* | Now generating this file with autoconf to avoid having to embed so | Joel Sherrill | 1997-12-22 | 1 | -0/+221 |
| | | | | much target specific information in the script. | ||||
* | Changed invocation of size_rtems to match new autoconf'ed version. | Joel Sherrill | 1997-12-22 | 1 | -1/+1 |
* | Changed from .align to .p2align to avoid differences in meaning of | Joel Sherrill | 1997-12-22 | 1 | -6/+6 |
| | | | | | .align between i386-rtems (real number on .align) and i386-go32-rtems (power of 2). | ||||
* | Added lines to build sizeinfo.txt which is automatically generated now | Joel Sherrill | 1997-12-22 | 1 | -0/+3 |
| | | | | by size_rtems. | ||||
* | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1997-12-20 | 19 | -38/+38 |
| | | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | ||||
* | Update from Eric Norum to include C++ support. | Joel Sherrill | 1997-12-20 | 3 | -239/+281 |
* | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1997-12-19 | 19 | -19/+19 |
| | | | | switch which lets the user specify a different linker script. | ||||
* | Pass in PROJECT_HOME so rtems-glom can run if the make is invoked | Joel Sherrill | 1997-12-16 | 2 | -4/+8 |
| | | | | just in this directory. | ||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 461 | -480/+1868 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Added missing dependency for libmisc.a based on a bug report by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -0/+2 |
* | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -2/+2 |
* | Changed the uuencode line to work better with VPATH setups. | Joel Sherrill | 1997-12-06 | 1 | -2/+2 |
* | Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined. | Joel Sherrill | 1997-12-06 | 2 | -4/+4 |
| | | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find. | ||||
* | Reworked mkdir line to invoke smaller lines. | Joel Sherrill | 1997-12-04 | 1 | -1/+4 |
* | Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano | Joel Sherrill | 1997-12-01 | 32 | -0/+4896 |
| | | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/). | ||||
* | Since test suite Makefiles are not always generated, use wildcard | Joel Sherrill | 1997-11-30 | 1 | -4/+3 |
| | | | | to determine which directories to descend into. | ||||
* | Corrected call to rtems_termios_open. | Joel Sherrill | 1997-11-30 | 1 | -1/+2 |
* | Corrected comment. | Joel Sherrill | 1997-11-30 | 2 | -6/+1 |
* | Do not generate make/os at install point. | Joel Sherrill | 1997-11-30 | 1 | -2/+1 |
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 4 | -2/+12 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Patch from Chris Johns to filter out the trace bit on CPU models | Joel Sherrill | 1997-11-29 | 1 | -2/+5 |
| | | | | which have hardware support for a separate interrupt stack. | ||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1997-11-18 | 1 | -0/+45 |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 2 | -0/+10 |
* | Removed warnings. | Joel Sherrill | 1997-11-18 | 2 | -1/+6 |
* | Added argument as required by new version of termios_open. | Joel Sherrill | 1997-11-18 | 1 | -2/+4 |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 2 | -2/+12 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 6 | -178/+427 |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 3 | -3/+3 |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 2 | -0/+2 |
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 2 | -2/+16 |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 5 | -29/+15 |
* | Switched to new style for read support routine. | Joel Sherrill | 1997-10-23 | 1 | -10/+6 |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 3 | -1/+205 |
* | Added console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -6/+15 |
* | Overhauled console driver to use termios and to simultaneously support | Joel Sherrill | 1997-10-23 | 3 | -149/+170 |
| | | | | both ports. | ||||
* | Added prototype for console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -0/+8 |
* | fixed comment | Joel Sherrill | 1997-10-23 | 2 | -4/+2 |
* | New termios.c from Eric Norum. | Joel Sherrill | 1997-10-23 | 5 | -1202/+1296 |
| | | | | Added new entry point to add in per physical port resource requirements. | ||||
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 |
| | | | | for the returned old_isr_handler was non-NULL. | ||||
* | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 1997-10-21 | 8 | -18/+18 |
| | | | | unsigned numbers. | ||||
* | Fixed endian problem in printing object names. | Joel Sherrill | 1997-10-21 | 2 | -0/+10 |
* | Converted to termios style device driver. | Joel Sherrill | 1997-10-21 | 1 | -265/+144 |
