* rtems/score/cpu.h: Account for name change.
* rtems/score/unixtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/sparctypes.h: Removed.
* rtems/score/shtypes.h: Removed.
* rtems/score/ppctypes.h: Removed.
* rtems/score/or32types.h: Removed.
* rtems/score/or16types.h: Removed.
* rtems/score/no_cputypes.h: Removed.
* rtems/score/mipstypes.h: Removed.
* rtems/score/m68ktypes.h: Removed.
* rtems/score/i960types.h: Removed.
* rtems/score/i386types.h: Removed.
* rtems/score/hppa1.1types.h: Removed.
* rtems/score/h8300types.h: Removed.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/a29ktypes.h: Removed.
* include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal
and bdbuf_buffer.avl.cache to signed char instead of char.
* Per PR126, configuration structures now match docs.
* include/rtems/config.h: Use public data types.
* bootloader/Makefile.am: Use AM_CCASFLAGS instead of AM_ASFLAGS.
* include/rtems/rtems/config.h: Use public data types.
* configure.ac: Update, remove code rott.
* libc/rcmd.c: Replace __rtems w/ __rtems__.
* Per PR147 addressed problems when reseting and inserting a timer
into a timer chain that did not honor time passage since the last
time the timer server was scheduled and the new insertion.
* include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up
the "reset server" routine into a set of very specific routines
that allowed the server to be unscheduled, timer chains to be
"synchronized" with the current time before inserting a new timer.
* sp31/sp31.scn, sp31/task1.c: Added test code to detect this case.
* tbr/Makefile.am: New file.
* tbr/.cvsignore: New file.
* tbr/tbr.c: New file.
* tbr/tbr.h: New file.
* configure.ac: Add tbr subdir.
* Makefile.am: Add tbr subdir.
* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE).
Add BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Add tbr.
* cpu.c: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.c).
* cpu.h: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.h).
* sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* PR132 requested some tinkering ot lower memory.
* include/confdefs.h: Lowered footprint of device driver table
and statically configure user extensions. Now if no static
extensions are configured, then the table is not instantiated.
* Side-effect of PR132.
* sp21/system.h: Now must explicitly request NULL driver.
* cpu.c: Define fix_syscall_errno() to nothing so MP links.
* src/dosfs/fat_file.c: Remove bsp.h.
fat_file_write(.. const char*buf ..).
* src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
* include/bsp.h: include <libcpu/cpu.h>.
* console/console.c: Remove unused variable console_open_count.
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS.
* syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
* delay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
