path: root/c (follow)
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-7/+5
| | | | * wrapup/Makefile.am: Don't preinstall libfs.a.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-6/+5
| | | | * src/Makefile.am: Don't preinstall libblock.a.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-1/+5
| | | | * configure.ac: Remove references to RTEMS_BSP.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-263-4/+13
| | | | | * configure.ac: Remove references to RTEMS_BSP. * src/Makefile.am: Add libposix.a.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-263-2/+11
| | | | | * configure.ac: Remove references to RTEMS_BSP. * src/Makefile.am: Add libitron.a.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-264-37/+20
| | | | | | | | * configure.ac: Remove references to RTEMS_BSP. * aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP. Allow building w/ --enable-multiprocessing --enable-multilib. * aclocal/enable-multiprocessing.m4: Eliminate RTEMS_HAS_MULTIPROCESSING.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-2/+5
| | | | * wrapup/Makefile.am: Remove libxdr.a.
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-2510-44/+44
| | | | | | | | | | | | | | | | | * configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-252-1/+5
| | | | * wrapup/Makefile.am: Fix stupid typo in previous patch.
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-253-4/+14
| | | | | | | * configure.ac: Add librpc. AC_PROG_RANLIB. * wrapup/Makefile.am: Add librpc. Use relative path to lib*.a for POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
| | | | * configure.ac: Remove librpc.
* 2002-06-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-254-155/+7
| | | | | | | * Per PR233, moved librpc to exec. Ralf will patch after move. The patches associated with this PR are out of date. * configure.ac, wrapup/Makefile.am: Modified. * librpc, librpc/ChangeLog: Removed.
* 2002-06-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-25140-36925/+73
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Per PR233, moved librpc to exec. Ralf will patch after move. The patches associated with this PR are out of date. ./include/rpc/.cvsignore, ./include/rpc/Makefile.am, ./include/rpc/auth.h, ./include/rpc/auth_des.h, ./include/rpc/auth_unix.h, ./include/rpc/clnt.h, ./include/rpc/des.h, ./include/rpc/des_crypt.h, ./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h, ./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h, ./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h, ./include/rpc/svc.h, ./include/rpc/svc_auth.h, ./include/rpc/types.h, ./include/rpc/xdr.h, ./include/.cvsignore, ./include/Makefile.am, ./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am, ./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x, ./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x, ./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x, ./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x, ./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h, ./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h, ./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x, ./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x, ./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x, ./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x, ./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x, ./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h, ./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x, ./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x, ./.cvsignore, ./Makefile.am, ./README_RTEMS, ./configure.ac, ./src/rpc/PSD.doc/.cvsignore, ./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms, ./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms, ./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms, ./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore, ./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am, ./src/rpc/README, ./src/rpc/auth_des.c, ./src/rpc/auth_none.c, ./src/rpc/auth_time.c, ./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c, ./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3, ./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c, ./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c, ./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c, ./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c, ./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3, ./src/rpc/des_crypt.c, ./src/rpc/des_soft.c, ./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c, ./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c, ./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c, ./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c, ./src/rpc/netname.c, ./src/rpc/netnamer.c, ./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c, ./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c, ./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c, ./src/rpc/publickey.3, ./src/rpc/publickey.5, ./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c, ./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c, ./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3, ./src/rpc/rpcdname.c, ./src/rpc/rstat.1, ./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c, ./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c, ./src/rpc/svc.c, ./src/rpc/svc_auth.c, ./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c, ./src/rpc/svc_raw.c, ./src/rpc/svc_run.c, ./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c, ./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c, ./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3, ./src/xdr/xdr.c, ./src/xdr/xdr_array.c, ./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c, ./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c, ./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c, ./src/.cvsignore, ./src/Makefile.am: Moved to exec.
* 2002-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-192-392/+4
| | | | * aclocal/subdirs.m4: Remove.
