* | build: Force warnings | Sebastian Huber | 2018-06-11 | 1 | -1/+1 |
| | | | | Always append some standard warning flags. | ||||
* | virtex5: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
| | | | | Updates #3425. | ||||
* | virtex4: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | virtex: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | tqm8xx: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | t32mppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -1/+1 |
* | ss555: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | qoriq: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -1/+1 |
* | qemuppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | psim: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mvme5500: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mvme3100: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mpc8260ads: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | mpc55xxevb: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | motorola_powerpc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+14 |
* | haleakala: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | beatnik: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | sparc64 BSPs: Hard define configuration required settings | Joel Sherrill | 2018-05-15 | 2 | -13/+3 |
* | no_cpu/no_bsp: Fix Makefile | Amaan Cheval | 2018-05-14 | 1 | -1/+1 |
* | sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h | Joel Sherrill | 2018-05-09 | 2 | -1/+13 |
* | smdk2410: Move define of CPU_S3C2410 to bspopts.h | Joel Sherrill | 2018-05-09 | 1 | -2/+5 |
* | bsp/pc386: Remove bin2boot support | Sebastian Huber | 2018-04-27 | 6 | -833/+0 |
| | | | | | Update #3408. Close #3410. | ||||
* | bsp/mcf5206elite: Do not install runtest script | Sebastian Huber | 2018-04-26 | 5 | -399/+0 |
| | | | | | | | Provide the runtest script only as a part of the sources. This simplifies the build system. Test support should be included in the RTEMS Tester. | ||||
* | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 2018-04-26 | 127 | -12218/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps: Remove unmaintained times files | Sebastian Huber | 2018-04-26 | 4 | -765/+0 |
* | bsp/sparc64: Move asm.S to bsps and rename | Sebastian Huber | 2018-04-26 | 3 | -19/+2 |
* | bsps/mips: Move liblnk to bsps | Sebastian Huber | 2018-04-26 | 5 | -248/+6 |
* | bsps/powerpc: Move bsp-start-zero.S to bsps | Sebastian Huber | 2018-04-26 | 5 | -119/+4 |
* | bsp/psim: Move align_h.S to bsps | Sebastian Huber | 2018-04-26 | 2 | -440/+1 |
* | bsp/haleakala: Move assembler files to bsps | Sebastian Huber | 2018-04-26 | 3 | -322/+2 |
* | bsp/qemuppc: Install linkcmds.base | Sebastian Huber | 2018-04-25 | 1 | -0/+1 |
| | | | | | Update #3339. Close #3411. | ||||
* | bsps/arm: Remove unused files | Sebastian Huber | 2018-04-25 | 13 | -17990/+0 |
* | bsps: Remove unused u-boot-generic-board-info.h | Sebastian Huber | 2018-04-25 | 1 | -132/+0 |
* | bsp/beagle: Move source files to bsps | Sebastian Huber | 2018-04-25 | 5 | -1621/+4 |
* | bsp/gumstix: Move fb.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -240/+1 |
* | bsp/lm3s69xx: Move ssi.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -171/+1 |
* | bsp/lpc176x: Move source files to bsps | Sebastian Huber | 2018-04-25 | 13 | -2426/+13 |
* | bsp/lpc24xx: Move source files to bsps | Sebastian Huber | 2018-04-25 | 10 | -1963/+9 |
* | bsp/lpc32xx: Move source files to bsps | Sebastian Huber | 2018-04-25 | 12 | -1239/+11 |
* | bsp/raspberrypi: Move source files to bsps | Sebastian Huber | 2018-04-25 | 7 | -1591/+4 |
* | bsp/smdk2410: Move smc.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -411/+1 |
* | bsp/tms570: Move cpucounterread.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -63/+1 |
* | bsp/mcf5206elite: Move nvram.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -174/+1 |
* | bsp/mrm332: Move interr.c to bsps | Sebastian Huber | 2018-04-25 | 1 | -50/+0 |
* | bsp/mrm332: Move spinit.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -97/+1 |
* | bsp/gen5200: Move source files to bsps | Sebastian Huber | 2018-04-25 | 7 | -3129/+4 |
* | bsp/haleakala: Move mmu_405.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -294/+1 |
* | bsp/beatnik: Move source files to bsps | Sebastian Huber | 2018-04-25 | 8 | -2721/+4 |
* | bsp/mvme3100: Move flashcfg.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -117/+1 |
* | bsp/mvme5500: Move source files to bsps | Sebastian Huber | 2018-04-25 | 4 | -545/+3 |
