* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The
bug has been there all the time, but only hits the leon bsp since the
leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* cache/Makefile.am: Use 'CLEANFILES ='.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'CLEANFILES ='.
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'TMPINSTALL_FILES ='.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* hared/bootcard.c: Now process C++ global constructors
(_init) as part of the first task execution not in BSP space.
This depends on the toolset defining USE_INIT_FINI so you
have to have the right toolset version.
* src/threadhandler.c: Now process C++ global constructors
* lib/tftpDriver.c: Add limited chdir() support to the TFTP
filesystem.
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/powerpc/new_exception_processing/Makefile.am: Use
* shared/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am: fix path to shared/include/coverhd.h.
* src/i386/any/Makefile.am: Move MAINTAINERCLEANFILES before the
includes and use MAINTAINERCLEANFILES = to make automake-1.5 happy.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
* Makefile.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* src/imfs/Makefile.am: Revamp INCLUDES handling to make automake-1.5
happy.
* tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* minimum/Makefile.am: Fix comments to make automake-1.5 happy.
* sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* cdtest/Makefile.am: Remove LD_LIBS.
* psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile: Remove LD_LIBS.
* itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