* 2002-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-184-24/+25
| | | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2002-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-182-1/+4
| | | | * Makefile.am: Remove commented out net-apps.
* 2002-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-182-4/+9
| | | | | * wrapup/Makefile.am: Use relative path to lib*.a for LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-174-94/+84
| | | | | | * Makefile.am: Merge src/Makefile.am. * configure.ac: Reflect changes above. * src/Makefile.am: Remove.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-0/+23
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Include $(top_srcdir)/automake/*.am. Use aclocal. * sapi/include/Makefile.am: Include $(top_srcdir)/automake/*.am. * sapi/Makefile.am: Include $(top_srcdir)/automake/*.am. * sapi/inline/Makefile.am: Include $(top_srcdir)/automake/*.am. * sapi/macros/Makefile.am: Include $(top_srcdir)/automake/*.am. * sapi/src/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/include/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/cpu/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/inline/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/macros/Makefile.am: Include $(top_srcdir)/automake/*.am. * score/src/Makefile.am: Include $(top_srcdir)/automake/*.am. * wrapup/Makefile.am: Include $(top_srcdir)/automake/*.am. * include/Makefile.am: Include $(top_srcdir)/automake/*.am. * rtems/include/Makefile.am: Include $(top_srcdir)/automake/*.am. * rtems/Makefile.am: Include $(top_srcdir)/automake/*.am. * rtems/inline/Makefile.am: Include $(top_srcdir)/automake/*.am. * rtems/macros/Makefile.am: Include $(top_srcdir)/automake/*.am. * rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-4/+4
| | | | * Include $(top_srcdir)/automake/*.am. Use aclocal/.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-1718-34/+34
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-1734-85/+175
| | | | | * Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-173-8/+14
| | | | | | * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-1714-39/+56
| | | | | | | | | | | | | | | | | * arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am. * kern/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * lib/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * machine/Makefile.am: Include $(top_srcdir)/../automake/*.am. * net/Makefile.am: Include $(top_srcdir)/../automake/*.am. * netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am. * nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am. * sys/Makefile.am: Include $(top_srcdir)/../automake/*.am. * vm/Makefile.am: Include $(top_srcdir)/../automake/*.am. * wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-176-17/+26
| | | | | | | | | * src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-174-8/+15
| | | | | | | * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-1712-20/+38
| | | | | | | | | * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * inline/Makefile.am: Include $(top_srcdir)/../automake/*.am. * macros/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-0/+38
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-alias.m4: Copied over from aclocal/. * aclocal/canonical-host.m4: Ditto. * aclocal/canonical-target-name.m4: Ditto. * aclocal/canonicalize-tools.m4: Ditto. * aclocal/check-bsp-cache.m4: Ditto. * aclocal/check-bsps.m4: Ditto. * aclocal/check-cpu.m4: Ditto. * aclocal/check-itron.m4: Ditto. * aclocal/check-multiprocessing.m4: Ditto. * aclocal/check-networking.m4: Ditto. * aclocal/check-newlib.m4: Ditto. * aclocal/check-posix.m4: Ditto. * aclocal/check-tool.m4: Ditto. * aclocal/enable-bare.m4: Ditto. * aclocal/enable-inlines.m4: Ditto. * aclocal/enable-itron.m4: Ditto. * aclocal/enable-multiprocessing.m4: Ditto. * aclocal/enable-networking.m4: Ditto. * aclocal/enable-posix.m4: Ditto. * aclocal/enable-rtemsbsp.m4: Ditto. * aclocal/env-rtemsbsp.m4: Ditto. * aclocal/env-rtemscpu.m4: Ditto. * aclocal/gcc-pipe.m4: Ditto. * aclocal/gcc-specs.m4: Ditto. * aclocal/multi.m4: Ditto. * aclocal/multilib.m4: Ditto. * aclocal/prog-cc.m4: Ditto. * aclocal/project-root.m4: Ditto. * aclocal/rtems-cpu-subdirs.m4: Ditto. * aclocal/rtems-debug.m4: Ditto. * aclocal/rtems-top.m4: Ditto. * aclocal/subdirs.m4: Ditto. * aclocal/sysv-ipc.m4: Ditto. * aclocal/tool-paths.m4: Ditto. * aclocal/version.m4: Ditto.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-1735-0/+1483
| | | | * copied over from aclocal/.
