path: root/c (follow)
* 2003-08-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-132-2/+8
| | | | | PR 451/bsps * pppd/system.h: Depend on TTY driver being in BSPs not simply i386.
* 2003-08-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-134-2/+12
| | | | | PR 451/bsps * startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
* 2003-08-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-133-0/+32
| | | | | * Makefile.am: Add bsp.pc.in * bsp.pc.in: New (pkgconfig support).
* 2003-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-112-0/+6
| | | | | PR 453/make_build * startup/linkcmds: Added .eh_frame
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1144-62/+90
| | | | * startup/Makefile.am: Remove USE_INIT_FINI.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-114-8/+10
| | | | | * bsp_specs: Remove -D__USE_INIT_FINI__. Remove *.cpp (Now unused).
* 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-112-1/+7
| | | | | | PR 369/filesystem * runtest: Add sample application to show the use of the DOSFS functions
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-11226-112/+568
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-113-6/+8
| | | | | * fileio/Makefile.am: Remove references to *.scn (Doesn't exist). * pppd/Makefile.am: Remove references to DOC* (Don't exist).
* 2003-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-094-0/+16
| | | | * Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-083-1/+7
| | | | | * include/rdbg/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU). * src/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-085-682/+22
| | | | | | | * lib/Makefile.am: New (Required by 'make dist'). * lib/ChangeLog: Remove. * lib/.cvsignore: Cleanup. * configure.ac: Reflect having added lib/Makefile.am.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-082-5/+35
| | | | | * configure.ac: Merge-in lib/libcpu/configure.ac. Merge-in lib/libbsp/configure.ac.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-082-3/+8
| | | | | * shmdr/Makefile.am: Reflect having merged configure.ac into ../../configure.ac.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-084-22/+14
| | | | | | | * include/Makefile.am: Remove (merged into Makefile.am). * gdbstub/Makefile.am: Remove (merged into Makefile.am). * Makefile.am: Reflect changes above. Reflect having merged ../configure.ac into ../../../configure.ac.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-086-89/+20
| | | | | | * configure.ac: Remove (Merged into ../../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../../configure.ac.
* 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-082-2/+4
| | | | * wrapup/Makefile.am (FAMILY_OBJS): Remove *exception_processing.
* 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-067-1/+833
| | | | | | | | PR 369/filesystem * Makefile.am, configure.ac: sample application to show the use of the DOSFS functions * fileio/Makefile.am, fileio/fileio.doc, fileio/init.c, fileio/system.h: New files.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-063-3/+11
| | | | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) -DUSE_ENHANCED_INTR_API from cpp. Remove cpp, old_cpp (now unused). * configure.ac: Add -DUSE_ENHANCED_INTR_API to bspopts.h.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-066-4/+15
| | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-0698-147/+245
| | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused).
