* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, include/bsp.h, startup/linkcmds: Use top level shared
* shared/bspgetworkarea.c: Removed.
* Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.sim: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.ram,
startup/linkcmds.rom: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am: Use top level shared bsp_get_work_area() implementation.
* shared/include/nvram.h: Fix typo.
* clockdrv_shell.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* bspstart.c: New file.
* clock/clock.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* clock/ckinit.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* startup/bspstart.c: Removed.
* shared/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* clock/ckinit.c: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h. All
SuperH BSPs now share a common bsp_start() implementation.
* shared/clock/clock.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* irq/FPGA.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in
its own file and rely on BSP Framework to perform more
initialization. Remove unnecessary includes of rtems/libio.h and
* startup/bspgetworkarea.c: New file.
* startup/bspstart.c: Remove unnecessary includes of
* clock/clock.c, startup/bspstart.c: Remove unnecessary includes of
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* clock/ckinit.c, startup/bspstart.c: Remove unnecessary includes of
* shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its
own file and rely on BSP Framework to perform more initialization.
Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* shared/m68kpretaskinghook.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
use of bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization. Remove unnecessary includes of
* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
* console/debugio.c, startup/bsppredriverhook.c: New files.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c: Add
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c,
startup/linkcmds: Add use of bsp_get_work_area() in its own file and
* Makefile.am, clock/ckinit.c, startup/bspstart.c, startup/linkcmds:
Add use of bsp_get_work_area() in its own file and rely on BSP
Framework to perform more initialization. Remove unnecessary includes
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds,
startup/linkcmds_ROM: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization. Remove
* startup/bsppredriverhook.c: New file.
* Makefile.am, configure.ac, startup/bspstart.c: Add use of
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Add use of
* Makefile.am, configure.ac, start/start.S, startup/linkcmds: Add use
* Makefile.am, configure.ac, include/bspopts.h.in, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Add use of
* Makefile.am, configure.ac, start/start.S: Add use of
* clock/clock.c, startup/bspstart.c, startup/linkcmds: Add use of
* startup/linkcmds: Remove unused _HeapBase.
* shared/startup/bspstart.c, shared/startup/pretaskinghook.c: Add use
* shared/startup/bspgetworkarea.c: New file.
* Makefile.am, configure.ac, include/bsp.h, include/bspopts.h.in,
startup/bspstart.c, startup/linkcmds: Add use of bsp_get_work_area()
in its own file and rely on BSP Framework to perform more
initialization.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Add use
* startup/bspstart.c: Add use of bsp_get_work_area() in its own file