* 2002-06-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-154-5/+7
| | | | | | * Makefile.am: Remove multilib support. * configure.ac: Ditto. * sapi/Makefile.am: Ditto.
* 2002-06-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-152-1/+5
| | | | * rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg.
* 2002-06-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-151-0/+9
| | | | | | | | | * automake/compile.am: Copied over from automake/. * automake/lib.am: Copied over from automake/. * automake/local.am: Copied over from automake/. * automake/multilib.am: Copied over from automake/. * automake/subdirs.am: Copied over from automake/. * Makefile.am: Add automake/*.am.
* Add AUTOMAKE_FILES.Ralf Corsepius2002-06-151-0/+4
* Copied over from the automake/Ralf Corsepius2002-06-155-0/+385
* 2002-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-142-1/+8
| | | | | * startup/linkcmds: Fixed typo and added gnu.linkonce.t and gnu.linkonce.r sections.
* 2002-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-142-1/+4
| | | | * startup/linkcmds: Fixed typo.
* 2002-05-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-302-7/+8
| | | | | | | * configure.ac: Remove RTEMS_CHECK_POSIX_API. Remove RTEMS_ENABLE_POSIX. Remove RTEMS_CHECK_CUSTOM_BSP. Remove RTEMS_ENABLE_POSIX.
* 2002-05-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-303-17/+6
| | | | | * Makefile.am: Remove headers. Remove CHANGELOG. * configure.ac: Use AC_CONFIG_SRCDIR([pppd]).
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-293-5/+49
| | | | | * configure.ac: Add libnetworking. * wrapup/Makefile.am: Ditto.
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-2915-53/+63
| | | | | | | | | | | | | | | | | | Relocate c/src/libnetworking. * Makefile.am: Reflect moval. * machine/Makefile.am: Ditto. * net/Makefile.am: Ditto. * lib/Makefile.am: Ditto. * netinet/Makefile.am: Ditto. * vm/Makefile.am: Ditto. * libc/Makefile.am: Ditto. * sys/Makefile.am: Ditto. * arpa/Makefile.am: Ditto. * nfs/Makefile.am: Ditto. * kern/Makefile.am: Ditto. * rtems/Makefile.am: Ditto. * configure.ac: Dittp. * wrapup/Makefile.am: Ditto. Remove references to networking apps.
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-292-1/+5
| | | | * Makefile.am: Reflect moving libnetworking. Use libnetapps instead.
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-29265-75145/+11
| | | | | | | Move networking libraries to c/src/exec/libnetworking * configure.ac: Reflect Moval. * Makefile.am: Reflect Moval. * wrapup/Makefile.am: Reflect Moval.
* 2001-05-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-281-0/+5
| | | | * ChangeLog: Corrected spacing.
* 2001-05-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-282-1/+6
| | | | | * Per PR31, moved mvme16x_hw.h to shared/mvme. * include/Makefile.am: Modified to reflect movement.
* 2001-05-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-283-266/+9
| | | | | | * Per PR31, moved mvme16x_hw.h to shared/mvme. * include/Makefile.am: Modified to reflect movement. * include/mvme16x_hw.h: Moved to shared/mvme.
* 2002-05-28 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-282-1/+6
| | | | | * rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP since it is now multilib'ed.
* 2002-05-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-2890-16227/+0
| | | | * libblock, libfs moved to src/exec for multilib'ing.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-281-0/+4
| | | | * Makefile.am: Remove libblock, libfs.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-283-4/+4
| | | | * configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-283-1/+17
| | | | | * configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX). * wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