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-066-3/+15
| | | | * bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* 2003-08-05 Till Strauman <strauman@slac.stanford.edu>Jennifer Averett2003-08-053-7/+16
| | | | | | | | PR 437/bsps * irq/irc.c: calls to bspIo/printk must not use '%i' format which is apparently not supported * pci/pci.c: calls to bspIo/printk must not use '%i' format which is apparently not supported
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-252-5/+9
| | | | * configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-252-7/+21
| | | | * configure.ac: Merge-in librdbg/configure.ac.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-2515-134/+83
| | | | | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am, include/Makefile.am, include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am, src/Makefile.am, src/i386/Makefile.am, src/i386/any/Makefile.am, src/m68k/Makefile.am, src/m68k/any/Makefile.am, src/powerpc/Makefile.am, src/powerpc/new_exception_processing/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-255-15/+25
| | | | | | * ide/Makefile.am, network/Makefile.am, rtc/Makefile.am, serial/Makefile.am: Add conditional LIBCHIP. Conditionally build include-dirs.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-252-12/+16
| | | | * network/if_fxp.c: Replace deprecated b* funcs by mem* funcs.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-252-5/+12
| | | | | * network/if_hdlcsubr.c: Use memcopy instead of bcmp, Use memcmp instead of bcmp.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-252-13/+29
| | | | | * configure.ac: Merge-in libnetworking/configure.ac. Merge-in parts of librdbg/configure.ac.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-259-89/+50
| | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * .cvsignore, Makefile.am, pppd/Makefile.am, rtems_servers/Makefile.am, rtems_telnetd/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-233-48/+22
| | | | | | PR 288/rtems * support/new_exception_processing/cpu.c: _ISR_Nest_level is now properly maintained and does not reside in SPRG0.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-183-7/+40
| | | | | | | PR 288/rtems * irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly maintained and any BSP which does not do so will trip a panic in the shared code.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-182-3/+11
| | | | | PR 288/rtems * startup/bspstart.c: _ISR_Nest_level is now properly maintained.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-186-8/+80
| | | | | | PR 288/rtems * irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly maintained.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-183-14/+17
| | | | | | | | PR 415/bsps * pci/detect_raven_bridge.c, startup/bspstart.c: This patch reverts enabling MCP interrupts for the motorola_powerpc BSPs. REASON: pci config space scanning (as e.g. done by the DEC Ethernet driver) would raise machine check exceptions.
* 2003-07-16 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-184-20/+69
| | | | | | | | | | | PR 428/bsps PR 432/bsps * bootloader/pci.c: Re-instated code that prevents remapping small IO regions, which if remapped would cause i8259 registers to move out from under the #define'd base addresses. * startup/bspstart.c: Reduced BAT2 PCI memory allocation to 256 megs, I incorrectly had extended it which would cause problems with PCI devices that defined prefetchable memory.
* 2003-07-16 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-183-0/+74
| | | | | | | PR 428/bsps PR 432/bsps * pci/pcibios.c, pci/pcibios.h: Added BSP_pci_Find_Device() which is copied from motorola_shared.
* 2003-07-18 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2003-07-182-75/+164
| | | | | | | | | PR 429/bsps PR 432/bsps * network/elnk.c: Due to a bug in the driver, if multiple packets are queued onto an elnk board, the ISR will deadlock the device with a tx complete interrupt. Lighter tx loads are not affected as they end up submitting single packets to the device.
* Fixed formatting so scripts work.Joel Sherrill2003-07-181-0/+1
* 2003-07-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-183-2/+7
| | | | | * src/rdbg.c: Use memset instead of bzero (deprecated). * src/servtsp.c: Ditto.
* 2003-07-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-172-1/+41
| | | | | | | | | | | | | | | | | | | | | | PR 433/tools * mips-stub.c: Patch from C. M. Heard <heard@pobox.com> described as: The purpose of the patch is to make the stub ignore all characters except '+' (ack) or '-' (nak) when it has transmitted a packet and expects an acknowledgment. Without the patch, putpacket() will retransmit each time it receives anything other than '+' when expecting an ack, and that, bitter experience has found, frequently results in the stub failing to sync up when initially attaching to gdb. I think that rtems users will notice significant improvement in the of the mips stub if this patch is incorporated in the distribution; certainly I did in my stand-aline environment. I should hasten to add that it is only an improvement and not a 100% cure for synchronization problems because '+' characters can (and do) during as message data, and it's still possible for these to be mistaken as acks. I have no idea how to fix that short of redesigning the gdb-remote protocol.
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-103-32/+9
| | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-107-67/+22
| | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am, ide/Makefile.am, network/Makefile.am, rtc/Makefile.am, serial/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-102-3/+20
| | | | | * configure.ac: Merge-in libchip/configure.ac. Merge-in optman/configure.ac.
