* | Patch rtems-rc-19991011-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-10-26 | 2 | -6/+5 |
| | | | | fixes a minor configuration bug. | ||||
* | New ideas on test incorporated. | Joel Sherrill | 1999-10-26 | 1 | -9/+17 |
* | Modifications from Erik Ivanenko <erik.ivanenko@utoronto.ca> to add | Joel Sherrill | 1999-10-26 | 2 | -5/+17 |
| | | | | | proper Multiboot signature to pc386 BSP. This enables Grub to recognize the image. | ||||
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> to fix some | Joel Sherrill | 1999-10-26 | 1 | -28/+68 |
| | | | | reported bugs in the start code. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> to address the following problem | Joel Sherrill | 1999-10-25 | 2 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 1 | -0/+8 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Added notes for new test. | Joel Sherrill | 1999-10-25 | 1 | -0/+19 |
* | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 2 | -72/+72 |
| | | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 3 | -21/+24 |
| | | | | <raguet@crf.canon.fr> to use a local variable. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 4 | -144/+148 |
| | | | | process. | ||||
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 8 | -1/+332 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 4 | -1092/+1092 |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 1 | -1/+8 |
| | | | | the executive. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 3 | -3/+3 |
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
* | Removed warning. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Increased stack size of initialization thread. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Added rtems_semaphore_flush directive. | Joel Sherrill | 1999-10-21 | 3 | -1/+105 |
* | Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE to | Joel Sherrill | 1999-10-21 | 1 | -6/+6 |
| | | | | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads. | ||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 1 | -3/+7 |
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 2 | -0/+18 |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 1 | -1/+12 |
| | | | | Eric Norum. | ||||
* | Spacing. | Joel Sherrill | 1999-10-12 | 3 | -0/+3 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 19 | -163/+44 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 35 | -188/+140 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 3 | -3/+3 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 10 | -31/+301 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 31 | -140/+470 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 2 | -2/+2 |
* | Moved RTEMS error and association from libmisc to libc support to | Joel Sherrill | 1999-10-11 | 7 | -13/+13 |
| | | | | | avoid cyclic dependencies generated when moving packages to the top level. | ||||
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-11 | 14 | -1428/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Added as part of moving librdbg to its own top level package. This was | Joel Sherrill | 1999-10-11 | 6 | -0/+141 |
| | | | | done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbg | Joel Sherrill | 1999-10-11 | 12 | -131/+1081 |
| | | | | to its own top level package. | ||||
* | Now compiles for coff and elf. | Joel Sherrill | 1999-10-11 | 1 | -65/+185 |
* | New directive added -- rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 2 | -1/+77 |
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 2 | -0/+20 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-06 | 26 | -5265/+0 |
* | New file. | Joel Sherrill | 1999-10-06 | 4 | -0/+56 |
* | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 1999-10-06 | 37 | -27023/+0 |
* | Removed configure generated from configure.in | Joel Sherrill | 1999-10-06 | 37 | -81630/+0 |
* | Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 | Joel Sherrill | 1999-10-06 | 7 | -7/+7 |
| | | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings. | ||||
* | Modified to explicitly list all files as part of C_PIECES. | Joel Sherrill | 1999-10-06 | 1 | -1/+2 |
* | Corrected build order so it was not as dependent on the mpc750 check. | Joel Sherrill | 1999-10-06 | 2 | -6/+2 |
* | Added sections as required by C++ and ELF. | Joel Sherrill | 1999-10-06 | 4 | -3/+14 |
* | Added more sections and made minor modifications to let the linkcmds | Joel Sherrill | 1999-10-06 | 8 | -29/+54 |
| | | | | | work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors. | ||||
* | Fixed spelling error (FAMILLY --> FAMILY). | Joel Sherrill | 1999-10-06 | 1 | -4/+4 |
* | Invalid value used for baud rate per bug report from | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
| | | | | Jay Kulpinski <jskulpin@eng01.gdds.com>. | ||||
* | Removed ifdef on go32. | Joel Sherrill | 1999-10-05 | 1 | -1/+1 |
* | Removed go32 ifdefs | Joel Sherrill | 1999-10-05 | 2 | -6/+0 |
