* aclocal/env-rtemsbsp.m4: Remove AM_CONDITIONAL MULTILIB.
* configure.ac: Remove AM_CONDITIONAL MULTILIB.
* Makefile.am: Remove BARE_CPU_MODEL.
* configure.ac: Remove reference to bare BSP.
Simplify RTEMS_BSP_LIST setup.
* configure.ac: Remove cfg_dir.
* configure.ac: Remove -std=c99 -fasm.
Remove AM_CONDITIONAL LIBCHIP.
* libchip/Makefile.am, wrapup/Makefile.am:
* make/custom/eZKit533.cfg: Switch to compiling at O2.
* startup/bspstart.c, startup/misc.c:
Fixed compiler warnings by adding prototypes to function
declarations and moving extern declarations to global scope.
* startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP which is NULL in this case. This pointer could
be passed on to 'boot_card()' as it is done by other BSPs.
This 'start/start.S' file however, passes a NULL pointer
directly to boot_card() (w/o ever calling save_boot_params()).
* start/start.S, startup/bspstart.c:
saved by the BSP and pass this pointer on to 'boot_card()'.
* shared/startup/pgtbl_setup.c: Fixed compiler warnings
(added prototypes to function declarations etc.)
* shared/start/start.S, shared/startup/bspstart.c:
* network/tsec.c: fixed compiler warnings.
* shared/misc/m68kidle.c: somehow this change was never committed, sorry.
* clock/rtc.c: Add initializer (Silence warning).
* startup/bspstart.c: Add missing prototype.
* shared/startup/linkcmds: Add __SBSS_END__ and __SBSS2_END__.
* configure.ac: Pick up make/custom/*.
* aclocal/check-custom-bsp.m4: Adapt to changes to configure.ac.
* network/tsec.c: rtems 4.10 no longer allows simple binary
semaphores to have priority inheritance attribute; use ordinary
binary semaphore instead.
*network/if_tsec_pub.h, network/tsec.c: Enhanced low-level
API allowing the user to selectively enable/disable/acknowledge
interrupts and to install their own ISR (rather than having
the driver posting an event to a single task).
* startup/bspstart.c: Fix warnings.
* start/start.S, startup/bspstart.c: Fix warnings.
* console/console.c: Fix warning.
* make/custom/tqm8xx.inc: New (Renamed from tqm8xx.cfg).
* make/custom/tqm8xx.cfg: Removed.
* make/custom/pghplus.cfg, make/custom/tqm8xx_stk8xx.cfg:
Include make/custom/tqm8xx.inc.
* make/custom/mbx8xx.inc: New (Renamed from mbx8xx.cfg).
* make/custom/mbx8xx.cfg: Removed.
* make/custom/mbx821_001.cfg, make/custom/mbx821_002b.cfg,
make/custom/mbx821_002.cfg, make/custom/mbx860_001b.cfg,
make/custom/mbx860_002.cfg, make/custom/mbx860_005b.cfg,
make/custom/mbx860_1b.cfg:
Include make/custom/mbx8xx.inc.
* make/custom/gen83xx.inc: New (Renamed from gen83xx.cfg).
* make/custom/gen83xx.cfg: Removed.
* make/custom/hsc_cm01.cfg, make/custom/mpc8313erdb.cfg,
make/custom/mpc8349eamds.cfg:
Include make/custom/gen83xx.inc.
* make/custom/gen5200.inc: New (Renamed from gen5200.cfg).
* make/custom/gen5200.cfg: Removed.
* make/custom/brs5l.cfg, make/custom/icecube.cfg,
make/custom/pm520_cr825.cfg, make/custom/pm520_ze30.cfg:
Include make/custom/gen5200.inc.
* make/custom/genmcf548x.inc: New (Renamed from genmcf548x.cfg).
* make/custom/genmcf548x.cfg: Removed.
* make/custom/COBRA5475.cfg, make/custom/m5484FireEngine.cfg:
Include make/custom/genmcf548x.inc.
* make/custom/lpc24xx.inc: New (Renamed from lpc24xx.cfg).
* make/custom/lpc24xx.cfg: Removed.
* make/custom/lpc24xx_ea.cfg, lpc24xx_ncs_ram.cfg,
make/custom/lpc24xx_ncs_rom_ext.cfg,
make/custom/lpc24xx_ncs_rom_int.cfg:
Include make/custom/lpc24xx.inc.
* shared/irq/idt.c: Check is the irq handlers are present before
calling.
* shared/comm/i386-stub-glue.c: Revert the change of 2009-05-06 as
the handlers need to be present. Fixed the warnings.
* configure.ac: Default to having PSC8 mezzanine so code builds
all the time.
* startup/bspstart.c: Calibrated clock using an VMEBus controlled
discrete pulsed at a 20ms rate.
* mpc6xx/mmu/bat.c: Resolved bug: It is not an overlap if the batindex
being set is the batindex of the overlap.
* startup/bspstart.c: Remove nested externs.
* shared/startup/zerobss.c: Remove nested externs.
* wrapup/Makefile.am: Remove AM_CONDITIONAL HAS_LIBBSP.
* configure.ac: Remove AM_CONDITIONAL HAS_LIBBSP.
