* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 2 | -1/+5 |
* | 2006-04-12 Konrad Eisele <konrad@gaisler.com> | Joel Sherrill | 2006-04-12 | 2 | -0/+6 |
| | | | | * include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define. | ||||
* | Add default exception handler. | Eric Norum | 2006-04-11 | 2 | -1/+57 |
* | Fix formatting. | Joel Sherrill | 2006-04-05 | 1 | -2/+2 |
* | 2006-04-05 Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru> | Joel Sherrill | 2006-04-05 | 2 | -4/+17 |
| | | | | * mpc6xx/clock/c_clock.c: Now works with MPCI SHM driver. | ||||
* | 2006-04-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-04-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove bogus CFLAGS_OPTIMIZE_V. | ||||
* | Add missing reset cause bit. | Eric Norum | 2006-03-24 | 2 | -0/+5 |
* | 2006-03-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-22 | 6 | -0/+27 |
| | | | | * include/.cvsignore: New file. | ||||
* | 2006-03-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-17 | 2 | -6/+17 |
| | | | | | | * shared/interrupts/vectorexceptions.c: Merger with submission from Bruce Robinson <brucer@pmccorp.com>. Make some arrays static const. | ||||
* | Misc. cosmetics. | Ralf Corsepius | 2006-03-17 | 17 | -77/+24 |
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 79 | -79/+0 |
* | Regenerate. | Ralf Corsepius | 2006-03-16 | 1 | -0/+14 |
* | Cosmetics. | Ralf Corsepius | 2006-03-16 | 1 | -8/+0 |
* | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 3 | -0/+46 |
| | | | | * Makefile.am, configure.ac: Reflect addition of rm52xx, tx49. | ||||
* | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+8 |
| | | | | | | | | * rm52xx/include/rm5231.h, rm52xx/vectorisrs/maxvectors.c, rm52xx/vectorisrs/vectorisrs.c, tx49/include/tx4925.h, tx49/include/tx4938.h, tx49/vectorisrs/maxvectors.c, tx49/vectorisrs/vectorisrs.c: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | ||||
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 7 | -0/+543 |
* | Regenerate. | Ralf Corsepius | 2006-03-16 | 1 | -2/+6 |
* | AC_CONFIG_SRCDIR(csb350). | Ralf Corsepius | 2006-03-16 | 1 | -1/+1 |
* | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -1/+3 |
| | | | | | * configure.ac: AC_CONFIG_SRCDIR(csb350). * acinclude.m4: Regenerate. | ||||
* | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+58 |
* | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 1 | -48/+1 |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 23 | -0/+4984 |
* | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 2 | -100/+2 |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>) | Ralf Corsepius | 2006-03-16 | 21 | -0/+3722 |
* | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+62 |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 28 | -0/+4472 |
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 2 | -7/+1 |
| | | | | * README: Remove (obsolete). | ||||
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+4 |
| | | | | * acinclude.m4: Remove p4000. | ||||
* | Remove (abandoned). | Ralf Corsepius | 2006-03-16 | 24 | -3351/+0 |
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 26 | -13/+66 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 4 | -3/+8 |
| | | | | | * startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add .gnu.linkonce.b.* section. | ||||
| | | | | | * startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add .gnu.linkonce.b.* section. | ||||
| | | | | | * startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 2 | -1/+5 |
| | | | | * shared/startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 6 | -4/+16 |
| | | | | * startup/linkcmds, startup/linkcmds.dl: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 3 | -2/+9 |
| | | | | | * startup/linkcmds, startup/linkcmds.pm520: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-07 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> | Joel Sherrill | 2006-03-07 | 3 | -7/+176 |
| | | | | | | | PR 853/filesystem * libchip/ide/ata.c, libchip/ide/ide_controller.c: The ata driver should be modified to support the new exception scheme and to use the handle parameter. | ||||
* | Add PRs. | Joel Sherrill | 2006-03-07 | 1 | -5/+5 |
* | 2006-03-07 Lars Munch <lars@segv.dk> | Joel Sherrill | 2006-03-07 | 2 | -4/+11 |
| | | | | | | | | | | * at91rm9200/clock/clock.c: The clock tick is not very precise on at91rm9200. The attached patch improves the situation by: (1) Not reloading the "period interval timer" register in the interrupt handler since this is done automatically. (2) Use integer rounding in the calculation of the "period interval timer" register value to get as close as posible to the CONFIGURE_MICROSECONDS_PER_TICK value. | ||||
* | Changes from Daron Chabot | Eric Norum | 2006-02-23 | 3 | -46/+95 |
* | 2006-02-13 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2006-02-14 | 3 | -0/+309 |
| | | | | | | * shared/startup/panic.c, shared/startup/probeMemEnd.c: added code for BSPs to use: panic using printk() to display reason. probeMemEnd() to determine memory size by probing. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -1/+5 |
| | | | | * src/rtemsStatusCode.cc: Fix warnings. | ||||
| | | | | * clock/clockdrv.c: Correct path to clockdrv_shell.c | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -6/+8 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 8 | -8/+24 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 46 | -82/+168 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -12/+14 |
| | | | | | * startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -12/+11 |
| | | | | | * startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add sections required by newer gcc versions. |
