* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -2/+0 | |
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 | |
| | | | | * configure.ac: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | |||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+6 | |
| | | | | | | * aclocal/enable-bare.m4: Remove (Abandoned). * bsp.cfg.in: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. * configure.ac: Remove RTEMS_ENABLE_BARE. | |||||
* | Remove RTEMS_ENABLE_BARE. | Ralf Corsepius | 2009-10-16 | 1 | -1/+0 | |
* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -4/+0 | |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -19/+0 | |
* | Remove special case lib/libbsp/bare (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -8/+2 | |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 11 | -739/+0 | |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -4/+4 | |
| | | | | * startup/bspstart.c: Remove __RTEMS_APPLICATION__ | |||||
* | added support for COBRA5475 board | Thomas Doerfler | 2009-10-16 | 12 | -19/+348 | |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+6 | |
| | | | | * startup/bspstart.c: Add missing prototypes. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 3 | -3/+8 | |
| | | | | | * shared/motorola/motorola.c, shared/vme/vme_universe.c: Add missing prototypes. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+5 | |
| | | | | * startup/linkcmds: Add .sbss.*. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -13/+17 | |
| | | | | | * startup/linkcmds: Add sbss section handling. Misc. sync with binutils's ld-scripts. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+5 | |
| | | | | * startup/linkcmds: Fix up .sbss .sbss.* section handling. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+7 | |
| | | | | * startup/linkcmds: Add __sbss_start, __sbss_end etc. | |||||
* | Update for block device API change. | Thomas Doerfler | 2009-10-16 | 2 | -2/+6 | |
| | | | | * make/custom/ss555.cfg: Remove -D$(RTEMS_BSP_FAMILY) (unused). | |||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+2 | |
| | | | | * Makefile.am: Remove RTEMS_HOST (unused). | |||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+1 | |
| | | | | * configure.ac: Remove RTEMS_HOST (unused). | |||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -3/+4 | |
| | | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 | |
| | | | | * make/custom/gen83xx.cfg: Remove -W -Wno-unused. | |||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 | |
* | Fix typo. | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 | |
* | add PHY control support | Thomas Doerfler | 2009-10-15 | 2 | -191/+159 | |
* | add network support, various corrections | Thomas Doerfler | 2009-10-15 | 7 | -37/+1898 | |
* | add MC_DMA support to MCF548x | Thomas Doerfler | 2009-10-15 | 12 | -0/+4408 | |
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+19 | |
| | | | | * make/custom/no_bsp.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+29 | |
| | | | | * make/custom/uC5282.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+55 | |
| | | | | | * make/custom/sim68000.cfg: New (relocated from /make/custom). * make/custom/simcpu32.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+39 | |
| | | | | * make/custom/ods68302.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+50 | |
| | | | | * make/custom/mvme167.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+75 | |
| | | | | | * make/custom/mvme162.cfg: New (relocated from /make/custom). * make/custom/mvme162lx.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+34 | |
| | | | | * make/custom/mvme147s.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+32 | |
| | | | | * make/custom/mvme147.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+35 | |
| | | | | * make/custom/mvme136.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+59 | |
| | | | | * make/custom/mrm332.cfg: New (relocated from /make/custom). | |||||
| | | | | * make/custom/mcf5329.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+40 | |
| | | | | * make/custom/mcf5235.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+36 | |
| | | | | * make/custom/mcf52235.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+26 | |
| | | | | * make/custom/mcf5206elite.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+33 | |
| | | | | * make/custom/idp.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+49 | |
| | | | | | * make/custom/genmcf548x.cfg: New (relocated from /make/custom). * make/custom/m5484FireEngine.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 4 | -0/+69 | |
| | | | | | | * make/custom/gen68360_040.cfg: New (relocated from /make/custom). * make/custom/gen68360.cfg: New (relocated from /make/custom). * make/custom/pgh360.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+25 | |
| | | | | * make/custom/gen68340.cfg: New (relocated from /make/custom). | |||||
| | | | | * make/custom/gen68302.cfg: New (relocated from /make/custom). | |||||
| | | | | * make/custom/csb360.cfg: New (relocated from /make/custom). | |||||
| | | | | * make/custom/av5282.cfg: New (relocated from /make/custom). | |||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+24 | |
| | | | | * make/custom/smdk2410.cfg: New (relocated from /make/custom). | |||||
| | | | | | * make/custom/rtl22xx.cfg: New (relocated from /make/custom). * make/custom/rtl22xx_t.cfg: New (relocated from /make/custom). |
