include/cpm.h, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/mmu.h, ppc403/ictrl/ictrl.h,
ppc403/tty_drv/tty_drv.h, shared/include/io.h,
shared/include/mmu.h, shared/include/page.h,
shared/include/byteorder.h, shared/include/pgtable.h,
shared/include/cpuIdent.h,shared/include/spr.h,
shared/src/stackTrace.h: New header guards.
Improve in-line assembly.
* pci/pci.h: Remove contents that are duplicates of the pci.h in cpukit
and include rtems/pci.h for the base set of PCI functionality.
* Makefile.am: Fix typo in previous patch.