* 2003-07-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0940-81/+78
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada.am: Add .adp to SUFFIXES. Remove c-compilation rule. * samples/base_sp/Makefile.am: Add init.$(OBJEXT). * samples/hello/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Add init.$(OBJEXT). * samples/ticker/Makefile.am: Remove VPATH. * sptests/sp01/Makefile.am: Add init.$(OBJEXT). * sptests/sp01/Makefile.am: Don't include */lib.am. * sptests/sp01/Makefile.am: Remove VPATH. * sptests/sp02/Makefile.am: Add init.$(OBJEXT). * sptests/sp02/Makefile.am: Don't include */lib.am. * sptests/sp03/Makefile.am: Add init.$(OBJEXT). * sptests/sp03/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Add init.$(OBJEXT). * sptests/sp04/Makefile.am: Don't include */lib.am. * sptests/sp04/Makefile.am: Remove EXPADA. * sptests/sp04/Makefile.am: Remove VPATH. * sptests/sp05/Makefile.am: Add init.$(OBJEXT). * sptests/sp05/Makefile.am: Don't include */lib.am. * sptests/sp06/Makefile.am: Add init.$(OBJEXT). * sptests/sp06/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Add init.$(OBJEXT). * sptests/sp07/Makefile.am: Don't include */lib.am. * sptests/sp07/Makefile.am: Remove EXPADA. * sptests/sp08/Makefile.am: Add init.$(OBJEXT). * sptests/sp08/Makefile.am: Don't include */lib.am. * sptests/sp09/Makefile.am: Add init.$(OBJEXT). * sptests/sp09/Makefile.am: Don't include */lib.am. * sptests/sp11/Makefile.am: Add init.$(OBJEXT). * sptests/sp11/Makefile.am: Don't include */lib.am. * sptests/sp12/Makefile.am: Add init.$(OBJEXT). * sptests/sp12/Makefile.am: Don't include */lib.am. * sptests/sp13/Makefile.am: Add init.$(OBJEXT). * sptests/sp13/Makefile.am: Don't include */lib.am. * sptests/sp14/Makefile.am: Add init.$(OBJEXT). * sptests/sp14/Makefile.am: Don't include */lib.am. * sptests/sp15/Makefile.am: Add init.$(OBJEXT). * sptests/sp15/Makefile.am: Don't include */lib.am. * sptests/sp16/Makefile.am: Add init.$(OBJEXT). * sptests/sp16/Makefile.am: Don't include */lib.am. * sptests/sp17/Makefile.am: Add init.$(OBJEXT). * sptests/sp17/Makefile.am: Don't include */lib.am. * sptests/sp19/Makefile.am: Add init.$(OBJEXT). * sptests/sp19/Makefile.am: Don't include */lib.am. * sptests/sp20/Makefile.am: Add init.$(OBJEXT). * sptests/sp20/Makefile.am: Don't include */lib.am. * sptests/sp21/Makefile.am: Add init.$(OBJEXT). * sptests/sp21/Makefile.am: Don't include */lib.am. * sptests/sp22/Makefile.am: Add init.$(OBJEXT). * sptests/sp22/Makefile.am: Don't include */lib.am. * sptests/sp23/Makefile.am: Add init.$(OBJEXT). * sptests/sp23/Makefile.am: Don't include */lib.am. * sptests/sp24/Makefile.am: Add init.$(OBJEXT). * sptests/sp24/Makefile.am: Don't include */lib.am. * sptests/sp25/Makefile.am: Add init.$(OBJEXT). * sptests/sp25/Makefile.am: Don't include */lib.am. * sptests/spsize/Makefile.am: Add init.$(OBJEXT). * sptests/spsize/Makefile.am: Don't include */lib.am. * tmtests/tm01/Makefile.am: Add init.$(OBJEXT). * tmtests/tm01/Makefile.am: Don't include */lib.am. * tmtests/tm02/Makefile.am: Add init.