* startup/bspclean.c: New file to explicitly invoke _sys_exit().
* README: Updated.
* libc/linkaddr.c: Initialized variable to remove warning.
* modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations
conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables
that were not used because the code using them was commented out.
Removed totally unused variables.
* modem/pppcompress.c: Added parentheses to avoid warnings.
* pppd/pppmain.c: Removed numerous warnings.
* shared/src/cache_aligned_malloc.c: Added include of <stdlib.h>
to eliminate warnings.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* libc/mallocfreespace.c: Name of routine is
rtems_region_get_information() NOT region_get_information().
* libc/unmount.c: Removed unused variable.
* console/console.c: Removed console_reserve_resources().
* gnatsupp/gnatsupp.c: Added prototype to eliminate warning.
* README: Updated to reflect status.
* startup/linkcmds: Added .ctor and .dtor sections to no avail.
* include/bsp.h: Removed incorrect error case.
* console/consolereserveresources.c: Removed code NOT file (YET).
* startup/bspstart.c: Removed call of console_reserve_resources().
* wrapup/Makefile.am: Corrected typo so BSP components are picked up.
* comm/console.c: Added casts to eliminate warnings.
* comm/console.c (console_reserve_resources): Removed.
* startup/bspstart.c: Removed unused variables ramSpace and _end.
Added prototype for initialize_monitor_handles().
* startup/syscalls.c: Added casts and removed unused variables to
eliminate warnings.
* Makefile.am: Add include of bsp.am. Add clock subdirectory.
* configure.in: Add clock subdirectory.
* include/Makefile.am: Add coverhd.h.
* cpu.c: Added include of <rtems/rtems/cache.h> to eliminate warning.
* rtems/score/cpu.h: When mips ISA level is 1, registers in the
context should be 32 not 64 bits.
* src/regiongetinfo.c: Removed unused variable to eliminate warning.
* src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to
eliminate warning.
* console/inch.c, console/keyboard.c, console/pc_keyb.c,
console/vt.c, include/bsp.h: Correct incorrect interrupt level
handling in new keyboard management code. Correct
BSP_poll_char initialization routine.
* start/start.S, startup/bspstart.c: Correct when the video is
initialized.
* timer/timer.c (Calibrate_1ms_loop): Address problem where this
did not work correctly on all PC speeds. The new calibrate routine
has been tested on Pentium 166, pentium II 200, pentium III
300 Mhz and does work as expected.
* pc386/console/console.c, pc386/console/serial_mouse.c,
pc386/console/vgainit.c, shared/comm/tty_drv.c: Remove warnings.
* console-polled.c: Remove warnings.
* include/rtems/posix/cond.h: #if 0'ed out prototype of
_POSIX_Condition_variables_Get to avoid conflict with macro
implementation.
* configure.in: Removed error check for enabling macros with
either POSIX or ITRON API.
* macros/rtems/score/coresem.inl: Removed comments since convention
calls for comments to be in inline versin.
* macros/rtems/score/object.inl (Objects_Get_local_object): Fixed
style to use _ prefix on variable names and use parentheses.
* macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
* Added macro support to ITRON API. This is known to compile.
* Makefile.am: Added macros directory.
* configure.in: Removed error check for enabling macros.
* macros/.cvsignore, macros/Makefile.am,
macros/rtems/.cvsignore, macros/rtems/Makefile.am,
macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am,
macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl,
macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl,
macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl,
macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl,
macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* Added macro support to POSIX API. This is known to compile.
* macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl,
macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl,
macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl: New files.
* rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines
since you cannot have prototypes for macros.
* macros/rtems/posix/Makefile.am: Added files.
* erc32sonic/Makefile.am: Only compile this if networking is enabled.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* cache/Makefile.am: Removed automake warning by introducing a
simple variable.
* src/msgqsubmit.c: Modified multiprocessing conditional so
this would compile with both macros and inlines.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
* inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs().
* README: Updated to reflect current status. Misaligned reference
during initialization may be compiler problem.
* console/console-io.c: Added support for printk().
* startup/linkcmds: Reserve 512K for RTEMS Workspace.
* General effort to make things compile with macros not inlines
* inline/rtems/score/coremutex.inl: Added comment indicating
for macros there is another copy of
_CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c.
* src/coremutexseize.c: Added body of
_CORE_mutex_Seize_interrupt_trylock() for macro case.
* macros/rtems/score/coremutex.inl: Added prototype for
_CORE_mutex_Seize_interrupt_trylock() since there is a real
body when macros are enabled.
* macros/rtems/score/coresem.inl: Added macro implementation of
_CORE_semaphore_Seize_isr_disable.
* macros/score/Makefile.am: Fixed typos.
* rtems/score/address.inl: Correct macro implementation of
_Addresses_Is_aligned() so it would compile.
* macros/rtems/score/coremsg.inl: Added closing parentheses.
* cpu_asm.S: Changed "_CPU_Ccontext_switch_restore: typo to
correct name of _CPU_Context_switch_restore. Added dummy
version of exc_utlb_code() so applications would link.
* include/rtems/Makefile.am: Added termiostypes.h.
* libc/Makefile.am: Removed termiostypes.h.
* libc/termios.c: Changed include of "termiostypes.h" to
<rtems/termiostypes.h> since that is an RTEMS specific header file.
* modem/ppp_tty.c: Changed to include <rtems/termiostypes.h> since
* sys/ttycom.h: Moved to lib/include/sys.
* Makefile.am: Modified to reflect above.
* include/sys/ttycom.h: New file -- moved from libnetworking/sys.
* src/imfs/memfile.c: Bug report from Sturniolo Jose
<jsturnio@nec.com.ar> where NULL pointer was dereferenced.
* libc/getcwd.c: Ensure _closedir(dir) is called even on
error exit from the routine.
* src/heapallocate.c: Do not allow the size to overflow when
adjusting it. A test allocated a stack of -1 (~0). This
actually resulted in a stack being allocated but with a
size of 0xb. The allocator did not test the size to see if
it rolled through 0 and so allowed the allocation to happen, the
thread to get created. The task crashed as you would expect.
* README, sim68000.setup, clock/clockdrv.c: Modified to add
support for timer as clock tick source. Compiles but untested.
* libc/termiostypes.h: New file -- missed in earlier commits.
* libc/res_init.c: Fix typo - adding missing # on include.
* cache/cache.h: Fix reference to MC68040 and put in stubs
for missing support routines. The functionality of these
routines needs to be addressed.
* startup/linkcmds: Fix typo and add extra 0 to base address.
Now runs until printf() tries to put a character and then
it locks up checking a status bit that does not change.
