and manage the interrupt sources like the other drivers. This
let use remove the ns16550_flush() routine.
Reworked transmit interrupt processing to remove ring buffer and
to mask the TX empty interrupt when it was not expected. This code
now uses termios to buffer TX output.
rather than doing repeated table lookups.
and to correctly set the TX active indicator.
than with a disable/enable pair.
Here's a small patch I forgot about from earlier in the week that removes
the hack fix Geoffroy had to use to get his BSP to work properly.
The termios osend() fix took care of this.
<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
of theses targets...
Here is a pure sh-rtems bug-fix patch.
The defines to enable the network to host conversion macros in
netinet/in.h were missing in sh/cpu.h
libchip, libio, and termios efforts.
Mask interrupts and save the current USP and MSP for all 68000 processor
variants.
Move some code around.
Tested all four ports. MC68681 as both polled and interrupt. Z8530 as
polled only.
This routines could be enhanced to determine if the SCC is present
since it appears from the DY-4 manual that a status registers indicates
this.
Deleted CSS interface related items.
Added items required to access DMA Control and Status Register so we
could figure out dynamically what the clock speed of the SCC really is.
RS-422 converter. We now see the TD light blink when typing
characters in HyperTerminal and when the board is reset we see
the RD light blink. This leads us to believe the cabling is
basically right.
returned a buffer which was not zero-filled, the reference count
was not correct. When the application exitted, the "lastClose"
handler was not being called to flush the output. This problem
had manifested itself on a variety of platforms.
The function rtems_termios_dequeue_characters() incorrectly incremented
the buffer pointers when it was invoked and there were no characters
in the ring buffer. This problem had also manifested itself on a
variety of platforms. The symptom was a strange repeating of the
data in the transmitter buffer when the transmitter serial device
was supposed to go idle.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
* c/src/lib/libbsp/sh/gensh1/scitab - NEW DIRECTORY
Location for building the table generated by shgen
* c/src/exec/score/tools/sh - NEW DIRECTORY - contains shgen
Most of it should be self-explanatory. I am a little bit concerned about
host-dependent features (getopt, floating point libraries). This
shouldn't disturb much now, as this tool should be compileable on all
gnu-based hosts and is only applicable for the sh. But in case somebody
complains, we may need to add autoconf checks or even restructurize
parts of rtems (IMO, rtems needs to be restructurized - remember the
"turning rtems upside down" issue).