$(OBJEXT). * tmtests/tm02/Makefile.am: Don't include */lib.am. * tmtests/tm03/Makefile.am: Add init.$(OBJEXT). * tmtests/tm03/Makefile.am: Don't include */lib.am. * tmtests/tm04/Makefile.am: Add init.$(OBJEXT). * tmtests/tm04/Makefile.am: Don't include */lib.am. * tmtests/tm05/Makefile.am: Add init.$(OBJEXT). * tmtests/tm05/Makefile.am: Don't include */lib.am. * tmtests/tm06/Makefile.am: Add init.$(OBJEXT). * tmtests/tm06/Makefile.am: Don't include */lib.am. * tmtests/tm07/Makefile.am: Add init.$(OBJEXT). * tmtests/tm07/Makefile.am: Don't include */lib.am. * tmtests/tm08/Makefile.am: Add init.$(OBJEXT). * tmtests/tm08/Makefile.am: Don't include */lib.am. * tmtests/tm09/Makefile.am: Add init.$(OBJEXT). * tmtests/tm09/Makefile.am: Don't include */lib.am. * tmtests/tm10/Makefile.am: Add init.$(OBJEXT). * tmtests/tm10/Makefile.am: Don't include */lib.am. * tmtests/tm11/Makefile.am: Add init.$(OBJEXT). * tmtests/tm11/Makefile.am: Don't include */lib.am. * tmtests/tm12/Makefile.am: Add init.$(OBJEXT). * tmtests/tm12/Makefile.am: Don't include */lib.am. * tmtests/tm13/Makefile.am: Add init.$(OBJEXT). * tmtests/tm13/Makefile.am: Don't include */lib.am. * tmtests/tm14/Makefile.am: Add init.$(OBJEXT). * tmtests/tm14/Makefile.am: Don't include */lib.am. * tmtests/tm15/Makefile.am: Add init.$(OBJEXT). * tmtests/tm15/Makefile.am: Don't include */lib.am. * tmtests/tm16/Makefile.am: Add init.$(OBJEXT). * tmtests/tm16/Makefile.am: Don't include */lib.am. * tmtests/tm17/Makefile.am: Add init.$(OBJEXT). * tmtests/tm17/Makefile.am: Don't include */lib.am. * tmtests/tm18/Makefile.am: Add init.$(OBJEXT). * tmtests/tm18/Makefile.am: Don't include */lib.am. * tmtests/tm19/Makefile.am: Add init.$(OBJEXT). * tmtests/tm19/Makefile.am: Don't include */lib.am. * tmtests/tm20/Makefile.am: Add init.$(OBJEXT). * tmtests/tm20/Makefile.am: Don't include */lib.am. * tmtests/tm21/Makefile.am: Add init.$(OBJEXT). * tmtests/tm21/Makefile.am: Don't include */lib.am. * tmtests/tm22/Makefile.am: Add init.$(OBJEXT). * tmtests/tm22/Makefile.am: Don't include */lib.am. * tmtests/tm23/Makefile.am: Add init.$(OBJEXT). * tmtests/tm23/Makefile.am: Don't include */lib.am. * tmtests/tm24/Makefile.am: Add init.$(OBJEXT). * tmtests/tm24/Makefile.am: Don't include */lib.am. * tmtests/tm25/Makefile.am: Add init.$(OBJEXT). * tmtests/tm25/Makefile.am: Don't include */lib.am. * tmtests/tm28/Makefile.am: Add init.$(OBJEXT). * tmtests/tm28/Makefile.am: Don't include */lib.am. * tmtests/tm29/Makefile.am: Add init.$(OBJEXT). * tmtests/tm29/Makefile.am: Don't include */lib.am. * tmtests/tmck/Makefile.am: Add init.$(OBJEXT). * tmtests/tmck/Makefile.am: Don't include */lib.am. * tmtests/tmoverhd/Makefile.am: Add init.$(OBJEXT). * tmtests/tmoverhd/Makefile.am: Don't include */lib.am.
* 2003-07-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0918-44/+161
* CleanupRalf Corsepius2003-07-081-12/+0
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-1/+5
| | | | * console/console.c: Correct typo.
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-1/+6
| | | | | PR 418/ada * rtems.adb: Add missing all keyword to derefence pointer.
